Question about Toshiba Satellite M65-S9092 Notebook
Toshiba m65-9092 locks up
The computer locks up unless you bend it around the sides close to the touchpad area.it works great then stops again unless you bend it. its driving me nuts.
    Scholar:
  • 112 Answers
I guess the fix on this one depends on your knowledge of taking apart computers. The problem sounds like there is something loose (either not plugged in all the way, or loose wire). The other option is a crack in a circuit board. If you feel that you know that you have enough computer hardware knowlege to have a look inside, I would check out this site. I use it frequently.
http://www.irisvista.com/
On this page are 2 tutorials about your model that will help you take it apart.
http://www.irisvista.com/tech/
If you don't feel up to it, take it to a repair shop. Hope this helps. If you have any other questions, post another comment.
Posted on Nov 15, 2008
Toshiba touchpad frozen!
Check for a switch for the touch pad.
Jun 15, 2017 | Toshiba Satellite(R) L655-S5115 Laptop...
It stopped working what to do to start it
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
Jun 29, 2011 | Microwave Ovens
Toshiba Laptop Scroll problems
Scrolling is not obvious because there is no area actually marked on the touchpad that shows where it is. Also if you tap the area before doing it, it won't work. Even for me it is hit and miss, since I don't practice with it enough. You could adjust the area that it uses and make it bigger, but then that gets in the way of regular mouse usage.
I would suggest that you try it at a store, and have a sales person show you how to use it.
As for the curser jumping even with that checkmark, well it can. All that checkmark does is turn off the touchpad for a brief moment while oyu are typing. Pause for a second and the touchpad is active again, then slightly bump the touchpad and your mouse will jump. Prove this to yourself by turning off the touchpad entirely with Fn+F9.
In the touchpad settings you can adjust various things to suit you. For example increase the slider for the diable while typing chekmark oyu mentioned, decrease sensitivity, turn off tapping support, etc. Each have thier pros and cons, and that is why they are adjustable.
Also, since you repaired it, I assume they tested it to make sure it was working. And if the touchpad is working, then the jumping adn the scrolling have nothing to do with a hardware problem, it is all software. You can replace hardware till the cows come home and it won't change things. So look at the software settings for scrolling and for "jumping".
This signature left intentionally blank.
Please let me know if you have any further questions or concerns.
Thanks.
May 07, 2010 | Toshiba Satellite A3 A355D-S6922 Notebook
Toshiba M35 S320 touch control buttons have stopped working. How do I fix it?
The TouchPad is enabled by default. To change the enable/ disable TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click the Mouse icon. 4 Click the TouchPAD ON/OFF tab. The TouchPAD ON/OFF tab view window appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply. 7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window. 9 Close the Control Panel window.
However, still if it does not work, you need to download drivers for touchpad.Here is link to download the drivers for touchpad. Under the "All categories link choose Touchpad"
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=556040&rpn=PSM30U&modelFilter=M35-S320&selCategory=3&selFamily=1073768663
Mar 27, 2010 | Toshiba Satellite M35-S320 Notebook
I need a replacement power adapter for my toshiba satellite ps171u-11993h. I live in the atlanta, ga area. Need to know a price range for this and location or phone number to get one. Thank you. Also on my...
The jumping around is you having your wrists too close to the touchpad, the touchpad is picking up signals from your wrists and moving the cursor to another area while you are typing. You can turn up the sensitivity on the touchpad properties to take care of the problem. The power adapter can be purchased on Ebay for approx. 30-40- dollars. Try to stay away from the very cheap ones...like 12-18 bucks, they are usually shipped out of Hong Kong, are cheap and get very hot. The other ones are in the USA, can handle the punishment and have warranties that actually are good. Just make sure you keep all your reciepts and paperwork.
Sep 07, 2009 | Toshiba Satellite 1715XCDS Notebook
Samsung q210 keyboard not working
There is a small ribbon cable that will pop out real easy when you open it up. There are actually 2, one for the keyboard and one for the touchpad. This can be a little difficult to put back in the slot and close the laptop back up without it popping out again as the cable is not very long. If you have a lot of patience, you should be able to get it. Just take your time and remember to close the lock on the connector where the ribbon cable slides in.
Aug 26, 2009 | Computers & Internet
Toshiba a300 synaptic touch pad scroller stopped working
Hi there.
The touchpad drivers could be corrupt, try reinstalling the touchpad drivers again.
Go here to Toshiba Support fill in the details of your model laptop and download the synaptics touchpad driver and reinstall it, see if that helps.
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
Good luck and thanks for choosing FixYa!!
Jun 01, 2009 | HP Pavilion dv4000 Notebook
How do I stop the Toshiba Satellite A200 touchpad locking?
When using FN button, Hold button down then press Function button you want then release FN button.
Feb 01, 2009 | Toshiba Satellite A100-S8111TD Notebook
Problem with the touchpad
when you plug the ac plug in do not have the unit on. then turn unit on to see if all is well with the touchpad area.
Jun 03, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Synaptics touchpad not working
Have you looked at the Device Manager to see if there's a problem with the touchpad?
Start -> Control Panel -> System -> click on Hardware tab -> click on Device Manager button. Do you see anything that indicates a problem with the touchpad?
Also, you might want to check the BIOS to see that the touchpad is still enabled. I doubt that this setting would have changed, but it's worth checking. When you boot the computer you should see a message that says something like: "To enter setup press XXX" where XXX is the delete key or some other key. Once you're in the BIOS poke around to see if you can find the settings for the Touchpad. Different manufacturers use different BIOS' so I cannot tell you exactly where to look.
Good luck.
Dec 19, 2007 | Toshiba Satellite A20 Satellite A25 Series...
Toshiba Satellite M65-S9092 Notebook Logo
117 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
