Question about Dayton G73 Utility Heater
Dayton 4lx46 garage heater - metal pipe through attic leaks
Last year I had this garage heater installed professionally. Metal pipe was installed through the attic above the garage, then outside (vent). This vent leaks from what appears to be the inside of the pipe - condensation? The water filters through the seams in the pipe then leaks onto the floor in attic. Any suggestions on how to repair this? I've though of sealing the outside of the pipe but am concerned that the condensation/moisture would travel down to the actual garage heater and then out on to the garage floor. Any suggestions would be appreciated.
  • fpmelenchuk Nov 15, 2008
    I do NOT have a steam system. It's a garage heater, gas powered, with model number mentioned. This solution has absolutely nothing to do with my problem!
    Genius:
  • 1,011 Answers
Sir,
leak causes the water in the drip/catch pan at the base of the heater to rise to . ... Buy water heater drip pan had the logbook open in your garage
Posted on Nov 15, 2008
    President:
  • 1,314 Answers
PEOPLE.....PLEASE READ THE QUESTION BEFORE ANSWERING!!!! You show your ignorance when you don't!
Basti mentions something about a steam system and sloping of radiator.....what does that have to do with his problem? Doesn't even have anything to do with the item he mentioned.
abhishek33 gives some useful information, however, it has nothing to do with his problem. READ THE QUESTION....HE already has a unit, he has a problem. He doesn't need help in picking out a unit.
Sorry to hijack your post, fp, but I'm really tired of idiots on here who can't read a question when they try to answer it. I'm not talking about wrong answers, but at least answer the question about the product. That's like me asking how to turn on my computer and someone teools me how to start a lawn mower with facts about purchasing a car....
</rantoff>
    Genius:
  • 1,239 Answers
Hi Deciding what kind of tankless heater to go with depends on a couple of things:
  • The flow rate, or amount of water you'll need heated at one time
  • Temperature rise, or the difference between your groundwater temperature and the desired output temperature
The Federal Energy Policy Act of 1992 set flow limits at 2.2 gallons per minute (GPM) at 60 pounds per square inch (PSI) for household water fixtures [source: U.S. Dept. of Energy]. Some people also use aerators to further limit the flow of water. Tankless manufacturers size their units based on the temperature rise needed for a given flow rate.
To calculate your flow rate, add up the GPM for the household water fixtures you'll need at one time:
  • Bathroom faucet - low-flow faucets use 0.5-1.5 GPM. Standard post-1992 fixtures are set at 2.2 GPM. Faucets before 1992 fall between 3.0 and 5.0 GPM.
  • Kitchen faucet - pre-1992 fixtures use between 3.0-7.0 GPM. The post-1992 standard remains 2.2 GPM, and kitchen faucets don't use aerators, so there are no low-flow numbers.
  • Shower - low flow rate is between 1.0-2.0 GPM. The 1992 standard remains 2.2 GPM. Pre-1992 heads fall between 4.0-8.0 GPM.
    Genius:
  • 1,447 Answers
Hi
With a steam system, hammering noises may occur if the radiator isn't sloped slightly. Place small shims beneath one end to slope the radiator toward the outflow
If the inlet valve leaks, the culprit is usually a worn valve stem packing. Repairing this involves draining water in the system until it drops below the valve and then dismantling the valve and replacing the packing (this is very similar to a faucet). If you don't know how to drain water from the system, call a plumber or radiant heating service person.
Hope this helps
  • 19,396 Answers
The leak is probably condensation, if you have enough space you can install a fan where you get condensation.
Try to keep the space where you get condensation as airy as possible.
  • Ginko
    Ginko Nov 15, 2008
    If it is possible install a fan near to the leaking fan or a main fan to aireate the garage.
    Follow some of the instructions here.
    If you dind out the cold pipe line that is condensing and dripping, you can cover it with insulating enclosure, this will definitively solve the problem.
    FD11 Sheet Metal Pipe Enclosure Detail
    Ensure also that the problem is not a leak from some other line, or rain water dripping throught the roof into the heater.In that case fix the leak.
How do I hook up the exhaust on a Dayton Gas Garage heater?
Well you have to buy reducer to get it down to 2 inches. Are you sure it's 2 inches or 3 .
Maybe this is a high efficiency heater so design to use a 2 inches pvc pipe
Dec 19, 2017 | Dayton Gas Furnace Heater
Goodman ac/heater drain pan leaking since instillation 3 years
sounds like the unit needs to be elevated and leveled.
Aug 10, 2012 | Goodman Heating & Cooling
I have a 3 ft stainless double wall chimney that is going thru a ceiling/roof in my garage. there were no instructions on installation. how is this secured? Pls thx Jer
You can use metal strapping with short self-tapping sheet metal screws also where it penetrates roof a metal collar on inside should be used and a roof collar approved for B-wall vent pipe to keep water from leaking inside on outside on the roof.You can penetrate outside of B-wall vent pipe with short screws to secure the pipe just don't penetrate both pipes.this outside pipe is just a insulator to keep heat from transferring through pipe.
May 01, 2011 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
My van is leaking antifreeze from somewhere by the firewall of the van not the radiator. Its the metal hose that has a hole in it but i can't figure out the name of these metal (aluminum)hoses.
The metal hose by the firewall is either your heater core inlet pipe or outlet pipe. These inlet and outlet pipes will develop leaks for a varity of reasons. If this is the source of your leak, you may want to replace the entire heater core which is much easier than trying to fix the leak. The attached link will help you.
http://www.allpar.com/fix/heat.html
http://www.thirdgen.org/heatercore
Please remember to rate this solution. Thanks!
Feb 04, 2011 | 1999 Chrysler Town & Country
My dayton NG heater fan will not shut off properly
Sounds like a bad fan switch. The switch is located on the heat exchanger and is 110 volt bi-metal switch. Follow the wires from the blower going back to the heatexchanger. Graingers can get you a new switch if you give them your model number. www.grainger.com.
Dec 12, 2009 | Dayton Heating & Cooling
Water leaking out engine near front fire wall
Sounds like one of the connections to the heater core are leaking. Should be hoses connecting to the metal heater core pipes. The heater core is on the inside of the car with metal pipes going through the firewall to heater hoses.
Nov 01, 2009 | 2001 Oldsmobile Alero
The rear heater lines, metal pipes, have Is there
Have you thought of sandpapering the lines clean, then using JB Weld?
Oct 29, 2009 | 1994 Plymouth Grand Voyager
Rheem small 6 gallon water heater vibration/noise
If the water heater is working fine than I would not worry about the function of the water heater. What the problem may be is that some of your WATER LINES HAVE MOVED, AS THEY WERE NOT SECURED PROPERLY. The sound you may have heard was the Copper or PVC(Plastic) lines just getting back comfortable. I Suggest checking that your water lines are secured about every 3 or 4 feet with the proper ancjhor....Metal for metal pipe, copper for copper pipe, etc. Sometime as in my house, pipes are run through a hole drilled through a stud or a piece of wood, usually when hot water is run through this pipe. You can here an expansion of the water line interacting with the pipe expanding, if the hole in the wood was not drilled big enough......Experience of remodeling a very old house.......Joe
Dec 31, 2008 | Rheem 81VP6S/430126 Water Heater
Dayton G73 Utility Heater Logo
66 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
