Question about Crate SPA1600 Power Amplifier - SPA Series Car Audio Amplifier
Crate Acoustic Durango Model (CA120D)-Cuts out
I have had this amp for a few years and it has always had a habit of cutting out, very irratically. I have reduced the problem down to the the input jacks, I think. If I put a small rubber washer on the input jack to prevent it from going in too far it reduces the problem but doesn't eliminate it. I recently noticed that the #1 feedback filter light comes on when the problem occurs. Crate told me a while back they could replace the jacks, at my cost, as they are not under the warranty (surprised me!!). But not sure the jacks are the entire problem, and why replace with the same style of jack?? HELP PLEASE!!!
2 Suggested Answers
SOURCE: Crate BT50 Bass amp cutting out with high input.
Sometimes an amplifier's preamp can't handle certain signals/frequencies at a high gain, so they cut out. Bass guitars are especially prone to giving such a strong signal.
I bought an older, nonworking bass amp recently and fixed it just to find it had the same problem. Best solution is to put a low ohm resistor at the amps input, but if you turn your guitar down to half volume it'll have the same effect: should prevent it from cutting out.
Posted on May 20, 2008
Where can i buy the circuit board
Your best bet is to conact Crate customer service. Hereis their contact page-
http://www.crateamps.com/support/index.php
Nov 04, 2015 | Crate CA15 Cimarron Acoustic Guitar Amp,...
Frying sound from amp intermittantly
then the problen is in the power amp section after the preamp stage. Contact Crate for your nearest service center.
Mar 03, 2014 | Crate Ca6110dg Gunnison 60 Watt Acoustic...
Effects don't work
On some amps there needs to be a footswitch inserted in the control jack to activate the effects circuit. Contact Crate to see if that's the case with your amp.
Jan 28, 2014 | Crate CA30DG Taos Acoustic Guitar Amp, 30...
Loud crackling on several pots
Sounds like your pots are dirty. You need to spray a cleaner such as Deoxit in the pots then rotate them a few times..This has to be done with the power off and the amp unplugged from the wall...Remove the knobs, get some food grade plastic hose which will be a snug fit when shoved on over the shafts of the pots...make sure to cut a piece off the hose about one inch in length...spray the cleaner into the hose and then with the hose still shoved down over the shafts rotate the shafts back and forth a few times...Then power up the amp and recheck...This will only work if the pots are not gone beyond the point of no return..Outside of that, they will need to be replaced which means you will have to disassemble the unit...
Jan 12, 2014 | Crate CA125DG Telluride Acoustic Guitar...
I have a 2000 Dodge Durango 5.2L. It starts fine, but it stalls unless my foot is on the gas. When it reaches idle speed it cuts off. I can even get it into gear if I do it while my foot is on the gas, but...
Sounds like a vacuum leak, but please see my tip at http://www.fixya.com/cars/r7427423-fix_poor_idle_high_idle_stalling_fuel . These are generic instructions. If you getstuck or need specific instructions for your car, please get back to me with model, year and engine info.
May 27, 2011 | 2000 Dodge Durango
I have a Fender Telecaster guitar and a Crate amp that cuts out i
The next time it stops, unplug the cable from the guitar and touch the tip of the connector with your finger. If the amp hums, then the amp is still working and the problem is in the guitar. If there is no hum from doing this, then the amp has am intermittent.
Try this before it fails to see what to expect in the way of the hum from this test.
Common problems with the amp are OFTEN with a broken input connector or bad switch on the preamp output jack if it has one.
There are MANY other things and without troubleshooting it is hard to steer you to a fix.
Mar 26, 2010 | Fender '72 Tele Deluxe Electric Guitar
Alpine PDX1.600 amp cuts off
Make sure there's no missmatched impedance. If your sub running 2 ohms then your amp has to be 2 ohms stable. Does the amp blow fuses or get really hot? If it does it can be a fire hazard and I would recommend taking it out of your car. It could be that you don't have sufficient grounding. The grounding needs to be very close to the amp and the paint needs to be thoroughly scratched off. Otherwise could be a blown transistor within the amplifier, you can check this by opening up the amp, running a multimeter and testing the transistors for resistance.
Aug 04, 2009 | Alpine PDX-1.600 Car Audio Amplifier
Nov 01, 2007 | Crate SPA1600 Power Amplifier - SPA Series...
Crate SPA1600 Power Amplifier - SPA Series Car Audio Amplifier Logo
219 people viewed this question
Top Crate Car Audio & Video Experts
xxxxxx xxx
Are you a Crate Car Audio and Video Expert? Answer questions, earn points and help others
