Question about Canon PIXMA MP780 All-In-One InkJet Printer
Images print too small
When I try to print a webpage the image that prints is about 1/2 inch by 1/2 inch. I can print word docs with no problems. I have reloaded the drivers on to Vista with no luck.
    Sergeant:
  • 390 Answers
Try adjusting your printer settings in the pc undeer you printer icon. Look under properties to see if settings are incorrect for web pages. You can also adjust the settings from the website you are trying to print by clicking on print icon arrow (not just the icon) top right corner and adjust property settigns of your printer for printing.
Posted on Nov 21, 2008
HP PhotoSmart C3140 All-In-One Inkjet Printer will not print in color
ok let's try this
Step One: Remove, inspect, and reseat the problem cartridge
Figura 4: Opening the printer cover (make sure the power is on)
c00308401.gif The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help.
[img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
NOTA:HP cannot guarantee the quality of remanufactured or refilled cartridges.
  1. Make sure the printer is on. Press the Power button if it is not lit.
  • Open the printer cover, then wait until the print cartridge carriage is idle and silent.
  • Press down lightly on the end of the problem cartridge to release it. Figura 5: Removing the tri-color cartridge
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/95/c00484998.gif" alt="" border="0">
  • Slide the cartridge out and inspect it: [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/caution.png" alt="">
    ATTENZIONEDo not touch the copper electrical contacts or the ink nozzles.
    Figura 6: Electrical contacts and nozzles
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/640/c00211537.gif" alt="" border="0">1 - Copper electrical contacts
    2 - Nozzles
    Check the electrical contacts for debris.
    Make sure all the clear nozzle protective tape has been removed.
    ATTENZIONEDo not attempt to remove the copper electrical strip!
    Figura 7: Removing the clear nozzle protective tape
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/767/c00211538.gif" alt="" border="0">Printer Reference Guide supplied with your printer.
  • If the cartridge is compatible, reinstall it in the printer:
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
    Figura 8: Sliding the cartridge into the carriage
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/222/c00484999.gif" alt="" border="0"> Figura 9: Pushing the cartridge into place
    [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/408/c00485000.gif" alt="" border="0">
  • Step Two: Clean the problem cartridge contacts
    1. Gather the following items to clean the cartridge and carriage:
      • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
      • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
      • Sheets of paper or a paper towel to rest the cartridge on during cleaning.
    2. Open the cartridge access door and wait until the carriage is idle and silent.
    3. Disconnect the power cord from the back of the printer.
    4. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
      NOTA:Do not leave the cartridges outside of the printer for more than 30 minutes. If the cartridge is outside of the printer for too long, the ink can dry and clog the nozzles.
    5. Dip a clean foam-rubber swab or lint-free cloth into distilled water, and then squeeze any excess water from it.
    6. Clean only the copper-colored contacts
      Figura 10: Clean the contacts
      [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/172/c01954145.gif" alt="" border="0">1 - Copper-colored contacts
      2 - Ink nozzles (do not clean)
    7. Repeat these steps for the other cartridge.
    8. Lightly moisten another cotton swab with distilled water, and then squeeze any excess water from the swab.
    9. Use the swab to clean the electrical contacts in the carriage, located inside the printer on the carriage slots.
      Figura 11: The electrical contacts in the cartridge slots
      [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/869/c03743456.gif" alt="Image: The electrical contacts in the cartridge slots" title="Image: The electrical contacts in the cartridge slots" border="0">
    10. Wait 10 minutes to allow the cartridge and carriage electrical contacts to dry.
    11. Reinstall the cartridges.
    12. Close the cartridge access door.
    13. Reconnect the power cord to the back of the printer.
    14. Press the Power button to turn on the printer.
    15. Try to print a page.
    16. If you are still unable to print, repeat these steps to clean and reseat the cartridges. Multiple cleanings might be necessary to restore printing.
    Figura 12: Print carriage contacts
    c00906469.gif Step Three: Repeat reseating and cleaning steps If the problem is not solved, repeat the reseating and cleaning procedures above
    Apr 04, 2014 | HP PhotoSmart C3140 All-In-One InkJet...
    Printer prints mirror image only.
    check the menu in the printing section. there should be a section that gives you mirror images, dark background white letters etc..
    need more info on the model .
    Aug 19, 2008 | Office Equipment & Supplies
    My printout is not sharp
    Step one: Print a cleaning page using the control panel
    You can clean the interior of the product by using the Cleaning mode function on the product control panel. To do this, follow these steps:
    1. From the control panel, press Setup .
    2. Use the arrow buttons (http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01393346.gif ) to select Service , and press OK .
    3. Use the arrow buttons (http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01393346.gif ) to select Cleaning mode , and press OK .
    4. When prompted, load plain letter or A4 paper into the input tray.
    5. Press OK to confirm and begin the cleaning process. A page feeds slowly through the product.
    6. Discard the page when the process is complete.
    7. Wipe the paper width guides and the paper path with a dry, lint-free cloth.
    Step two: Clean the scanner glass and the cover
    1. Turn off the product, disconnect the power cord from the product and the wall outlet, and then wait for the product to cool.
