Require TV code to program cable TV remote to operate TV
TV code information is not in TV manual that came with set.
Sylvania model LC195SL9
  • 5 more comments
  • richardroste Nov 14, 2008
    The remote control I want to program is a Verizon Fios TV remote control Model RC144 5302/00B
    None of the submitted codes worked to turn off the TV with the power button.
  • richardroste Nov 15, 2008
    No luck, the new codes did not work.
    I have been using the identical procedure entering the codes.
    Non of the codes you gave worked.
    Are there anyother codes I should try to program the remote to the TV? Codes tried 0807,0002,0502,0115,0520,0919,0324,0247,0402,0408,0109,0715,0717,0054,0030,0171,0057,0081,0198,0205,3005,3006,3018,3042,3082,3095,3099,3105,3139,3161,3186,3192,3196,3210,3218,3221,3229,3235,3236,3237,3245, and 3246
    I had already used the procedure they recommended to find a code on Verizon's site. It did not work.
    I had previously emailed them at this site a week ago. They responded to the email without a solution or recommendation.
  • 728 Answers
If you can not find a code that works with your remote and tv, you may need to just buy a universal remote cheap and a code booklet will come with and it will give you code to try that will work with your tv, and they will tell you how to set the remote to let it work with your tv.
Posted on Nov 15, 2008
    Sergeant:
    Champion:
  • 283 Answers
These are the code for sylvanie tv 0054, 0030, 0020,and 0096. please dont rate me if not working.
Thank you for using fixya....
    Genius:
  • 1,913 Answers
    Scholar:
  • 112 Answers
I can't find any other codes. Your best option may be to contact the manufacturer and try toget it from them. There is the possibility that it got changed and they are about the only ones that could tell you.
  • Steve DiPolito
    Steve DiPolito Nov 15, 2008
    Of course there is always the option of getting another remote that is easier to deal with. This may be a better option.
  • 4,806 Answers
Here is the direct link to the support site@
http://www22.verizon.com/residentialhelp/fiostv/remote+controls/setup/setup.htm
    Scholar:
  • 45 Answers
Http://www22.verizon.com/nroneretail/nr/rdonlyres/0d93f875-4498-460f-8fc4-a15d519b4e7c/0/welcomekitremotecontrolinsrt_nc.pdf
check this user guide for your remote instructions on program codes as well as
this site for programmable codes on your remote for various tv's. Hope this helps
Posted on Nov 14, 2008
  • 1,879 Answers
Verizon Fios TV remote control ain't good.
Get a universal remote with learning capabilities.
Try iconRemote control
http://www.remoteshoppe.com/index.php?itemid=396
  • monk3ybidzness
    monk3ybidzness Nov 15, 2008
    Verizon Fios TV remote control does not work well with a lot of TV's.
    President:
  • 2,712 Answers
Turn on your TV.
4. Press and hold the TV key.
5. While holding down the TV key, press the OK key.
6. Release both keys. The Device Keys will blink twice.
7. Enter the 4-digit TV code you circled. The TV key will blink 3 times.
8. To test to see if this was the correct code, point the remote at your TV and press Power. If the TV turns off, you have successfully programmed your remote.
9. If the TV did not turn off, repeat all the steps with the next code in the list.
10. For future reference, underline the code that worked for you.
Note: If some of the keys on the remote do not operate your TV as you would expect, then try the next code in the list for your brand of TV.
These are the codes:
0057, 0081, 0198, 0205, 3005, 3006, 3018, 3042, 3082, 3095, 3099, 3105, 3139, 3161, 3186, 3192, 3196, 3210, 3218, 3221, 3229, 3235, 3236, 3237, 3245, 3246
This manual will give you ALL details:
http://www22.verizon.com/Content/CommonTemplates/Includes/download/Philips_Remote_Manual.pdf
Hope that helps! Dont forget to ACCEPT this solution if it works :)
Cheers!
