Question about Toshiba Satellite A70-S249 Notebook
Hi, can I operate the A 70 on mains power without a battery
Hi Team I wish to use my laptop as a desk top and mobile and wonder if if would be best to run without battery when on mains power
Thanks
Allen
  • kateal Nov 14, 2008
    Hi Commanderzod, thanks for your advice I thought I might be able to extend the life of the battery by removing it when on mains power for extended periods.
    Allen
  • 112 Answers
Your battery will not charge until it reaches a lower limit of charge.
Whilst in the Laptop and using mains power your battery acts like a UPS and is available soon as you lose power.
The battery life will not be degraded or improved, removing it whilst plugged into mains.
When using Laptop om=n mains the battery is always there in case you lose power or somehow the lead gets pulled out inadvertantly, so you will not lose work.
I use a laptop all the time for work just got a new Latitude D630. The battery in my old lappy is still good for 2hrs+ and never been removed.
80% of its life was on mains.
Hope this helps.
Posted on Nov 14, 2008
  • Geoff Champion
    Geoff Champion Nov 15, 2008
    Thanks for the fixya kateal.
    If only we could make them last longer.
    But that would mean less after market profit for the manufacturers.
    Glad I could help.
    Zod
Compaq laptop
Unplug power adapter from laptop and remove main battery, press and hold power for 2 minutes, when finished install battery and power supply. Now turn on the computer.
May 03, 2012 | Averatec Computers & Internet
My c610 battery i have replaced it 2 times but it still dolesnt charges it stops it stops to charge during charging
Hi nabhanizatio
DELL LATITUDE C610 BATTERY CHARGE FAILURE
The likely cause of the original battery fault is a very common mistake in the way laptops are used. A laptop battery, working at optimum efficiency, whether of the older Nickel Cadmium and Nickel Metal Hydride or newer Lithium Ion types, is meant to charge under power and then discharge under use, if it is to have a long and useful life. This means that it should be used in a similar way to a cellphone's battery - connected to mains electricity and charged up when low or flat and then disconnected from the power and used on battery power alone until the power level means the cycle needs repeating. Many people, however, unwittingly use their laptops like desktop PCs and leave the mains electricity permanently connected to it even after the battery is fully charged. The reason that people cite for doing this is 'convenience'. This, however, is a mistake.
Laptops have more flexibility than cellphones in that, if they are mainly used in one place rather than as mobile devices, then it is possible to charge the battery to full capacity, disconnect from the mains, then remove and keep the battery until the next time the laptop's mobility function is required (periodically recharge the stored battery if not in use for long periods of time because the charge slowly dissipates when not in use), reconnect the mains to the battery-less laptop and use it like that, ad infinitum.
When a laptop battery is fully charged, what it really wants to do is discharge. However, maintaining the mains connection prevents it from doing so. The Power Management
System on the motherboard is designed to cope with long periods of either battery powered or battery-less mains powered use, but not long periods of simultaneous battery + mains powered use. A fully charged battery still connected to mains electricity has no means of discharging and various power sensitive components such as the Power Inverter, Cold Cathode Backlight, LCD Panel, Graphics Chip and Motherboard Power Management Stystem can become damaged by the power bottleneck created.
Using the battery in this wrong way also gradually depletes the charging capacity of the cells, until eventually, the cells can carry no charge, meaning a dead battery. A dead battery, where the cells are depleted, left in the laptop with the mains connected, is even worse for the Power Managent System
because the flow of power to the motherboard via the dead battery cells is inefficient and intermittent, creating battery overheating, low CPU Cooling Fan speed, inferior cooling and consequent internal overheating hazards in addition to potential electrical damage to several components. When damage to the Motherboard Power Management System passes a certain point, even a new battery might not charge - the situation in which you now find yourself.
Loose DC jacks, leading to intermittent power drops and surges, are typically caused by the jack being allowed to take the weight of the heavy transformer box on the laptop's power cable. The solution is to ensure that the laptop is never held, carried or used with the transformer hanging unsupported. If the laptop is in use, the transformer should be disconnected, carried, placed on a desk or table near the laptop (if the cord is short) or laid completely full-weight-flat on the floor (if the cord is long enough). Also, a Surge Suppressor/Surge Protector should always be used between the mains power socket and all computer
equipment, rather than directly to the mains.
If either the Motherboard Power Management System or DC Jack are ever damaged, your laptop would require professional specialist repair by a Component Level Laptop Repair Specialist, providing No Fix No Fee, Warrantied Repairs ( typically 3-6 months Repair Warranty).
I hope this helps.
