Question about E-Machines Computers & Internet
Dual voltage I would like to buy desktop computer model eMachines® EL1200-01e. I'm not sure that this desktop has dual voltage. On the picture there is red switch (110/220V) like on the most desktops with dual voltage. But its only switch and in spec they don't mention about supplay.Does somebody know this model?
  • E-Machines Master
  • 4,806 Answers
Contact emachines and ask them, not all power supply units have volt switches, the best thing you could do is have a physical look at the same model if you can find it in a store or view the specs on line
Posted on Nov 15, 2008
Dual monitor
It appears you have two outputs for video so yes, you should be able to export the video signal for dual monitor use.
Apr 22, 2013 | eMachines E Machines Et1831-07
Emachine won't power on??
from the video the only think i can think of is that some computers have a little red switch that changes from an american standard voltage to european standard make sure that switch is turned to 120v(located in the back of the computer with mouse and keyboard connectors). secondly the other solution if that didn't work the power supply were the plug is connected into for the computer is propably not connected to the motherboard. to do that their is a connector on the power supply that should say P1 that connects to the motherboard. if all that fails have some own or yourself plug something in to the outlet in which you use for your computer to see if the outlet is at fault. If all else fails get a new power supply and have yourself or a computer technician or have a pro technician in PC maintence look at your computer or just buy a new computer.
*hope this was of use to you and sorry for the spelling mistakes*
Mar 18, 2013 | Computers & Internet
I havea model EL1210-09 desktop and would like to add an additional video card to run dual monitors. What is needed?
does it have a graphics card in it already if so then you will have to buy a pci graphics card unless you have dual pci-express slots on you motherboard
Feb 24, 2011 | E-Machines eMachines Desktop PC
Emachine computer
Make sure you have all driver installed. Run a FREE scan at least to know what you are missing using Driver Detective you don't have to buy it, they let you run a free scan.
Also, assuming that your CD reads (like when you play music CDs) you may have to install a good program like Nero or Roxio.
Apr 09, 2010 | E-Machines eMachines Desktop PC
Connect leads to motherboard
the red and white leads supply power and from the picture they plug in the middle of the right side. white connecter.
Aug 13, 2009 | E-Machines eMachines Refurbished EMA...
Dual Channel on an Emachines T5082
Look closely at the BOLD print
Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
Apr 17, 2009 | E-Machines T5082 PC Desktop
Not sure if this is a good choice for me...
Not sure what type of graphics card it has but if it cannot support the dual monitors you can buy an additional card that does.
Mar 28, 2009 | E-Machines eMachines Desktop PC
Can u possibly tell me where i might be able to download a schematic for an EMachine desktop computer model #T2742? It is out of warranty and was donated to our church and we need to know where to...
Hi dallasblue08,
Here's a diagram of what your looking for:
The following eMachine models share the same motherboard (and thus the same front panel layout):
T2742 T2796 T2798 T2824 T2885 D2823 T2862 T2896 T2898 T2958
Hope this helps!
Mark
Jan 04, 2009 | Computers & Internet
Emachines problem... PSU works but comp doesnt turn on
Hi, Did you just add the second CD? If you did you may need the driver for the mother board? Make sure the power cord for the cd has voltage plug it into the DVD drive also check the cable make sure red stripe is on the correct side of drive. You can download the driver at http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T2672 User guide is there as well. The start button has a pair of wires with a small pin connector on it. This will connect to the motherboard if there is a 3 pin set you might try moving to the other pin. The new power supply also has to provide a start voltage? Your power supply may not be compatible or it may put the voltage on the third pin.
Aug 22, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
109 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
