Question about Toshiba M675 VHS VCR
Flashing power at startup
When the VCR has been off awhile it flashes on and off for 5 or 10 minutes until if finally settles in. It then works fine but makes it impossible to tape with the timer.
0 characters
1 Points
When I put a tape in the vcr the time flashes and I can hear a tapping sound inside the machine.
You have circuit board problems...time to retire it...they are cheap to rereplace!
Dec 26, 2012 | GE VG4270 VCR
I need the manufacture code for the panasonic PV-V4624S VCR so i can set it up through my dish network receiver. It should be a 3 digit code.
Try these codes, If they don't work there will be instructions for a Power Scan as well this should resolve this!
Codes: 734,856,855,868,869,870,871,872,873,882,813,765,840,841,639,699,663,714,715,716.
Power Scan:
1.) Press and hold the correct VCR button (about six seconds) until all mode button backlights come on, then release.
2.) Press 222 pound (#) then record three times.
3.) With the desired equipment on, press and hold the VCR/DVD button until all mode button backlights illuminate (about 3 seconds), then release.
4.) Press and release the Power button.
5.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
6.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
To verify the code works try several different functions for that equipment.
Daniel Busa
DISH Network Customer Service
Feb 09, 2011 | Panasonic PV-V4624S VCR
My Matsui VCR (VP 9501 OP) won't stop flashing '0.00'.
It sounds like you need to reset the clock,you should find clock setting in the main menu
Aug 30, 2009 | VCRs
Error 2 on Front Panel
I'm not sure if this is a solution, but it cleared up the problem for me. It turned out there was a loose paper label for the cassette that got stuck inside the VCR with the cassette.
I had to take off the top of the VCR by removing the three screws. I then removed the jammed loose paper and then was able to get the cassette out. The flashing number 2 (whatever that means) went away. The machine seems to be working fine now.
Apr 19, 2008 | Philips VR620CAT VCR
Remote control code for Philips VCR & DVD player DVP3340V/17
If you have Dish Network and I suspect if you have Direct TV or a cable providers, you can use your remote for that service provider to find your VCR code. For the Dish you can look in the user's guide on pages 9 and 19 to see how to do a "Device Code Scan" and "Check Device Code".
To Scan: #1: Turn on the device you wish to scan for a code, #2 Press and hold down the button on your Dish remote for that device until all the buttons light up and the specific device button is flashing, #3 Press the blank power button, #4 press the up or down button until until your VCR tuns off, #5 Press the POUND ( # ) key to store the code number and #6 Press the blank power key to turn the device back on.
To Check the Device Code: #1 Press and hold down the device key until all buttons light up and the device button is flashing, next press the POUND ( # ) key TWICE ! The Mode button will flash to code number with a pause between each number, i.e. 5 flashes, pause 3 flaskes, pause one quick flash is 530. Write down this number and you are rady to go !
Nov 16, 2007 | VCRs
unplug it for 30 minutes and retry...any luck?
Jun 01, 2007 | Mitsubishi HS-U445 VHS VCR
Missing manual for - sharp VC-A560 VHS
I lost my manual and the biggest issue of getting this set up is getting the vcr to the channel you need for play back either channel 3 or channel 4. To change the channel you hold the power button and the tv/vrc button at the same time till you get the channel you want. Three flashing lights is channel three, four flashing lights is channel 4. every time the power goes out mine resets to channel 3 and will not play videos until I reset to channel 4. Hope that helps.
May 24, 2007 | Sharp VC-A560U VHS VCR
Flashing (intermittent) display [--:--] no full power up
You have a power supply problem and it most likly will not be worth you purchacing a schematic for this unit unless you want to spend 25 bucks + to fix it.
Sep 25, 2006 | Sharp VC-H993U VHS VCR
Toshiba M675 VHS VCR Logo
20 people viewed this question
Top Toshiba VCRs Experts
alexander woolfolk
alexander woolfolk
Are you a Toshiba VCR Expert? Answer questions, earn points and help others
