Question about IOGear (GBE201W7) Wireless Headset
Cannot connect using WIDCOMM
I cannot get this adapter to work on Windows XP Pro SP2. My Bluetooth places" does not detect anything, yet I am using the same version that the manual uses. Can anyone help me?
0 characters
1 Points
MY BT-03I Connect Successfully to my laptop but laptop can't detect that as a headset/speaker so i can't hear any thing with it !!! please help me
If you are running Windows XP, you will need to load on a "Bluetooth Stack" for Audio Profile support. These are not free, unless they are bundled with your laptop of the Bluetooth add-on card.
The built in Windows XP Bluetooth support is minimal and based on data transfer only.
Bluetooth stack providers include Widcomm and BlueSoleil. The Laptop Vendor or add-in card provider need to provide the stack.
Apr 23, 2011 | Genius BT-03i Bluetooth Headset
Toshiba laptop with IOgear bluetooth adapter installed will recognize phone but won't detect plantronics explorer headpiece. I would like to use it to chat on skype
If the Bluetooth adapter can detect the phone but not the Plantronics headpiece, then there's no problem with your computer or your Bluetooth adapter. The problem has something to do with the Plantronics.
Try to turn the headpiece off, then turn it back on. Set it to discovery mode, then try to detect it using your computer. If that did not help.
Try to detect the Plantronics, using your phone. That will help you in isolating the problem.
Aside from that, make sure that no possible wireless interference while you're searching for the headpiece. Cell phone, base of the cordless phone should be away from the computer while you're searching for the headpiece. Because Bluetooth and cellphones/cordless phones are running on the same 2.4GHz frequency RF signal. They might interfere with each other.
Apr 14, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Insignia NS-BTHDP ok with phone, pairs with PC but can't connect
Make sure the headphones are set as "default" under Control Panel>Hardware and Sound>Sound>Manage Audio Devices - same for microphone if you're using it for online speech.
Jun 04, 2009 | Insignia Bluetooth Wireless Headphones...
Pairing a bluetooth adapter without key
hay the key is nothing more then a metal stylus try using a sewing pin in place of the stylus. it is metal and small enough to fit in the hole this will alow you to press the button and set it into pairing mode. good luck and have a nice day!
Feb 08, 2009 | Cardo BTA II - Cellular phone Bluetooth...
Jabra bluetooth adapter A210
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
Lost my Insignia Bluetooth Headset Disk
Oct 16, 2008 | Insignia Bluetooth Wireless Headphones...
Lost Disc
I bought this headset from Best Buy and it came with a usb dongle.  I also lost the disc.  Insignia's website is useless, and the Broadcomm update website is down at the time of this writing.  After hours upon hours of scouring, I found a working driver, which works perfectly.  This works on Windows XP, but I can't verify that it will work for Vista.    I hope this helps you.
I will never buy Insignia products again because of their lack of driver support.
Best regards, RobotJay
Aug 21, 2008 | Insignia Bluetooth Wireless Headphones...
Pairing headset with laptop
Make sure you have software that supports headsets such as widcomm these links may be useful.
and the drivers
hope it helps! I set it up using generic BT dongles on my custom built machine at the house and it works like a charm. Good luck
Dec 23, 2007 | Motorola Mobility Bluetooth Hands Free...
IOGear (GBE201W7) Wireless Headset Logo
Top IOGear Headsets Experts
Brian Sullivan
Brian Sullivan
Are you an IOGear Headset Expert? Answer questions, earn points and help others
