Question about BonJour 53372 Wine Cube Refrigerator
Wine cube 11-bottle model#wc900 [ need location of fuse panel ]
There is no power nor light from refrig help what do I do?
  • travlee_sher Mar 19, 2009
    wow no solution yet!
How to make wine bottle windchimes
17 steps to make wine bottle wind chimes -
1. Gather empty wine bottles, ideally, you're are going to need at least 3 bottles.
2. Remove labels.
3. Wash the bottles.
4. Grab a glass cutter and score around the bottle using a
clamp as your guide.
5. Cut 3 bottles and sand the sharp edges to prevent cuts.
6. Get 3 corks.
7. Acquire 6 3/4 hooks.
8. Buy at least 2 feet (0.6 m) of jewelry chain.
9. Screw the hook on top of the cork.
10. Attach the chain to the hook.
11. Push the cork back on top of the bottle.
12. Repeat steps for the other bottle.
13. For the last or bottom bottle of the chime get a metal earring or any accessory.
14. Attach it to the chain. this will make sounds as the wind blows into your chime.
15. Accessorize the end of the chain if you prefer.
16. Carefully connect all three bottles.
17. Hang somewhere where air passes and listen to relaxing sound it makes!
Mar 12, 2017 | Furniture
Plugs in but wont turn on
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - ‎42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - ‎In stock
Jan 20, 2016 | Koldfront 12 Bottle Stainless Steel...
Why do people decant wines?
Decanters are most often used to get rid of sediment from a wine bottle. If you slowly pour the wine on an angle from the bottle to the decanter you can use the light behind the neck of the bottle to see when the sediment approaches the neck.
A second reason to decant wine would be to help aerate the wine, releasing several aromas and flavors. It is best to do this with full bodied highly tannic red wines
Feb 03, 2013 | Wine & Spirits
What is a cube wine rack?
Wine cubes are a versatile type of wine storage which considered being small and can fit large amounts of bottles. You should just stack bottles on top of each other allowing any type of bottle to be stored. This is convenient if many different types of bottles are being used.
Aug 13, 2012 | Furniture
The power seems to be OK ,but the wine cooler is no longer chilling The temperature registers over 80 degrees . We think the compressor is gone. The wine bottle capacity is 30 bottles. Is there in home...
Mcintyre Tv & Appliances
Rr #2, 9622 Dalton Rd.
Grand Bend, ON, N0M 1L0
Phone: 519-238-8270 Appliance Doctor
82 Victoria St E
Wingham, ON, N0G 2W0
Phone: 519 357 4668 Stew'S Rec Vee Service Centre Inc
County Raod 12e G/D
Kippen, ON, N0M 2E0
Phone: 519-263-6058 https://www.danby.com/locator.php?type=dealers It doesn't state if there is in home service or not. But those are the three service locations that are listed in your area.
Jun 11, 2011 | Danby DWC283BLS Wine Cooler
Wine cooler temperture
blown fuse in back panel, there are two of them, one you can see, one is in black shrink rap, this is probably problem fuse. It was on my unit and had to cut away the shrink rap and solder in new fuse. Found the problem fuse in top left of panel in back of unit, hope this helps.
Jan 19, 2009 | Oster 12-Bottle Wine Cellar - Black
The fan does not go on
Ther are two fuses in back panel of unit. One fuse can be seen other is hidden top left of panel and is coated in black shrink rap. I had to replace that fuse to correct the problem. Problem is I had to cut away shrink rap and resolder another fuse, you may have to have someone who can do this look at your uint. Hope this helps.
Dec 19, 2008 | Oster 12-Bottle Wine Cellar - Black
No response from company on Oster 12 bottle wine refrigerator
just replace the 5amp fuse on circuit board with a 6.3amp. tada!
use an exacto knife to remove the shrink wrap on both ends of old fuse. heat ends with a soldering iron and pull away old fuse. solder new 20mm in line fuse holder from radio shack to both poles insert 6.3amp fuse and done. at least mine works again! $6.00 total cost!
Dec 15, 2008 | Oster 12-Bottle Wine Cellar - Black
Refrigerators Logo
52 people viewed this question
Top BonJour Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a BonJour Refrigerator Expert? Answer questions, earn points and help others
