Question about Jwin JD-VD736 Portable DVD Player with Screen
Martin reed slow and is too warm and bery hot.some time dont reed the menu
0 characters
1 Points
How make my dvd player play movies in color
Dear Laysia,
Maybe your DVD player and your TV are not set for the same TV transmission system. The TV system in U.S. is NTSC. TV systems in some countries in South America and Europe are of the PAL type. You have to check in the manual for your DVD and your TV which TV systems they work with . many of them are multisystem, but you have to check in their menu or settings if BOTH are set to AUTO or to the same TV transmission system.
Hope it helps!
Best regards,
Miguel Luiz Martins
Dec 28, 2011 | Kenwood DV-605 Multi-disc DVD Player
Has really slowed down dubbing - and disc is heated when removed, after only one dubbing and finalizing.
The speed of dubbing depends on the max writing speed of the disc used.
A disc always gets warm after using,the laser gets verry hot.
Jul 31, 2009 | Panasonic DMR-EH50 DVD Recorder
After 10 min. of play time the dvd stops working
This is most likely a problem with the power supply to the drive motor. A component is breaking down and the supply voltage is dropping below operational levels after warming up.This is a problem that needs service in a service center or someone who is a experienced electronic technician to take apart the unit and test it for bad components.Hope this help you with your problems.
Mar 18, 2009 | Polaroid PDM-0742 Portable DVD Player
Start time when turned on.Really slow
Jan 10, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Panasonic DVD-S31
have you ot it setting on something warm or hot like a subwoofer to surround sound or on top of a tv even if you had it there before and it worked they get older and cant take heat as well and they get dust built up in them alot of times one freezing or shutting off is getting to hot is it doing it right when you turn it on if so try unplugging it for a few hours then plug it back and try it
Feb 06, 2008 | Panasonic DMR-ES10 DVD Recorder
Pinoeer DVD-366
Hi there, just got that progresive problem gone :D
- Startup ur DVD (ON)
- Wait until Loading - No Disc (status on DVD display)
- In here, ur screen still blank (black screen)
And here's how:
- Press "Home Menu" button
on ur DVD (it should be on the down left of the circle button)
-- Watch out, the screen still in blank, just feel it right ok?
- Down 2x -- Initial Setting
- Menu / Ok (the circle button)
- Down -- Video Out
- Menu / Ok
- Down -- Component Out
- Menu / Ok
- Down -- It will choose Interlace, it will saved the day :-)
- Menu / Ok
That's it.. Cheers mate ^^
Give me a mail if u still have the problem, coz I Know how it sucks.
Dec 02, 2007 | Pioneer DV-366K DVD Player
DVD must be overheating
General failure when units warm / hot in high humidity environments. Units operate normally once cold, failure only occurs occasionally then seems OK but when warm fails again
Many PCB's/components have contamination which will manifest themselves in warm and humid environments, so once unit is warm then electrical failure occurs. Clean circuit first in solvent/water combination and retest unit. Failure should dissapear. If corrosion found on joints then reheat with soldering iron which you may see joints bubble then clean PCB thoroughly. Best to soak in cleaner then wipe around with lint free wipe especially around powered components. NOTE contamination is typically hygroscopic and will attract moisture if particularly bad will electromigrate if not too bad then poor SIR Surface Insulation Resistance (occasional unexplained failure) Could go on for long time but this is only the start! Does this sound familiar to anybody ??
Nov 24, 2007 | Sansui VRDVD4005 DVD Player/VCR
Won't spin DVD - says OPEN (top right) on TV screen
Just got a coby dvd-207 for free due to this problem, fix takes about 5 minutes.
Tools needed:
1 small philips screwdriver
1 toothpick
1 bottle of rid-ox, deoxit, or similar contact cleaner and restorer
1) remove the two rubber feet on bottom of case that have arrows pointing at them
2) remove 6 screws that have arrows pointing at them
3) carefully open case, there are wires connecting both halves, leave them connected
4) press open button, so that the disc receptacle is open
5) look for a gear on the inside near the back of the case that is connected to the dvd door, there should be a cheap reed switch mounted near it
6) clean the cheap reed switch with a toothpick dipped in rid-ox/deoxit/etc
7) re-assemble, plug it in, and watch movies for another few months until the reed switch decides to stop working again
The next time it goes out, i am just going to cut the two wires to the switch and either cross them over or install a mini-toggle switch on the side of the case..
Nov 04, 2007 | Coby DVD-207 Portable DVD Player
Jwin JD-VD736 Portable DVD Player with Screen Logo
23 people viewed this question
Top Jwin DVD & Blu-Ray Players Experts
Jaime Hernandez
Raj Patel
Are you a Jwin DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
