Question about Toshiba 35A44 35" TV
My Toshiba TV is changing channels to snow,. etc.
I was experiencing a problem where the volume would go high on the bar on the screen, and then go back to zero. but the bar stayed on there. Now I am experiencing a problem where the channels rotate on the TV Screen, and I can use remote most of the time to go to channel 3 and it clears up for a bit then comes back on same way. Can you advise woud would be causing this? I thought maybe it was in the remote. I took batteries out and replaced them but is still doing same thing. Could it be that the remote conked out and not working properly? I appreciate any help. Thanks.
  • kemonnie May 11, 2010
    Is this on all of your channels? And how often?
  • 318 Answers
Firstly check your remote negative button on your remote may be its sticking or touching the edge. the problem is with a remote.
Posted on Apr 08, 2009
Volume tv goes down its own
Depending on your TV, here are the generic steps Toshiba has outlined to reset your TV:
1. Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
2. Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
3. Highlight the SYSTEM STATUS menu at the top.
4. Highlight SYSTEM INFORMATION below and press ENTER.
5. At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
6. Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
Apr 09, 2014 | Toshiba Televison & Video
I have a 42 inch lcd tv. The tv will come on but the screen is blue Cant change channel or adjust volume. Any help would be greatly appreciated, thank you.
try to unplug it and a cable or sat box if used from power for a while to see if a reboot will help---also the fact you cannot change channel etc means the set experienced some kind of glitch.
Nov 04, 2012 | Sanyo 42 in. LCD TV
My Toshiba 36AF43 won't get any channels with converter box or anntenna
  • Connect the antenna to the antenna input of the converter
  • Connect the R-W-Y outputs of the converter to the corresponding inputs on the rear of your Toshiba TV.
  • Turn both units on. You should see a converter menu displayed on the TV screen.
  • Select channel scan on the converter. You should see a progress bar displayed on the TV as channels are detected.
  • Scanning should finish by displaying one of the scanned channels.
Dec 08, 2017 | Toshiba 36AF43 36" TV
The screen is red blue and green static like dots
Ur tv convergence are dead.Must know how to solders?Must repalced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair, to buy a convergence kit to rerpair the tv ur self.The shop will cost u $300-350 for parts and labors.
Apr 22, 2010 | Philips 60PP9202 60" Rear Projection...
With the Toshiba 32AV502R 32 in. HDTV LCD TV, can
how do you change your HD setting say 480i to 1080p...
Dec 07, 2009 | Toshiba 32AV502R LCD TV
At random a black retangular box appears on the screen
Go into the TV's closed-caption settings and turn off captioning. You'll find it's set for "text" mode right now. What's happening is that in text mode, the set blanks out the part of the screen where the text will go but there isn't any. On channels or programs where captions aren't being broadcast you don't see anything. With the captions turned off the box will go away.
Apr 10, 2009 | Toshiba 20AF41 20" TV
Toshiba 35a44 problem
check the following power supply components
power transistor of the supply
zener diodes
rectifier diodes
Oct 15, 2008 | Toshiba 35A44 35" TV
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from:
Mar 16, 2008 | Toshiba 24AF45 24" TV
Picture too large for screen
If the television is connected to a cable box such as Time Warner's HD box, the picture mode can be changed by pressing the '#' on the cable box's remote keypad (where the channel numbers are). This cycles the picture between zoom, normal, and stretch which could be cause of your problem.
Aug 18, 2007 | Toshiba 50H13 50" Rear Projection...
Toshiba 35A44 35" TV Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
