Question about Lite On LVW-5005 DVD Recorder
I have two LiteOn LVW 5005 DVR recorders. One will not open .
It reads open on the display but doesn't open.
The second one doesn't always stay closed when I change a DVR and start reading the disc. Can anybody help me or tell me where to get it fixed.
I use mostly DVR's that are rewritable +RW.
  • 1 more comment
  • Anonymous Nov 29, 2008
    I have the same problem which I'm trying to solve right now.I'm pretty sure it's mechanical due to wear and tear of the plastic movable parts.I also have the 5026 model which is beginning to show the same early symptoms.
  • ChiTownJack Dec 01, 2008
    I have same issue...The button seems to be working and the display says "OPEN" but the tray does not move (all the time). Sometimes it does open but when it doesn't, if I knock on it or pick it up slightly and set it back down with a slight thump it opens.
    Closing mine is also an issue sometimes...I have to gently lift the end of the tray to get the mechanism to engage and close the drawer.
    I am out of warranty and LITE-ON tech support can not help. 1-877-525-1900 is the number...$1.49 / Min charge for support.
  • klatil Dec 08, 2008
    I have exactly the same problem. When I push the open button, there is a click as if the device tries to open the tray, but it cannot.
5 Suggested Answers
SOURCE: Lite-On LVW-5005 (DDW-813s)
I have same problem like you, but I have changed the DDW-813s to a new Lite-On DH-20A3P, it work perfectly, good as new.
Posted on Oct 31, 2007
SOURCE: DVD Recoder trouble
I have the LVW 5005 and was having a similar problem. Unplugged it tore it apart (looking if anything looked physically wrong) plugged it back in and it worked (and still is). Try unplugging it, letting is sit for 1/2 hour and plugging it back in. Might get lucky.
Posted on Mar 23, 2008
SOURCE: Lite On LVW-5045 DVD Recorder - won't record onto disc
Liteon lvw 5045 problem action failed.please consult our customer service for recovery. (error code: 0x810D0004)
Posted on May 10, 2008
  • 39 Answers
SOURCE: i have a liteon 5005 dvd recorder and it tells me
you must use the proper recording disc for formatting compatability of your unit. i.e. r+/r- confer with owner manual for recommended discs mch
Posted on Mar 09, 2009
  • 16 Answers
SOURCE: Liteon DVD recorder LVW-5045 has disc inside and won't open tray
Use your knuckles to knock on top of cabinet just above disc tray door while at the same time pressing open button,99% of the time disc tray will open.The problem you have is caused by a worn out belt drive or the tray is out of alignment.The disc tray belts only cost $2,when tray is open you can see the minature belt that controls door to the right.Use twizzers to remove and replace.Belt size 1.9
Posted on Aug 09, 2009
Liteon dvd recorder won't play or record from disk or cable tv
You should be able to connect with the AV input, Y, Video R, W. Audio, they go to same color on DVD & TV.
Feb 18, 2010 | Lite On LVW-5005 DVD Recorder
I need a user manual for a liteon lvw 5001 email address richard_beck@btinternet.com
Go to Liteonit internet site.You can download a free manual and put on a CD disc.
Mar 20, 2009 | Lite On LVW-5005 DVD Recorder
I have a liteon 5005 dvd recorder and it tells me that my disc is invalid what can i do to fix it?
Mar 08, 2009 | Lite On LVW-5005 DVD Recorder
Liteon lvw-5045
If your DVD recorder can still access CD's the goto the following link and select your DVD recorder from the drop down list under audio/video and download the firmware file.
http://www.liteonit.eu/index.php?option=com_wrapper&Itemid=178
Write the file contained in the zip file to a CD and insert it into your DVD recorder. Follow the instructions in the user manual to complete the firmware update.
This should solve your problem.
Feb 19, 2008 | Lite On LVW-5005 DVD Recorder
DVD Recoder trouble
Dec 05, 2007 | Lite On LVW-5005 DVD Recorder
Remote
You can order a new remote on their homepage by going to the consumer support section.
Aug 16, 2007 | Lite On LVW-5005 DVD Recorder
Lite On LVW-5005 DVD Recorder Logo
71 people viewed this question
Top Lite On Televison & Video Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
JOHN TOPLISS
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
