Question about Northern Industrial 2 Hp Twin Tank Electric Air Compressor
Starting the unit
My compressor (a portable) starts pumping when I turn it on. It goes up to 120 lbs and then at the point it is to shut off, it does. The air then starts escaping from the compressor switch and purges the tank down to 70 lbs; I believe that this is through the unloader which is built into the pressure switch. The compressor tries start up again, but fails and repeats this action until I shut the system down by pulling the plug because if I try to depress the on and off switch it lets more air out of the tanks. The pressure switch was replaced with a new one, but this did absolutely no good, it keeps doing the same thing.
    Scholar:
  • 65 Answers
I am thinking it is 110 volt. the reason I mention that is because I had a similar problem with powering back on but without the air leakage. Narrowed it down to insufficient power supply. As it didn't do it all the time. And I think the built in thermo protector somehow had an effect. Think the motor heated up faster due to not enough current, and the thermo protection tried to keep it from starting but wasn't working properly to start with I don't think after it was a year or so old. It drew 15 amps, That is a big draw. Turn on a skill saw at the same time there went the breaker. Different locations it acted differently.
In your case I think if you replace that entire power switch pressure unloader assembly. It sounds like at least your describing an assembly, that definately sounds faulty and may be the root of the whole problem. Then just to check, check your amp draw for the compressor and make sure the circuit your plugged into doesn't have a lot of other demands. Better to get 25 feet more of air hose then use an extension cord, depending on your amps for your compressor.
The way it's described sounds like the on off switch, pressure switch that controls the auto on and off, and the pressure relief/unloader valve are all together. So when you say you replaced the pressure switch, did you replace the whole assembly ? If I am calling that correctly in picturing it as being one combined unit ?
Posted on Nov 20, 2008
I have a D55168 Dewalt compressor. Since I've had it, it has never shut off automatically and I've always shut it off manually at 200 psi. If I leave it alone, will it automatically shut itself...
Your concern is very well placed, at pressures that high a lot of damage can be caused by a failure. According to the manual for this model air compressor the approximate cut-in pressure is 160 psi and the approximate cut-out pressure is 200 psi. Meaning it should pump up to 'about' 200 psi and shut off and not come on again until it gets down to 'about' 160 psi. They say approximate and I say about because it's not an exact science setting the pressure switch. Spring rates are not always exact, pressure guages are not that precise, etc. When turned on, it should shut off at 200 psi +/- 10 lbs. If it goes more than 10 lbs over that (220psi), I'd recommend you get the pressure switch and or guages checked or replaced.
Jun 16, 2011 | Dewalt D55168 1.8 HP Wheeled Portable...
Compressor UP6 25 125, runs all the time but is only under load for a short time, should it shut down between loads?
This unit will shut down if unloaded for a set period of time. Usually 5 to 10 minutes. This time could be longer if some one has changed it from the factory setting. There is a timer in the control box that starts counting down when the unit unloads. If it stays unloaded long enough for the timer to count down the unit will stop until the air pressure drops to the low set point on the pressure switch. It will then start up. If the unit loads before the counter counts down the timer starts from the beginning when it unloads again. This cycle continues until you manually shut it down or you stop using air long enough for the timer to reach Zero and shut down.
Apr 22, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
MY AIR TANK WILL ONLY HOLD 40 LBS OF AIR WILL NOT GO ANY HIGHER I HAD THE PRESSURE SWITCH TESTED AND ITS GOOD WHEN IT GETS UP TO 40 LBS IT STAYS RUNNING AND WILL NOT SHUT OFF MODEL FP209001 2 GAL...
If the pump is putting out 40 lbs then it is working these things are loud there must be air leaking out some where are you sure that the petcok on the bottom of the tank is closed or the blow out valve is not leaking or mabey I would say the gauge but it dosn;t shut off If the pump is putting air in that tank it eigther compresses or it comes out run your hands all around the mechine when its running there must be a leak
Nov 24, 2010 | Campbell Hausfeld 2 Gallon Air Compressor
I have a 5 gal, i hp craftsmen compressor, 3 years old, used once a year to blow down sprinkler system. Compressor ran up to 120 lbs upon turn on, would not cycle off. manually shut off unit and turned...
Oil free pumps do tend to blow the piston ring (not too expensive) available at searsparts.com. Remove covers to pump and manually turn crank until piston is at top and look at the condition of the cylinder neer top, If it looks scratched, order cylinder kit with piston ring. If it looks good and shiney, could be the valve plate in the head. There are reed valves that tend to break. Run pump however with covers removed and check with soapy water for air leaks and repair as needed (air leaks under the cover will prevent unit from filling). Good luck
Nov 13, 2010 | Craftsman 15 gal Air Compressor 3 hp UMC...
After starting the compressor, the tank does not fill up to 120 psi and shut the compressor off automatically. It will continue to run and not fill the tank completelhy. How can I fix this?
It could be one of three things. 1. The air intake could be dirty to the point that it cannot take in enough air volume with each cylinder stroke to be able compress it to 120. Try cleaning the air filter. 2. The reed valve that prevents the return of air from the tank to the compressor is not sealing well. This might be cleanable, but requires disassembly. 3. The cylinder itself has a poor seal giving you bad compression. This would require major surgery and parts, and is probably not worth fixing.
Jun 29, 2010 | Campbell Hausfeld FP2080 4 Gallon Portable...
2 hp 120 v motor on compressor. motor will not start under load
bleeder valve is bad or dirty drain air unplug machine pull the back up plate control plate and make it shinny with emmeory cloth then clen it and try again, if it still does the same thing your going to nedd to replace unloader valve.
Apr 14, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Tank pressure 120 regulated pressure 200. how can
If your pressure cut-off switch is faulty, it will keep running. Could be very dangerous. MSC has switches with different ranges. I had this problem once with an 80 gal. compressor. It was running and I cautiously walked over and shut it off. At this point it had 200psi built up. Yes, I was scared but a new regulator fixed it. The old contacts were rusty and wouldn't release. Hope this helps.
Terry
Nov 18, 2009 | Dewalt D55146 Factory Reconditioned 4.5...
Leaks air at the pressure switch
start your compressor and let it buid up pressure to turn off. then unplug from power.lossen the fill tube that goes from the pump to the tank. when you loosen it. if it leaks air then your check valve is bad and will have to be replaced.
Dec 25, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Cycling compressor
The pressure switch will shut off when the set pressure is obtained. Usually about 100 to 120 lbs. If the compressor stops at lower pressure than mentioned you may try to adjust the pressure by looking under the switch cover for adjustment screw/nut.(no more than a few turns) Increase pressure by increasing spring tension. Quick cycling is usually caused by air leaking from tubing, drain valve or check valve. After compressor shuts off unplug it from the outlet and spray soapy water on all fittings and drain valve. Repair leaks and test for quick cycling, however the compressor should reach 100-120 before shutting off. Some small compressors have a thermal reset but that usually takes a few minutes to reset. Pressure switch is defective if it shuts off before setting mentioned. Enjoy
Dec 11, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Northern Industrial 2 Hp Twin Tank Electric Air Compressor Logo
124 people viewed this question
Top Northern Industrial Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Northern Industrial Air Tool and Compressor Expert? Answer questions, earn points and help others