ID
  • Swilin Sampson
    Swilin Sampson Nov 15, 2008
    Go through the manual i posted. Its sure to help.
  • Swilin Sampson
    If none of the codes worked, try the following procedure:
    1. Turn on your TV.
    2. Press and hold the TV key.
    3. While holding down the TV key, press OK.
    4. Release both keys. The Device Keys will blink twice.
    5. Press 9 - 2 - 2.
    6. Point the remote at the TV.
    7. Press > (PLAY).
    8. Press >>. Every time you press >> the remote sends out a new power-off command to the TV. Keep pressing >> until the TV turns off. (You can press << to go back.)
    9. When the TV turns off, you have found the right code. Press OK to store this code.
    Note: There are over 300 TV and DVD codes. The most common codes are tried first, but you may still need to press >> over 300 times to find the right code. If you reach the end of the list of codes the entire remote will flash twice and return to normal operation. You can exit programming at any time by pressing Exit
    Genius:
  • 1,124 Answers
Try some of these 0054 - 0030 or 0171
    Genius:
  • 2,120 Answers
Same as FUNAI
  • Leroy Elliott
    Leroy Elliott Nov 15, 2008
    Hmm, now that I think about this:
    I have the same TV but no code I tried would shut off power either, maybe it's a bug. My mother has a FUNAI, it's the same exact TV as Sylvania, it won't shut off also. Bought both at Sears and didn't notice different brand names until I got them home and unboxed.
    Scholar:
  • 181 Answers
Try out 19834432.
or
0967854.
and the fourteen digit code is
34254367685993.
try it and reply.
thanks.
  • 6 more comments
  • fixyy Nov 14, 2008
    if it four digit code
    6754
    or
    3267
    also check this digit code for reset
    543
    or
    887,
    or
    321
    try it and reply.
    thanks.
    If you want the Power Key to control multiple devices at once…
    1. Press and hold the STB key.
    2. While holding down the STB key, press OK.
    3. Release both keys. The Device Keys will blink twice.
    4. Press 9 - 7 - 7. The STB key will blink twice.
    5. One after the other, press each Device Key you want the Power Key to control, in the order you want them to turn on or off. Each selected Device Key will blink twice after it is pressed.
    6. Press OK when done. The STB key will blink three times to indicate success in programming.
    For example, to program the Power Key to turn on or off your TV, AUX and
    STB, in that order with one press of the Power Key, press [STB+OK], [9-7-7],
    [TV], [AUX], [STB], [OK].
    Factory Reset
    To reset the remote to the original factory defaults:
    • Press and hold the STB key.
    • While holding down the STB key, press OK.
    • Release both keys. The Device Keys will blink twice.
    • Press 9 - 0 - 0. The STB key will blink 3 times to indicate success in programming.
    Cheers!
    the last option is calling the service center .
  • fixyy Nov 15, 2008
    If none of the codes worked, try the following procedure. (As before, we will use the example of a TV. For other devices use the appropriate Device Key instead of the TV key in step 2 and 3.)
    1. 1. Turn on your TV.
    2. 2. Press and hold the TV key.
    3. 3. While holding down the TV key, press OK.
    4. 4. Release both keys. The Device Keys will blink twice.
    5. 5. Press 9 - 2 - 2.
    6. 6. Point the remote at the TV.
      1. 7. Press the forward key >
      2. 8. Press -->>-- this arrow key Every time you press-->>--- the remote sends out a new power-off command to the TV. Keep pressing--->>--- until the TV turns off. (You can press this key ----<<---- to go back.)
    9. When the TV turns off, you have found the right code. Press OK to store this code. Note: There are over 300 TV and DVD codes. The most common codes are tried first, but you may still need to press--->>--- this key over 300 times to find the right code. If you reach the end of the list of codes the entire remote will flash twice and return to normal operation. You can exit programming at any time by pressing Exit.
    if this solution helps u please rate the solution.
    thanks.
