Question about Canon CLC 1150 Color Copier
Will not copy
I have a canon model # np1218 copier
problem is it said paper jam , but there is no paper in copier
it starts to copy but only will go about 3 ins and stop
  • 67 Answers
A sensor is dislodge check where it jams and reseat the sensor be sure to take the copier off before reseating the sensor if that do work replace the sensor
Posted on Nov 15, 2008
Canon IR 2016j, paper jams on every copy.How do i fix it?
Dear Abdullah
pl. check the machine base where it stay, it should be plain and firm.
Next check the left side door(test it by pushing inside while making copy). check the fixing assembly and paper path, may be toner clogged on its surface.
If your machine covered more than 200000 A4 copies, check the paper path (guide) at registration sensor and delivery guide at fixing unit.
If the paper jam at paper pickup tray, replace the pickup roller set (2nos.)
Since you have not mentioned the page counter and where paper jam occurs, its difficult to assume more.
thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
Canon ir4570 always jam at fuser
To properly solve the jam, you would have to start taking apart the machine, take the fuser out and inspect the paper path, a service manual would be helpful as the machines paper path in most cases is very complex, there are alot of moving parts in the path.
there is possibly a small piece of paper in the path, stuck in a gear or something similar, or a part is out of place or there is something in the path that doesn't belong there.
Aug 15, 2010 | Canon Office Equipment & Supplies
The paper won't feed and the paper jam light goes
Wich copier model do you using?
My wild ques would be paper feed rollers. Try to clean them with alcohol and try to copy.
But still I would want to know the model.
You can also contact me on emma.servis@gmail.com, if its Canon copier.
Jul 17, 2010 | Canon Office Equipment & Supplies
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
Canon image runner 7105/7095/7086
try cleaning your pick up rollers but sounds like they need replacing, just clean them with window cleaner and rag
Apr 09, 2009 | Canon imageRUNNER 5570 Copier
Jammed paper
Pper jams are removed from right hand side of copier-remove cartridge and lift green tab, check for paper there.
Paper jams in the fuser section are a real problem with this model the fuser unit has to be removed.
Jun 07, 2008 | Canon ImageClass D880 Copier
Jammed paper at the Sorter Unit
Do you get a paper jam or is the finsher not showing that is empty? You may have a broken bin or a miss alined bin or you have a lazy sensor flag. The copier should give you a idea where the paper jam is... May need more info. on this one..
Jun 06, 2008 | Canon NP 6050 Copier
Canon 6050 copier
yes it indicates same message
Apr 14, 2008 | Canon NP 6050 Copier
Paper Jams
How many copies has the copier done ?
When was the last fuser fitted ?(heated rollers)
the fuser rollers have a life of about 100,000 copies
and you change the whole unit at 200,000 copies
Feb 15, 2008 | Canon imageRUNNER C3200 Copier
Canon CLC 1150 Color Copier Logo
41 people viewed this question
old marine
old marine
