Question about HP Computers & Internet
I can't seem to get my moniter out of sleep mode
  • HP Master
  • 4,806 Answers
Just press the on off button, it should wake up
Posted on Nov 15, 2008
Came home to find computer off. It was left in sleep mode. The moniter keeps saying there is no signal and the keyboard has no power.
If its truely in sleep mode, and won't come out of sleep mode. Unplug the computer from its power, hold the power button down for 5-15 sec, then wait 2-5 full minutes. Then plug it back in, and turn it on.
If that doesn't work it is NOT stuck in sleep mode. Most dell computers I've worked with the caps go out in the power supply and/or the motherboard. I would next clean out the computer with canned air, check the caps on the motherboard, and in the power supply. If there are any bad caps, replace them, and it should fix it. Hopefully though the above paragraph fixes your problem.
Sep 13, 2013 | Dell Dimension 4600 PC Desktop
Power switch is staying in sleep mode. will not turn on or when it does turn on the moniter stays in sleep mode
use external monitor and go to control panel - power setings - here you can set up all you need
Nov 10, 2012 | E-Machines eMachines Desktop PC
Computer starts but moniter stays in sleep mode .. moniter works on different comp .. will adding a vid card to my comp fix this problem ??
Actually, Yes. It seems like you have answered your own question... Especially considering the monitor works on another computer.
Do you have another monitor to test on this computer?
Although another consideration could be if you recently installed or downloaded a program which may have changed your video output range to a setting your video monitor wont handle. If this is the case and you can start the computer in safe mode, this will allow you to go into your properties settings and change it back. This way, a new vid card is not req.
Good Luck
Sep 14, 2012 | HP Compaq dx2300 Microtower - RT950UTABA...
Moniter is stuck in sleep mode
Check for shorted out transistors (C5706/5707) in the inverter circuits.
Dec 17, 2009 | Dell E173FP 17" LCD Monitor
Will not come out of sleep mode
RMB in desktopselect properties... screen saver...10 min..............thank u
May 06, 2009 | Computers & Internet
The monitor will turn on but only stays on for about 3 seconds
Maybe you guys should make sure the moniter is on the right input, because if moniters are on a wrong input then they go into sleep mode. If that doesn't work make sure that the cables are fully inserted! Hope I Helped!
Jan 20, 2009 | HP Pavilion F1703 17" LCD Monitor
Monitor will not boot up stays in sleep mode
Is your pc got beeps, if yes then try to remove and clean the memory and also the video card if it is add on card. and then insert it again test. if encounter still the same error then try to replace the memory.
please tell me more if ever what you encounter about the issues.
may this help,
melnavz
Oct 04, 2008 | HP Media Center m7060n PC Desktop
Sleep mode
There is an On Display Menu (ODM). You can access it by pushing the button located on the monitor. Use +- buttons to navigate in the menu. Here you can switch off the sleep mode or change the sleep settings. I have a simular problem... I try to turn off the power save function but it seems like it dosen´t want to understand this...
Oct 08, 2007 | Compaq TFT5015 15" LCD Monitor
Computers & Internet Logo
26 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
