Back to:
Tags:
RCA VR355 VHS VCR
RCA's save button (by 3 users)
posted by cheche_lcn on Nov 21, 2006
My vcr does not want to work. I put the tape in and it doesn't do anything but says save on the screen (of the vcr). What can I do to it so that it can work? Is their a button I have to push to get the save off of it so it can work? It won't do nothing at all It don't even turn off or on. Can you please tell me what I can do to fix it.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Mar 20, 2008
the panel of my VCR shows the word "safe" and i can not use it.
Comment by vcr-beat-me, posted on Dec 04, 2007
(we have an old tv & have to chg ch thru the vcr. we've done this for almost 2 years) few days ago it shuts off and says SAVE. I put a none recordable tape in and it ejected it. I put a rec'able one in and it kept it! It won't turn on or eject this tape. has the time on its view sceen till we push a button then it says SAVE. What can I do. We tried unplugging the power a few times, no go.
Solution #1
posted on Aug 18, 2008
Not Rated (0)
freetek
Rank:Wiz Wiz
Rating: 83%, 522 votes
This model seems to be developing a variety of problems and those I have read could be caused by failing power supplies since poorly filtered or unstable supplies can cause unpredictable problems.
If I am correct, you will need a tech to do some checking and servicing these has become questionable from a standpoint of cost and (some) parts availability.
Although the problem description is not the same, the message I posted a few minutes ago may be useful in your cases too:
"The clock uses very little power so a weak supply might still be able to provide stable voltage to it.
All the other functions require enough power to drag down a supply that is on its last legs and I think that is where the problem lays.
If the display brightness seems normal, then either a different section is being used for the missing functions or a weak capacitor in the power supply can no longer filter the DC voltage well enough to provide stable voltage to motors, the main board, etc.
To determine what is at fault will require some technical skills and a couple of instruments normally not found at home.
About the only thing you might try on your own is to open the case, look for a customarily separate board that appears related to the AC input cord which should be unplugged at this time.
You will see cylindrical parts ranging in diameter from 1/4" to about 1 1/4" and various heights.
The tops are normally visible and the cases are of aluminum. Look for any that seem to have bulging tops or a crusty deposit around their base.
Those things are visible indicators of failure.
If you find such parts and have an appropriate soldering iron (not a higher power 'gun') you might remove these and buy replacements.
That could be a problem since most electronics supply places won't even talk to you.
If you want to try on line, look at www.mouser.com , one of the few who will sell single quantities of parts.
The values will look something like this:
100uF/16V
These parts are polarized so if you don't see a '+' or '-' on the board, be sure to mark it before removing so any new part does not fail immediately after replacing."
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on RCA's save button:
I don't want to Accept this solution
Can you Help with these VCRs problems?
VCRs
I have an LG VCR model no. EC490SW/EC290SW (about 6 or 7...
VCRs
I have connect my SD-V394 Toshiba DVD/VCR combo to my Sony...
VCRs
Does anyone have the new codes for the ntl box in ireland?...
RCA VR355 VHS VCR
I have had RCA's in the past and whenever we lose power in...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
