Question about Compaq (294416-B22) Internal ZIP Drive
Drive light comes on when a disk is inserted, but the drive will not show up on the computer...
I got a used computer, and the zip drive light comes on when I put a disk in but nothing else. The drive does not show up on the computer and windows (xp) cannot locate it with the hardware wizard.
    Problem Solver:
  • 15 Answers
Are you sure it's connected to the IDE/ribbon cable. If so you may want to check if it's Master/Slave/Cable Select jumper is in the correct position.
Posted on Nov 22, 2006
Cannot open drive E on Iomega zip 100
Assuming you have connected the drive and then restarted the computer with the drive connected and powered on... if it is model 31714 (not the same as the picture no power supply is required - if power supply is required make sure unit is powered on prior to connecting)
First guess at your problem. Your disks are formatted for a operating system other than what you are using. (Mac formatted disks on a PC or the other way around)
If you don't know how the disks were formatted you could test this by letting it get to the "insert disk" and then trying to right click and see if you have a format option ... note this will erase all information on the disks.. you will likely need to long format
Second guess the drive is bad... have seen cases where the drive is bad. If you have another computer you can use try hooking the computer up to another computer and see if you get the same result.
Let me know if this does not work and specific model number and op system I might have more ideas. I can also point you to a replacement If I know more about your system.
Feb 20, 2015 | Iomega Zip 100MB (31714) External ZIP...
I have a Zip 250 disk that will not read. When I insert the disk in the external disk drive, it will spin and stop a few times and that's it. When I try to access the disk/drive letter via "My Computer",...
If the disk is unreadable this means that the format or the files extensions on it are not readable in the operation system you use..either are damaged or the disk itself is damaged or it wasn't finalized like it should ...If other disks inserted run ok than the disk it is damaged and it is nothing wrong with the drive itself..When it says to insert a disk this means that it is not seeing the disk at all and it sounds like a drive problem ..but if other disks are ok ..than it is just a damaged disk or in a format unreadable ..beware if it a cd unit ..will not read dvd-es..or if it a dvd kind will not read large dvd-es (dual layer) or blue-ray disks..
May 29, 2010 | Iomega ZIP 250 External ZIP Drive
Pen drive showing insert disk
check your pend drive on some other system if the message is the same, it has become corrupt,replace it
Sep 16, 2009 | IBM Iomega ZIP 750 (22P7099) External ZIP...
Please Insert a Disk in Drive H:
you can replace your usb port, or YOU CAN USE YOUR PENDRIVE IN ANOTHER COMPUTER, by which you will come to know that whether your USB port is OK or not.
Mar 26, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pendrive error message "please insert a disk in removable disk"
right click my computer.
click manage
selest disk management
right click to drive-H
select change path 7 name of drive
change it to any letter except lettur used for your other drives
thats it it is done.
Dec 23, 2008 | IBM Iomega ZIP 750 (22P7099) External ZIP...
Khypermedia DVD RW - not being consistent
Try to re-install the drivers for the drive.
Hope this helps!
Nov 23, 2008 | KHypermedia (KDVRW8X) (20730176) DVD+RW...
Cant figure out how to use zip drive when i have added a pass to my zip dr 250
1. Insert a blank disk into the zip drive
2. Give this disk a password (it can be any password, as long as you
remember it)
3. Using the Ioega toolset, set the zip drive's sleep time to a large
value (such as 1 minute)
4. Wait a while until the drive "spins down". You will hear the drive
stop spinning.
5. Take a pin or a straighten paper clip and stick it into a hole in
the back of the Zip drive. This will manually eject the blank disk.
6. Insert the disk you want to access (the one you don't know the
password to)
7. now use the IoMega toolset to remove the password. When prompted
for the password use the password from step (2).
This is just a word of warning in case you store any important information like I used to on zip disks. Perhaps move to a more secure medium.
May 09, 2008 | Iomega Zip 100MB (31714) External ZIP...
Iomega zip port
First of all, make certain you are only using 100 MB disks in a 100 MB reader.
If the problem is more complex than that, I have several questions:
Can you read different disks?
what type of connection is the zip drive using with the computer? USB?
does the zip drive need an external power supply?
will the zip drive successfullly read disks when connected to a different computer?
does the zip drive appear under my computer at all? even as an empty drive?
what operating system are you using?
Mar 29, 2008 | Iomega Zip 100MB (31714) External ZIP...
My pen drive get detected and when click to open it shows the message: " PLEASE INSERT THE DISK INTO DRIVE I"
my pen drive get detected but i am not able to format and copy things to my pen drive
Mar 26, 2008 | Pen Drive IVO MP3 Player
Compaq (294416-B22) Internal ZIP Drive Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