    Codes for Televisi
    Abex 3026
    Admiral 0120, 0490, 3001, 3027
    Advent 0788, 081
    Adventura 3028
    Aiko 0119, 3009
    Aiwa 3195 0057, 0087, 0699, 0729, 0839,
    3002, 3182, 3219
    Albatron 0727, 0870
    Alleron 3013
    America Action 0207
    Ampro 0778
    Amtron 3012
    Anam 0207
    Anam Naal 3003, 3012
    AOC 0057, 0205, 3004, 3005
    Apex 3117, 3189 Apex Digital 0183, 0775,
    Audiovox 0119, 0207, 0478,
    0902, 3012
    Aventura 0198
    Belcor 0205
    Bell & Howell 0181, 3001,
    Benq 1059
    Bradford 0207, 3012
    Brillian 3227, 32
    Brockwood 0205
    Broksoni 0207, 0263, 0490, 3182, 3204
    Candle 0057, 0205
    Carnivale 0057
    Carver 0081
    Celebrity 0027, 3002
    Celera 0792
    Centurion 3007
    Changho 0792 Citizen 0057, 0087, 0119, 0205, 3005, 3006, 3009,
    3203
    Clarion 0207
    Colortyme 0205, 3005
    Colt 3199
    Commercial Solutions 0074, 1474
    Concerto 0205, 3005
    Contec 0207
    Contec/Cony 3008, 3012
    Craig 0207, 3012
    Crosley 0081
    Crown 3012, 3018 Cis Mat 0057, 0074, 0081, 0087, 0120, 0172, 0181, 0193, 0205, 0478, 0493, 0729, 1174, 1374, 3000,
    3005, 3015, 3022,
    CXC 3012 0119, 0205, 0478, 0650, 0688, 0699, 1688, 3004, 3005, 3009,
    3025, 3081, 3100,
    Daytron 0205, 3005, 3025
    Dell 1107, 1205
    Denon 0172
    Dimensia 3000
    Dumont 0044, 0205, 3024
    Durabrand 0198, 0205, 0207, 0490,
    Dwin 0120, 0747, 0
    Electroband 0027,
    Electrograph 1782
    Electrohome 0205, 3002,
    Element 3264 Eon 0181, 0198, 0205, 0207, 0263, 0490, 0650, 3005, 3008, 3010, 3011, 3012, 3013, 3015, 3025,
    3031, 3186, 3203, 3204,
    Envision 0057, 0205, 0840, 3005
    Epson 0860, 0867, 3144
    ESA 0198, 0839
    Fisher 0181, 3014, 3015 Fujitsu 0710, 0836, 0880, 3013, 3159, 3160,
    3162, 3163, 3164 12, 3013, 3198
    Funai 0198, 0207, 30
    Futuretech 0207, 3012 eway
    Gat1782, 1783 GE 0074, 0078, 0205, 0478, 1174, 1374, 1474, 3000, 3003, 3005, 3016, 3017, 3037, 3124, 3200, 3201,
    3208 0057, 0205, 3024
    Gibralter 0044,
    Go Video 0913 Goldstar 0057, 0205, 3004, 3005, 3008, 3025,
    3026, 3202 3013
    Grunpy 0207, 3012,1061
    Haier 3005
    Hallmark 0205,
    Harley Davidson 3198
    Harman/Kardon 0081 2
    Harvard 0207, 301
    Havermy 0120
    Helios 0892
    Hello Kitty 0478
    Hisense 0775 Hitachi 0172, 0205, 1172, 3005, 3008, 3198
    3039, 3044, 3180,
    HP 3253, 3254
    Hyundai 0876 3252
    Ilo 3249, 3250,
    IMA 3012 0081,
    Infinity 3018 3257
    InFocus 3255, 3256,
    Insignia 0198
    Inteq 0044
    Janeil 3028 0081,
    JBL 3018 JC Penney 0205, 3000, 3004, 3005, 3006, 3025, 3026
    3016, 3017, 3022, 0027,
    JCB 3002 en
    Jens 0205, 0788, 0842, 0844, 3005 JVC 0080, 0758, 1280, 3008, 3017, 3019, 3070, 3096, 3097, 3101, 3134,
    3174, 3175 3005
    Kawasho 0205, 3002,0207
    KEC
    Kenwood 0057, 0205, 3005
    KLH 0792, 0794 ovabem
