Drills / Drivers
Problem for Drills / Drivers
Generic problem for all Drills / Drivers
How do I remove a keyless chuck from my Sea...
By charlieperel on Nov 14, 2008
the screw has been removed but when I insert the allen wrench I can not get the chuck loose. Which way do I turn the allen wrench?
Thank you for any help.
Best Solution
posted on Nov 16, 2008
Helpful)
stug_57u
Rank: Wiz
Rating: 90%, 50 votes
The chuck is screwed on with a normal thread, the screw in the centre (already removed) is left hand thread. Holding the drill with the open end of the chuck facing you, it should unscrew anti clockwise. It might take an impact to start it off. I normally put the gearbox to slow, set the cluth to drill and then holding the drill firmly, hit the allen key against the edge of my workbench. Bring the drill down like a hammer blow so the allen key hits the bench (which should be on your left). I find this more effective than holding the drill on the bench and hititng the allen key with a hammer as it allows for less drill movement at the point of impact.
Was this helpful?
Yes
No
Popular Solutions for Drills / Drivers
Questions and Unsolved Problems for Drills / Drivers
Answer
what is the best impact driver
Answer
need the manual for ryobi 18v charger
Answer
the drill can run fine and then quit without moving the trigger. I can rotate the chuck by hand (no... (More)
Answer
I have a DW958 18v drill and it runs and the bit spins, but if you put your finger on it, it stops.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Drills / Drivers:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
