Acer Aspire One not starting
Thanks for your reply.
The battery has already been removed, in fact I work on adapter most ofthe time, without the battery. The problem occurs while running onadapter.
How does one reset the Ram?
    Scholar:
  • 121 Answers
There is a small portion under the notebook that can be opened ...it has a pic ok ram on the opening lid most of the case.....remove this lid....have the battery out of the notebook.....remove the ram by uncliping the ram of the side clips......and than put it back the same way reboot and test
hope this works out for you
Cheers
Posted on Nov 16, 2008
Acer aspire 5100 when a laptop does not start with power plug on and no battery what could be the issue
Do you have a voltmeter? The first thing I would check is to see if you are getting 19VDC coming out of the charger. The on then off when you have the battery in sounds like your battery is almost out of juice and the fact that nothing happens when you plug it in without the battery indicates to me that your power adapter is not working.
Jan 31, 2017 | Acer Computers & Internet
Acer aspire 2920 no power at all,,, even i use adapter or batery its already no power also,,,please help me
You may need to replace the adapter, THIS is only the first step.
IF the "new" adapter doesn't fix it, then you should remove battery, and try it again.
IF this fixes it, try the original adapter, without the battery, if it works, just us the laptop with only the adapter and purchase a new battery.
Hope this helps.
Dec 09, 2013 | Computers & Internet
The Acer 5315 notebook I have will not power up. It is plugged in and when I press the start button, the power light is on for about 2 seconds and then it shuts down. I removed the battery and it will not...
most probably it is the motherboard. try to turn on the computer using the ac adapter without the battery. if the problem is the same, the motherboard is already defective.
Jun 11, 2010 | Acer Aspire 5315 Notebook
I have an Acer aspire 5050 and when i try to turn it on i hear the fans starting but nothing hapens on the screen. i tried to conect it to a pc monitor but it didn't work. I think there isn't any video...
hello gligor,
try this.
Turn Off Laptop
Remove the Power Adapter Pin
Remove the Battery and leave the Laptop Idle without Power n Battery for about 2-3 Hours
Fit the battery again and connect Power Adapter and try again
Feb 04, 2010 | Acer Aspire 5050-3242 Notebook
I need a Replacement Notebook Battery for Acer Aspire 7520-5757 11.1V 4000 mAH Can I use a Replacement Notebook Battery for Acer Aspire 7520-5757 that has: 14.8 Volt 4400 mAH Will the volt...
No, you should NOT use a battery with different voltage. It may not fry your computer, but it will certainly not work/charge properly.
But it seems impossible, that two batteries of the same symbol have different voltages - one is 3-cell type (3x3.7V lithium cells) and the other is 4-cell (4x3.37V). This usually means, that the second battery will be physically larger (4 groups of cells instead of 3).
If your original battery reads 11.1V, then it's most probably the correct voltage - perhaps there's a typo on the website? Try to consult them so they double-check the specs of this battery.
Jan 31, 2010 | Computers & Internet
Sir, i have bought a acer laptop model aspire 5920 but when i was working on it suddenly it shut down and till now i cannot made it power on can you tell me the problem
Remove the battery and the power adapter, wait 5 minutes, plug in the power adapter and try turning it on, if it doesn't turn on, remove the power adapter, plug in the battery and try starting up again, if it still doesn't work plug in the power adapter, try starting up.
Is the power adapter working? does it have a green led on it that shows that its powered?
Sep 10, 2009 | Acer Aspire 5920 Notebook PC
My Aspire 5315 will not start
I actually contacted Acer by email for this and got a reply in less than a day.
Try the steps below for a power reset, to eliminate a hardware problem with your notebook:
1. Disconnect the AC adapter from the laptop.
2. Remove the battery.
3. Press and hold the power button for about 30 seconds then release it. (You will not see anything happen)
4. Connect the AC Adapter to the laptop. Make sure the AC Adapter is plugged in.
5. Turn the computer on as normal.
6. Once Windows boots, insert the battery.
If the notebook still does not power on, we recommend the notebook be serviced by our authorized repair depot. You can set this up for service yourself by going to www.acerpanam.com; click on the link for Depot Repair. If you are out of warranty, or you would rather do this via phone, please contact Acer Technical Support at 1-800-816-2237, Mon-Fri 7am-9pm CST and Sat-Sun 8am-5pm CST excluding holidays. For out of warranty products please call 1-866-621-2237. Hours of operation are 7am-8pm CST, Mon-Fri, and Sat-Sun 8am-5pm CST excluding holidays.
Dec 17, 2008 | Acer Aspire 5315 Notebook
Acer Aspire 5100 Red Battery Light
The Aspires should have no issue booting without the battery installed. Have you done a static reset? (i.e. hold the power switch for 20/30 seconds without power or battery in) And the voltage range on the Aspire 5100 should be +19v - +20.5v on the inner part of the connector so it might be worth checking that the power adapter is outputing correctly.
If it works without battery, then it can be checked by testing the voltage between pins 1 and 6 on the battery (the ones either end) and should be 7.5v or above if the battery is charging correctly.
Hope that gives you a starting point, if you've done all those things already then appologies and best of luck with it.
Dec 10, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 3000 keyboard failing
The problem is the battery as mentioned before. Disabling "Microsoft ACPI-Compliant Control Battery Method" should solve the problem of the keybord and the mouse, this is, because the driver dosen't work properly with a bad battery. I think it fires a lot of hard interruptions that are blocking the keybord and the mouse interruption to the system (each time a key is pressed an interruption is send to the processor... if the battery driver sends a lot of interruptions, the key interruptions don't have time to be processed in time - that explains the fact that the system responds to a key press is that bad)
Apr 06, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
676 people viewed this question
David Payne
David Payne
