Question about Samsung LN-S3251D 32 in. LCD HDTV
No video Remote works OK with the TV - sound and channel selection are OK. No video, except backlight is present. It would appear the main board has the problem, and if so is the current repair technique to replace the board?
  • davdittmar Nov 15, 2008
    The main board does not show any physically defective filters and the input power to the board is OK - are boards rebuilt like the old Quasar modules or is the alternative board replacement. I would like to get pricing and availability from some source and would appreciate suggestions on who to contact.
    I would appreciate assistance in locating on-line sources for new or rebuilt boards.
  • Samsung Master
  • 19,396 Answers
Do not replace the main board!
If there is no raster, but the TV is not responding to the remote, it is FOR SURE not the digital board.
The TV must be tested by a technician following determined troubleshooting diagrams.
Faults that can give you No raster, but Channel selection working:
1 You have no raster, but you see the display menu on screen.
If you are using an external receiver check cables.
Faulty side AV board :See audio video board here
LCD display Ribbon cable: Samsung Cables / Ribbons for model LN-S3251D
LCD controller board: see here the part.
Good luck with your repair.
Posted on Nov 15, 2008
  • Samsung Master
  • 4,806 Answers
The most common problem is the power relay switch with lcd tv's, i replaced mine with ease but other tv's i have worked on the problem has been the whole board, look for semiconductor that looks to have blown out, also chech the capacitors to make sure they are not swollen or melted to the board, there is large chance that if something has blown it has taken some other part out with it.
Replacing the whole board can be very expensive and could cost more than the TV itself.
  • 320 Answers
Disregard the previous information supplied to you. If you have no on screen display or menu, then yes the only option is board replacement. You can look here for the part you need:
http://www.shopjimmy.com/searchparts.cfm?make=Samsung&t=model&m=LN-S3251D
  • Any Guy
    Any Guy Nov 15, 2008
    i JUST SENT A LINK TO BOARDS
    President:
  • 2,712 Answers
    Genius:
  • 1,913 Answers
Open the back side your tv then clean dust also give heat to circuit so moisture is gone.
also recoonect all cable to it.
then try.
    Scholar:
  • 181 Answers
Yes, u r right .its the problem on your main board.and it needs to be checked before replacing the board.sometimes the whole board is not faulty,only some electrical components go faulty.it needs to be checked with multimeter and can be easily replaced by soldering iron.
thanks.
Posted on Nov 14, 2008
  • fixyy Nov 15, 2008
    on the main board just checked for any burned capacitor or any bulgy type or any capacitor pumped from its regular size or any capacitor got leaked from top that has to be replaced carefully.
How do I get my LED TV to start working?
depending on the model, if the backlight has come on but nothing else then the main av board has fun into a fault, some models have a rest sequence to use on the original tv remote to reset to factory settings, if your model does not have this feature, then turn the power off for 10 min and plug power on and holding down the either of these, power button or menu and select. some times these work to reboot.
May 19, 2017 | Televison & Video
LG 42LG30-UD No Picture, backlights work, sound works, control keys work. Everything work, but no video. What could it be?
If you can hear the audio, there should be video too; because, without video, the audio will be muted. I assume something wrong with the LVDS cable. Check it. If you wish to get some details; check the site linked here. Pull up older posts.
Apr 03, 2016 | LG Televison & Video
Tv has sound but no picture, nothing shows with the flashlight test, all inputs have sound but no picture, installed a new t-con card with no results ?
Use a voltmeter to verify the different voltages on the power supply board are present within tolerance. Look for discolored , puffy or domed capacitors. Repair kits and complete replacement boards can be had from: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 17, 2016 | LG Televison & Video
VX37L Screen Suddenly Went Blank, Now No Image, Sound Only on Cable Input, VIZIO Logo Lights Up
turn on the set, grab a bright flash light and dim the lights in the room. Shine the flash light on the screen, if you see a faint picture on the screen, you are dealing with a backlight problem. There are several things that can cause this. One, a bad backlight inverter, two, faulty 24vdc power supply, three, bad main board, or a bad faulty backlamp.
May 10, 2013 | Vizio VX37L Television
Vizio VT470M no picture, no sound, no backlight. Power supply board looks good all voltages appear correct (24V, 5V, and 3.7V) and no "bulged" capacitors . When I unplug unit for two hours, the...
Im having similar problem and with my limited knowledge of lcd tvs and the voltages ALL being good except the pwr on or sw on voltage from the main board to the power supply which tells it to switch everything on Im guessing that something is going wrong on the main board. In the condition where it freezes it (the power on V) which switches everything on i get varied voltages such as 2.5 or 3 or (the normal 5v) and then when nothing powers up (blank screen) i read 0v on pwr on voltage but all my other voltages are corect (24v to inverter, 12 v to main board, 5v, etc.) Im guessing from researching this is that there is in improper voltage somewhere in the main board circuit. I have been unable to find it so i may order another board and post back.
Jun 19, 2012 | Vizio VT470M 47 in. TV
Cant get cable tv
Hello
First connect the cable to its cable input socket at rear.
Turn the tV On and enter its Menu option window. Press UP or DN button on the remote control to select 'Cable'. Selecte EZ scan [channel search]. The TV must scan for all available channels, and will stop after all the channels has been stored in its memory. You have to wait till the search function stops; no other functions with remote cannot be done, and the set will not respond any external command, either by remote control or by its front panel control, except the mains power ON/OFF switch will work. OK.
Nov 21, 2011 | Zenith Z50P3 50 in. Plasma TV
My toshiba lcd tv has a black screen i have no picture or sound
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.if otherwise TURN THE TV OFF AT THE MAINS. This will reset it to default. Wait 1 minute at least.
- TURN TV ON. Ensure you have sound so you know the video/audio feed is OK.
- PRESS THE TIMER BUTTON ON THE REMOTE
you should now have picture or at least response from the screen indicating what channel it is on.
I hope this will help to solve the problem..
Aug 05, 2011 | Televison & Video
No sound on TV
You have turned on SAP sound. Switch your MTS TV sound back to main or standard or Stereo.
OK is used to choose your selection once you 'highlight' it with the arrow keys.
If you are having menu issues, unplug the TV for ten seconds, plug it back in and try the menu again. (you may have to reset your channels)
Feb 26, 2010 | RCA 3-Device Universal Remote with...
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
Samsung LN-S3251D 32 in. LCD HDTV Logo
48 people viewed this question
Henry  Thomas
Henry Thomas