    2. Open the scanner cover.
    3. Gently wipe the scanner glass and the cover with a soft cloth or sponge that has been moistened with nonabrasive glass cleaner.
    4. · Dry the glass and lid with a lint-free cloth, chamois, or a cellulose sponge to prevent spotting. Do not use paper-based wipes or tissues that can scratch the glass, or leave fiber residue.
    5. · Close the scanner lid.
    Step three: Clean the pickup roller
    1. Push the release button, and open the print cartridge door.
    2. Remove the print cartridge and find the pickup roller.
    3. Release and remove the pickup roller.
    a. Pull the small, white tabs on either side of the pickup roller outward.
    b. Rotate the pickup roller toward the front.
    c. Gently pull the pickup roller up and out.
    4. Clean the pickup roller with a lint-free cloth, lightly moistened with water.
    5. Allow the pickup roller to dry completely.
    6. Reinstall the pickup roller.
    a. Position the pickup roller in the slot.
    b. Rotate the top of the pickup roller away from you until both sides snap into place.
    7. Replace the print cartridge, and close the print cartridge door.
    8. Reconnect the power cord to the product and to the wall outlet, turn on the product, and then try again to print.
    * If these steps resolved the issue , you do not need to continue troubleshooting.
    * If the issue persists , see the next solution.
    Solution five: Check the driver settings
    Try to resolve the issue by adjusting the driver settings.
    Step one: Check the printer default
    1. Open the Printer or the Printers and Faxes window.
    o Windows XP : Click Start , and click Printers and Faxes .
    o Windows Vista : Click the Vista icon (http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01319360.gif ), click Control Panel , click Hardware and Sound , and then click Printer .
    2. Find your product, and check whether it is selected as the default printer.
    o If the product icon appears with a checkmark (http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01854338.gif ), skip to the next step.
    o If the product icon does not appear with a checkmark (http://h10025.www1.hp.com/ewfrf-JAVA/Doc/images/c01854338.gif ), right-click the product icon, and select Set as Default Printer .
    Jan 02, 2010 | HP LaserJet M1120 MFP All-In-One Printer
    How to set camera mode to have time and date on printed photo. it does show time and date when i review the photo.
    Refer the page # 77 in the manual of the Camera to superimpose the Date stamp on the images or print the images with Date stamp.
    http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=DSCW100guidepdf&sliceId=pdfPage_77&docTypeID=DT_MANUAL_1_1&dialogID=55704716&stateId=1%200%2055706200
    or
    http://www.docs.sony.com/release/DSCW100guide.pdf
    However, because the images shot with the Camera include information on the recording date, you can print images with the date superimposed if the printer or the software can recognize Exif information. For compatibility with the Exif information, consult the manufacturer of the Printer or the software.
    If you use a Photo printing service, ask them to superimpose the date on images.
    However, using the supplied PMB software, you can print images with date.
    How to add a date and time to images for printing using the Picture Motion Browser software.
    http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/feature/edit/attach_date.html
    Good Luck!!!!!!!!!!
    Oct 12, 2009 | Sony Cyber-shot DSC-W100 Digital Camera
    My printer prints only small fonts.
    That is the presentation that you get from a webpage. Webpages are using a different program and it will shrnk or expand the substance of the website you download. Have you tried using the "print screen" function in your computer?
    Aug 31, 2009 | HP PSC 2355 All-In-One InkJet Printer
    Anytime you try and print a webpage it locks up the print job and the user can not delete the job, I have to reset the print spool on the server then it will delete. Only does this with web pages internal...
    Chances are it's adobe-based web pages. There's a known problem with coding discrepancies on Adobe items imbedded in webpages being directly printed.
    If you can save the file to a full .pdf or maybe convert it to a .doc before trying to print it might do the trick. If not, best to steer clear of the problem webpage altogether.
    Aug 20, 2009 | Office Equipment & Supplies
    The images are too big.
    go to the printer perference or setting on your pc, there is option says scale to fit the page, click it , and some of printer allow you to select the paper size you are using. its simple problem its just driver setting issue.
    Good luck
    Mar 19, 2009 | Dell Office Equipment & Supplies
    MFC-5440CN 4X6 PRINT
    mabey try using windows, not linux, make sure you have driver and other software on CD.
    Jul 21, 2007 | Brother MFC-5440CN All-In-One InkJet...
    Printing black squares in word.doc
    It sounds like this is an HP driver issue. HP drivers have built-in "optimizations" (that unfortunately have bugs) for things like printing photos. Different programs (word, for example) try to take advantage of these optimizations in different ways. When they work, they give superior photo printing (faster, with more accurate color). When they don't, you get black squares. This is why "converting" it to PDF worked for you -- Word printed it through the PDF driver instead of the HP printer driver, then when you printed the PDF file, that program avoided those optimizations when it sent the images to the printer. Unfortunately, the translation caused quality loss. If your goal was to print out something like a "proof-sheet" of photos, you might try the free photo organizer at www.preclick.com. It will print these for you, captions and everything, and should be able to avoid the driver issues.
    Apr 11, 2007 | HP PSC 2410 All-In-One InkJet Printer
    Canon PIXMA MP780 All-In-One InkJet Printer Logo
    37 people viewed this question
    old marine
    old marine
