Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharpness of the image
Having trouble tuning the picture. Have tried he drop down menu and put sharpness at highest level but the image is still not crisp. Its a brand new TV. Is there a setup step that can correct this? Or maybe it is the local signal? it is a42D65U unit
  • Anonymous Mar 19, 2014
    no signal--:-- ----/--/----
    select the service setup menu to add new service. What has happened to my tv?
Putting sharpness up to high will cause the opposite effect. To get the correct level of detail you are looking for you need to adjust all your settings, especially your contrast and brightness levels. A good guide would be cnet.com. They have several posts for TV settings for HDTV. Goof luck. Please post back to let me know how things go.
Posted on Apr 03, 2009
Troubleshoot dell e5500
Depending upon your operating system, try reducing your resolution to something lower. If your resolution is currently at 1920 x 1600, reduce it down to 1280 x 1024. This should allow you back up & regroup.
On a blank portion of your screen, <Right Click> your mouse, choose "Properties" for Windows XP or "Screen Resolution" for Windows 7, for Windows XP go to the last tab, Find the Resolution slider or drop down menu and choose a lower resolution than the one you are currently using.
If your laptop is connected to an external monitor, use the monitor menu buttons to recenter and shrink the image back to factory settings.
Good Luck. Dell Certified Systems Engineer - DellTech1
May 03, 2013 | Dell Superb Choice Laptop Replacement...
I have a Toshiba laptop.. completely new, and it was 700 dollars. When I go onto facebook, or clothes shopping, all of the pictures are blurry... but text is fine.
I understand that you are having the issue that you are getting Blurred Pictures while accessing the sites. To answer your query with the proper steps the information about the Browser you are using is required. If you are using the Internet Explorer you may follow the steps: Launch the Internet Explorer browser by double-clicking its Desktop icon or selecting it from the Start menu. Click "Tools" in the top menu bar of Internet Explorer. Select "Internet Options" from the drop-down menu. Click the "Advanced" tab and scroll down to Multimedia. Check the box next to "Smart Image Dithering." This will help to ensure that images are loaded properly. Right-click on the image in Internet Explorer and select "View Original Image" from the pop-up menu. This will force the browser to display the original image. Check to see if any installed Internet browsing accelerators are compressing your browsing too much and causing the blurred pictures. For example, the MSN Accelerator (used to enhance the speed of an individual's Internet connection) can sometimes cause blurry images due to high levels of compression. Right-click the "MSN Accelerator" in your Windows task bar (bottom right-hand corner of your PC's screen) and set the level of compression to "None." If you are using the other browser you may try resetting the settings. Even in Internet explorer you may reset. But note that resetting the Brower may deleted the saved information like password and auto fill.
For additional help if you need please revert back with the exact details like the browesr you are using.
You may also try updating the flash player and check the operations
Sep 03, 2011 | Toshiba Satellite P100 Notebook
Put new carbs on. Having trouble tuning air/petrol mix and syncronising the carbs.
need vacuum gauge, take one carb and adjust till highest vac setting. then match next carb to first carbs settings (same vac) if u can't match adjust first carb to 2cd carb's highest vac setting. make sure engine is warmed up first.then ride
Apr 03, 2011 | kawasaki ZL 1000 A1 Eliminator Motorcycles
When I shoot with my nikon, I'm able to see details and and sharpness on the images. When I shoot with my sigma sd14 I am not gettin any sharp pictures. When u see the pictures u are not able to see a
This Sigma has poor reviews at high iso levels i.e 1600, try dropping the iso levels down and see if there is any significant improvement.
Regards Marc
A Nikon/ Canon Fan
Apr 16, 2009 | Sigma SD14 Digital Camera
Having problem with focus, cant even read the menu sharp dt300
try cleaning the color wheel with rubbing alchol and a q-tip
Feb 21, 2009 | Sharp DT-300 Multimedia Projector
Television screen is showing mirror image not the actual image.
There's a button on the original remote control that does exactly that:
(Please vote or comment if my solution helped you!)
Adjusting PICTURE FLIP Settings
You can set the orientation of the picture.
Directly setting the PICTURE FLIP
Press PIC. FLIP to display the
PICTURE FLIP screen.
2 Press PIC. FLIP to change the
setting.
Setting the PICTURE FLIP on the
MENU screen
Press MENU to display the MENU
screen.
2 Press a/b to move the cursor to
PRESET, and press ENTER.
3 Press a/b to move the cursor to
PICTURE FLIP, and press
ENTER.
4 Press c/d to select the desired
picture flip setting, and press
ENTER.
5 Press MENU to return to the main
screen.
NORMAL MIRROR ROTATE
UPSIDE DOWN
A•
The PICTURE FLIP screen automatically
disappears in 3 seconds.
• [NORMAL]: normal image
[MIRROR]: mirror image
[ROTATE]: rotated image
[UPSIDE DOWN]: upside down image
Oct 22, 2008 | Sharp LC-15AV7U 15 in. LCD Television
Changing settings
Hi cajun51man
If you go into the User Menu of the Projector look for a subfolder that reads either Flip Image or Mirror.
Scroll down to it and scroll left or right - this will switch between the image features.
May 26, 2008 | Sharp Notevision XG-C50X Multimedia...
SONY 61" Rear Projection TV
you will need to get a service manual for the tv and enter the service mode. then you will need to readjust the convergence.
Oct 24, 2007 | Sony KP-53S65 53" Rear Projection...
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
