Laptop only works when plugged in
My HP Compaq NX9105 will only work while plugged into the mains. If you pull the plug while the laptop is running, it goes dead (much like a PC would if you did the same to it). Pretty certain the battery is fine so what needs fixing/replacing?
  • tcharleswort Nov 15, 2008
    So how do I go about fixing it?
  • Anonymous Apr 30, 2009
    I have a HP DV1321us. It will charge the battery and run on ac supply but when I unplug it, it will die after about 3 seconds. The battery is fully charged but it just is not getting power to the motherboard for some reason. Any help would be appreciated. Thanks,
  • 1,124 Answers
If the battery is good, then you have a bad motherboard connector.
Posted on Nov 14, 2008
  • Pablo Csaky
    Pablo Csaky Nov 15, 2008
    Usually replacing the battery it is fixing the problem. In your case you said that the battery is ok, so the problem is in the board or the connectors, to fix that the laptop must be serviced.
    But you can try before with another battery from similar laptop or a new one and see what happen first.
Disk drive change
yes there is an a adapter that the size of cdrom drive except you can 2.5 drive inside of it and it plugs in like a cd drive
Feb 11, 2013 | HP Compaq nx9105 Notebook
HP Compaq nc6220 Laptop is dead. no lights,
Is this the same if the charger is also plugged in??
Remove battery and retry with charger plugged in.
If same battery charger is faulty.
Dec 22, 2009 | Compaq Hewlett Packard nc6220 PC Notebook
Laptop mouse pad doesnt work if being used on flat surface
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 27, 2009 | HP Compaq nc6320 Notebook
Does my compaq nx9105 have an in built microphone to go on skype
There is a jack for an external but there is no internal microphone on this model
Oct 17, 2009 | HP Compaq nx9105 Notebook
Change videocard
You need a High end graphic card to play such games... go ahead and purchase a a HDMI graphic card... consult hp for it...
Jul 03, 2009 | HP Laptop Keyboard for HP/Compaq Pavilion...
Hp compaq laptop no power
you 1st need to confirm that your mains adapter is working properly, does the charging light on your laptop come on when plugged in? if it does, then good.
you should be able to cancel hibernate mode by holding the power button for about 10-15 secs
hopefully this will then allow you to power up as normal,
I don't like Hibernate mode myself as I have had previous problems with it and I tend to disable my laptop from hibernating.
if the charging led does not light when you plug in your laptop the it is possible that you have a faulty Power adapter or power controller circuit.
hope this helps
Mar 24, 2009 | HP Compaq nx7300 Notebook
Computers & Internet Logo
1,998 people viewed this question
David Payne
David Payne
