Lasko 5350 will not power up. Tempermental.
Hello, My Lasko ceramic 5350 is quite tempermental. It will not turn on. I've tried unplugging it and using a different outlet. When I reattempt to turn on the power the red light blinks and the unit will not turn on. Yesterday, however, after previous failed attempts, it did turn on and stay on for approx 1 hour. Please help.
  • Anonymous Apr 04, 2009
    My Lasko Ceramic Heater turns off after it gets to hot.
I had the same problem with mine,, I called the 800# and they told me to either vacuum it out weekly or use a hair dryer to blow out the vents, both solutions seemed to have work for me ~ good luck
Posted on Dec 10, 2008
I have a brand new 6405 aka 6410 lasko heater. it will not turn on?? it shut down and no lights or anything will go on?? not dirty cause it's new. any ideas?? reset button??
Posted on Dec 18, 2011
    Problem Solver:
  • 3 Answers
Lasko ceramic heater - when it shuts down simple, clean the back and front of the heater metal net with a powerful vacuum brush
Posted on Nov 05, 2011
My master heater kicked out the reset and it won't reset
Have you unplugged it and let the electrics cool? Then try reset. don-ohio
Jan 10, 2017 | Heating & Cooling
Honeywell portable heater HCE322V manual
Honeywell has the manual for the HCE322V ceramic tower heater on the product page: http://www.honeywellstore.com/store/products/digital-ceramic-tower-heater-hce322v.htm . Click on the Manuals tab. The direct link to the manual is http://www.honeywellstore.com/store/images/pdf/HCE311-HCE322-HCE323-honeywell-heater-manual.pdf .
I hope this helps. Note: the manual covers a few different models. You should ignore any section about the HCE323; that model has a remote and a few other extras.
Jan 08, 2017 | Honeywell Heating & Cooling
How do i deal with the dripping of water from my Mitsubiishi split system from inside unit? Will putting the unit on 19 and then turning it full bore clear over condensing?
NO
the water is condensation from the humidity in the air turning to water on the cold evaporator core
normally it drips into a tray and drains away outside
if it is inside ( running down the walls it indicates
the drain hole and tube is blocked or the evaporator core is covered in gunk and holding the water up and not dripping where it is designed to
Call an accredited ac specialist shop to clean the fins and drain tube
Jan 06, 2017 | Heating & Cooling
I need a new power switch for a Intertek heater Model # ES3000, where can I find one
Here's a link for the entire control panel. http://energysaverheaters.com/ES3000-200CP.html
They do not sell just the power switch unfortunately.
Jan 05, 2017 | Heating & Cooling
Thermostat set at 73degrees , turns on and off to frequently
Hello Jean Thomson,
There are several reasons air-conditioning could go on & off frequently.
Thermostats can be set with close degree function...
Assuming your temperature variances are of no importance
the THERMOSTAT can be adjusted to be less sensitive...
BUT BY FAR... the most common reason for rapid cycling
of the A/C are air leaks and poor insulation...
Your local UTILITY provider will likely have FREE (or very reasonable) thermal analysis - evaluation programs... wit supported contractor services to improve your INSULATION and reduce ENERGY CONSUMPTION.
Also you might need to consider that your A/C system is simply poorly engineered to keep your home at a comfortable temperature...
Again... there are SPECIALISTS who are capable of analyzing your existing structure... and recommending appropriate systems sizing to economically operate efficiently....
Nothing here for the uninformed noviciate... all highly technical.
Save money... Get a PROFESSIONAL ANALYSIS..
Hope this helps!!
Carnac the Magnificent
Jan 02, 2017 | Heating & Cooling
Why does my ceramic heater keep turning off
Without other specifics I can only postulate that it's more than likely overheating, and perhaps it's location stifled
Dec 09, 2014 | Heating & Cooling
Electric Furnace stopped running
You have one of two problems. Either the capacitor for the motor has failed or the motor has failed. I would turn off the power to the unit and see if you can locate the capacitor and remove it. An ac supply or electrical supply house can match up the capacitor. This is relatively inexpensive. Otherwise you will need a new motor.
Nov 11, 2014 | Heating & Cooling
Williams wall heater setting off co2 alarm
Then it may well need a service or check the alarm
Jan 01, 2014 | Williams (5009622) Ceramic Gas Wall...
Heating & Cooling Logo
767 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Cris Sparks
Cris Sparks