If this answer does help you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and guides us in exploring the best ways to provide useful, high quality answers. If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa.
Oct 07, 2011 | Dell Latitude C610 Notebook
Battery does not charge is their any easy fix that is not - buy a new battery please?
Hi shaun par914...
If you have an ohm meter, check you ac adapter ouput to make sure it has electricity at the plug and is not defective.
Sorry, Otherwise if it is working, then you must replace your battery as there is no fixing a defective battery.
Please tke time to rate me
Sep 03, 2011 | NEC Computers & Internet
My Gateway MS2285 didn't charge, so I took out the battery and ran it on AC only and it was okay. Should I do this if i plan on running on AC for a long period? What do you suggest please
Hi
The likely cause of the original battery fault and the key to what to look out for in future is a very common mistake in the way laptops are used. A laptop battery, working at optimum efficiency, whether of the older Nickel Cadmium and Nickel Metal Hydride or newer Lithium Ion types, is meant to charge under power and then discharge under use, if it is to have a long and useful life.
Many people, however, unwittingly use their laptops like desktop PCs and leave the mains electricity connected to it even after the battery is fully charged. The common reason that people cite for doing this is 'convenience'.This, however, is a mistake.
Laptops have more flexibility than cellphones in that, if they are mainly used in one place rather than as mobile devices, then it is possible to charge the battery to full capacity, disconnect from the mains, then remove and keep the battery until the next time the laptop's mobility function is required (periodically recharge the stored battery if not in use for long periods of time because the charge slowly dissipates when not in use), reconnect the mains to the battery-less laptop and use it like that, ad infinitum. It is this method of powering the laptop that you have recently discovered.
When a laptop battery is fully charged, what it really wants to do is discharge. However, maintaining the mains connection, prevents it from doing so. The P
ower Management system on the motherboard is designed to cope with long periods of either battery powered or battery-less, direct mains powered use (as you are currently doing), but not long periods of simultaneous battery + mains powered use. A fully charged battery, still connected to mains electricity has no means of discharging and various power sensitive components such as the Power Inverter, Cold Cathode Backlight, LCD Panel and Graphics Chip can become damaged by the power bottleneck created.
Using the battery in this wrong way also gradually depletes the charging capacity of the cells (as seems to have happened to you), until eventually, the cells can carry no charge, meaning a dead battery. A dead battery, where the cells are depleted, left in the laptop with the mains connected, is even worse for the Power
Management System, because the flow of power to the motherboard, via the dead battery cells, is inefficient and intermittent, creating battery overheating, low CPU Cooling Fan speed, inferior cooling and consequentinternal overheating hazards in addition to potential electrical damage to several components (and even burn damage to users' laps).
Loose DC jacks, leading to intermittent power drops and surges, are typically caused by theDC Jack being allowed to take the weight of the heavy transformer box on the laptop's power cable. The solution is to ensure that the laptop is never held, carried or used with the transformer hanging unsupported. This is a very real danger wparticularly when the laptop is moved while being used in a battery-less condition. If the laptop is in use, the transformer should be disconnected, carried, placed on a desk or table near the laptop (if the cord is short) or laid completely full-weight-flat on the floor (if the cord is long enough). If a battery-less laptop is being moved, to be completely safe, it should really be powered down beforehand. Another hazard of battery-less laptop use is the accidental pulling out of the power cable while the laptop is in use, which can cause serious damage to the Hard Drive, CPU, RAM, Cooling Fan Motor, Graphics Chip, LCD Panel, Cold Cathode Backlight and LCD Panel Power Inverter.
Also, always use a Surge Supressor/Surge Protector between the mains power socket and all Co
mputer equipment, never connect the laptop's power cable directly to the mains.
When battery cells are dead, a replacement battery is required for mobile computing and should be bought and installed as soon as possible. In the meantime, the old, dead battery should be removed and disposed of in an ecologically sound manner and the laptop can be used (battery-less) on mains power alone.
Manage any new battery you buy and the AC/DC Adapter in the way described above and you should hopefully avoid problems in future.
I hope this helps. If this answer does help you, please take the time to rate it. This helps answerers like me better understand the needs and the point of view of the asker and guides us in exploring the best ways to provide useful, high quality answers. If you need further help, please feel free to post another question or add a comment to this question.
Sep 03, 2011 | Gateway NV5378u Notebook
My laptop sony vaio will not hold a charge for very long.
battery backup problem replace a battery or purchase a new battery.
Sep 02, 2011 | Computers & Internet
My Dell says it doesn't recognise my new battery, and tells me that I should press F1 and that it won't be able to charge it, but it then does appear to charge it ok, although the light at the...