    Kloss Na3012, 3028 Konka 3032, 3238, 3239, 3240, 3241, 3242,
    3243, 3244
    KTV 0057, 0207, 3012, 3025 LG 0205, 0727, 0883, 1205, 1292,
    3004, 3145
    Lloyd's 3198
    Loewe 3018
    Logik 3001 ma
    Luxn 0205, 3005 LXI 0074, 0081, 0181, 0183, 0205, 3005, 3015, 3018
    3000, c
    Magnasoni 3203 Magnavox 0057, 0081, 0205, 0733, 0829, 1281, 1481, 3005, 3006, 3018, 3046, 3047, 3056, 3098, 3102, 3212, 3218
    3154, 3198,
    Magnin 3200
    Majestic 3001 Marantz 0057, 0081, 0205, 0731, 0882, 18
    1181, 3005, 30
    Matsushita 0277, 0677
    Maxent 1782
    Megapowe 0727
    Penney 0062, 0064, 1062, 1264, 3885, 3886
    Philco 0062, 3806
    Philips 0062, 0108, 0645, 0766, 3806, 3820, 3861, 3876, 3898, 3899
    Philips Magnavox 3820, 3829
    Pilot 0064, 3805
    Polaroid 3858
    Polk Audio 0108
    Presidian 3861
    Proscan 0087, 1087, 3800, 3841
    Pulsar 0066
    Quarter 3803
    Quartz 3803
    Quasar 0062, 0189, 1062, 3806, 3882, 3894, 3903
    Radio Shack 3805
    Radio Shack/Realistic 3803, 3804, 3805, 3806, 3807, 3808
    RadioShack 0027, 3883
    Radix 0064, 3805
    Randex 0064, 3805
    RCA 0087, 0834, 0907, 1062, 1087, 3800, 3804, 3806, 3824, 3853, 3866, 3885, 3897, 3911, 3916
    Realistic 0027, 0062, 0064, 0074, 0075, 3803, 3804, 3805, 3806, 3807, 3808
    Replay TV 0641, 0643
    Ricavision 1999
    Ricoh 3810
    Runco 0066
    Samsung 0072, 0766, 1041, 3804, 3851, 3855, 3859, 3865, 3870, 3889, 3918
    Sanky 0066, 0075
    Sansui 0027, 1506, 3811, 3850, 3883, 3888
    Sanyo 0074, 3803, 3804, 3807, 3842, 3885
    Scott 0072, 0211
    Sears 0027, 0062, 0064, 0074, 1264, 3803, 3805, 3806, 3807, 3883, 3886
    Sharp 0075, 0834, 3814, 3821, 3830, 3881, 3890, 3911
    Shintom 3801
    Shogun 3804
    Singer 3806, 3810
    Sonic Blue 0641, 0643
    Sony 0027, 0059, 0060, 0062, 0663, 1259, 1999, 3801, 3809, 3815, 3816, 3819, 3834, 3856, 3857, 3862, 3864, 3873, 3877, 3883, 3919
    Stack 9 1999
    STS 3806
    Superscan 3904
    Sylvania 0027, 0062, 0108, 1808, 3806, 3808, 3861, 3896, 3904, 3910, 3913
    Symphonic 0027, 3808, 3812, 3861, 3883
    Systemax 1999
    Tagar Systems 1999
    Tandy 3803
    Tashiko 3805
    Teac 0027, 3808
    Technics 0062, 0189, 3806
    Teknika 0027, 0062, 0064, 3805, 3806, 3808
    Thomas 0027, 3883
    Tivo 0645, 0663, 0766, 2023
    TMK 3804
    Toshiba 0072, 0872, 1035, 1172, 1999, 2023, 3826, 3827,
    NEC 3802, 3803 0064, 3805
    Nikko
    Niveus Media 1999
    Noblex 3804
    Northgate 1999
    Olympus 0062, 3806 Optimus 0064, 0075, 0189, 1089, 3805, 3882
    Orion 0211, 1506, 3811, 3888 Panasonic 0062, 0189, 0252, 0643, 1062, 1089, 3806, 3813, 3817, 3823, 3831, 3839, 3860, 3872, 3882, 3893, 3894, 3895, 3901, 3902, 3907, 3909, 3912, 3914, 3915,
    Philips codes :----0216, 1216, 1293, 1296, 3636, 3698, 3749
  • 19,396 Answers
What kind of remote control are you using, please provide details on model.
