Question about Technics SL-1210 Turntable
Pioneer pl 200 , no sound well real quiet
I got a pioneer pl 200 but the speaker wires were chopped off bout 20cm from the player i tryed soldering new wires on and av plugs to plug into auxilary of my stereo ,
the sound is very quiet and you hear it better by putting your up to the needle.
any ideas will be greatful.
also there is a 3rd wire in between the 2 speaker wires on original tryed earthing but no luck .
  • skidyup Nov 17, 2008
    hay man thanks for anwering
    the stereo does not have a phono input just 2 plug auxiliary which i plugged it into , same place i plug my ipod in .
    i tried grounding the small middle wire which stopped the quiet hum but no difference to the sound
    Problem Solver:
  • 10 Answers
The third wire is a ground wire I think. You are running the ttb through a phono input and not through a line level input on your system right?
Posted on Nov 17, 2008
No sound from deck
Are the speakers connected directly to the JVC? If so, all four speakers going quiet could be bad soldering on the radio. If the speakers are not connected to the radio, then check the blue/white wire that turns on the internal amplifier.
Aug 06, 2013 | JVC KD-G340 Car CD/ MP3 Player
Can't find replacement cartage for Pioneer PL-200
Try a computer search. There are sources out there
Jul 29, 2012 | Pioneer Audio Players & Recorders
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
My Pioneer PL-990 Turntable only outputs sound through the white wire. Only a quiet buzz comes through the red wire.
The red wire is the right channel, so going back to your amp, get a single phono plug with with the wire exposed, so you can touch the wire. Then remove the turntable connections. With the amp on plug the the lose wire plug into each channel and check if the sound on the right is still low. If it is then there's a problem with the magnetic cartridge pre-amp inside the amp. They are often located near the phono socket on a seperate PC board, but if not just follow the red wire to the main board. Chances are it will be an IC that's failed.
If it has a strong buzz at the back of the amp. Then I should replace the wire between the turntable and the amp. Or the right phono plug that connects to the amp.
Nov 13, 2010 | Pioneer PL-990 Turntable
Pioneer VSX-5300; sound cutting out
try open each speaker test may be speaker or wire short....if all ok check pcb solder side....
Dec 31, 2009 | Audio Players & Recorders
Pioneer pl-200 turntable one channel is dull and muffled
I think we need to do more diagnosis. Did you try swapping the channel cables Left-to-Right so you're sure it is in the TT and not in your Phono preamp?
If it's still in the TT and always on the same channel with two different cartridges you probably have a wire problem in the tonearm/shell or interface between them.
May 01, 2009 | Technics SL-1210 Turntable
My pioneer sounds really bad
Check the antenna input...sometimes these come loose
Mar 12, 2009 | Car Audio & Video
Pioneer car stereo-how to hook up speaker wires
ok u have 8 wires because the other wire is just a ground.as long as u ground the other wires u should be fine. ok the wire that is marked ign. wire may be your mem.wich usally hooks to an orange wire the hot wire u have is just what it says hot that comp. at the end i blieve was a fuse .it sounds like the other part is missing.
Oct 01, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Reconnecting Deh - P3000
HI. search pioneer no sound on this board. i have already walked another guy through this... if everythng works but no sound is outputted.. 99 times out of 100 the audio output ic "chip" is bad. Its a common failure for pioneer cd players as well as others. The part is about $20 if you know where to look... if you decide to repair this yourself you will need to be very skilled with solder and desoldering braid... let me know
Jul 18, 2007 | Pioneer DEH-P3000 CD Player
Technics SL-1210 Turntable Logo
455 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