Hi
You don't say which Operating System you use.
A new battery needs a good, long charge for only the first charge. After that, charge until it is fully charged. The battery charge icon at the bottom right of the screen, near the clock, will tell you the state of the battery, by floating the mouse over it. If you have no icon, right click on the Task Bar, bottom of screen > properties > notification area > tick 'power' > apply > ok.
The likely cause of the original battery fault and the key to what to look out for in future with the new battery is a very common mistake in the way laptops are used. A laptop battery, working at optimum efficiency, whether of the older Nickel Cadmium and Nickel Metal Hydride or newer Lithium Ion types, is meant to charge under power and then discharge under use, if it is to have a long and useful life. This means that it should be used in a similar way to a cellphone's battery - connected to mains electricity and charged up when low or flat and then disconnected from the power and used on battery power alone until the power level means the cycle needs repeating. Many people, however, unwittingly use their laptops like desktop PCs and leave the mains electricity connected to it even after the battery is fully charged. The reason that people cite for doing this is 'convenience'. This, however, is a mistake.
power management system on the motherboard is designed to cope with long periods of either battery powered or battery-less mains powered use, but not long periods of simultaneous battery + mains powered use. A fully charged battery still connected to mains electricity has no means of discharging and various power sensitive components such as the Power Inverter, Cold Cathode Backlight, LCD Panel and Graphics Chip can become damaged by the power bottleneck created.
anagement System because the flow of power to the motherboard via the dead battery cells is inefficient and intermittent, creating battery overheating, low CPU Cooling Fan speed, inferior cooling and consequent internal overheating hazards in addition to potential electrical damage to several components.
Also, always use a Surge Suppressor/Surge Protector between the mains power socket and all Co
mputer equipment, never directly to the mains.
When battery cells are dead, a replacement battery is required and should be bought and installed as soon as possible. In the meantime, the old, dead battery should be removed and the laptop used (battetyless) on mains power alone.
Manage the new battery and the AC/DC Adapter in the way described above and you should hopefully avoid similar problems in future.
I hope this helps. If this answer does help you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and guides us in exploring the best ways to provide useful, high quality answers. If you need further help, please feel free to post another question or add a comment to this question. Thanks for using FixYa.
Sep 02, 2011 | Dell Inspiron Mini 10 Notebook
I have lost Bios password on my Samsung R530. How can I get it back
Usually removing the internal battery in a laptop does not remove the BIOS password. However I have just done this on the Samsung R530 and it did remove it.
Remove AC power, remove main battery, turn laptop upside down and remove all screws, push up the little tabs at the top of the keyboard to unclip it and remove ribbon cable from motherboard, disconnect the 4 wire speaker plug and then pry open laptop from the front, pop the plastic lugs in the battery bay and remove the top facia.
Remove the small coin battery and hold the power button for 15 seconds making sure you do not have the AC jack or main battery installed.
Reassemble, turn on and you should be able to press F2 to enter setup.
Please thank if I helped.
Jan 22, 2011 | Samsung R530 Notebook
My battery always stays charged, so why is my laptop telling me that i need to replace my battery?
Hi,the reason why your laptop is telling you to replace Battery is,you have killed your battery without knowing by Charging it always,since you have constant power supply,you should at least after getting a new Battery,discharge it four to five times a week longer life of battery,by these i mean,unplug cord from mains let power drain to 5% or 10% before charging again while working and if fully charged and you are not making use of it disconnect and if you want to make use of it use battery instead do not connect immediately to mains until power drains from battery.Just like your mobile phone,you only charge it when need be(ie. when Battery is Low).
Jan 01, 2011 | HP Pavilion DV7-1020US Laptop
My computer won't wake up after going into
HI, i suggest you unplugged your system from the AC outlet and leave for sometime to rest, power it on back after few minutes and put on your system.
Doing this will help wake your system up from hibernation.
I wish you best of luck.
Jan 07, 2010 | IBM ThinkPad R40 2722 Notebook
Desk top won't display-hibernation mode
Based on your post of failure to boot due to hibernation, you can try removing the battery and AC adapter connection for an hour or so. Thereafter, insert battery back and charge but don't power up. Allow the laptop to charge for a couple of hours. Try powering up/booting. Press F8 to start in Safe Mode. Once in Safe Mode disable Hibernation.
If the laptop still fails to power up, then it may be entirely another problem.
Post back results. Good luck and kind regards.
Nov 04, 2007 | HP Pavilion dv4000 Notebook
Toshiba Satellite A70-S249 Notebook Logo
183 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