Sylvania tv manuals model lc195sl9
http://www.searspartsdirect.com/partsdirect/user-manuals/lc195sl8-sylvania-parts-tv+lcd-manual [] Control Panel
POWER (pl 1)
Press to turn the unit on and off.
INPUT SELECT (pl 3)
5. SETUP (p11)
Press to display the main menu.
6. infrared sensor window
Receives infrared rays transmitted from the remote
control.
7. power on indicator
Lights up when power is on.
8. standby indicator
Lights up in standby mode.
May 02, 2014 | Televison & Video
Sylvania LC195SL9 19 in. LCD need a dis remote
hi! i have a couple of codes for your tv, just try them, 1145, 3095, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1150, 2092, 1464, 2408, 1465, 2260, 1046, 1465,
1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483, hope this helps!!! goodluck!!!
May 14, 2010 | Sylvania LC195SL9 19 in. LCD TV
My Sylvania model LC195SL9 A will not connect with Vista
The TV cannot support the video resolution that your PC puts out, you need to find out what the resolution the TV can do in PC mode, then set the video on your PC to that resolution.
Nov 11, 2009 | Sylvania LC195SL9 19 in. LCD TV
Need Sylvania program codes for (CRK59B)RCA
I have the manual for the RCA TV that the CRK59B came with. The Sylvania VCR program codes are 08, 29. If you're trying to control a Sylvania Cable -TV Box, the code is 11.
Aug 28, 2009 | Televison & Video
The codes that i have from comcast won't program my television to the dvr
Actually the codes you receive from the cable company are to be used for the cable remote. It allows people with most brands of televisions to use the cable remote to turn the TV itself on and off and to adjust the volume. If the codes you have don't work for your TV this just means you'll have to use two remotes: the TV remote for power and volume of the TV and the cable remote for everything else.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 11, 2009 | Sylvania LC195SL9 19 in. LCD TV
I need the RCA remote code for Durabrand tv
Since the Funai code does not work, you have to use the CODE SEARCH feature.
The remote may already be set up to operate your brand of TV, VCR, Laserdisc, Satellite Receiver, Audio Equipment, or Cable Box. It is pre-programmed with the following codes: TV-000, VCR1-000, AUDIO-003, and SAT•Cable Box-000. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using CODE SEARCH
1. Manually turn on your device (TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box or Audio Equipment).
2. Press and hold CODE•SRCH.
3. Press and release the device button you want to set up (TV, VCR1, VCR2•LD, SAT•CABLE, or AUDIO).
4. Release CODE•SRCH.
5. Press POWER repeatedly until the device turns off (you may have to press up to
100 times).
6. Once the device turns off, press and release ENTER.
7. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond,
repeat steps 1-7.
Programming Your Universal Remote
Nov 17, 2008 | RCA Universal Remote Control
RCR3273 Remote Control code for 8607 Scientific Atlanta cable box
These are all of the codes I have for the RCA universal remote.
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 24, 2008 | RCA Universal Remote Control
Televison & Video Logo
320 people viewed this question
Top Televison & Video Experts
Electro Med Services...
