Question about RCA F27242GY 27" TV
Tv was working fine...then shut itself off.
Tv was working fine then shut itself off. when i tried to turn it back on, it clicks 2 or 3 times and does absolutely nothing. i unpluggec it for 30 min and tried again with nothng but clicks. is there a reset button or something on this set. if it was caused by a power surge or something, can't i just reset it? please help...thanx...
  • DebbA3 Jan 13, 2008
    We have an RCA tv that tries 3 times to click on and off, and then just turns off. We cannot turn it on with the remote, or with the power button... it just clicks 3 times as if it's trying to turn on with each click, but doesn't ever turn on.
  • RCA Master
  • 5,138 Answers
There is no reset button on any tvs that stop in 1980s when they no longer used tubes in chassis,s now the only tube is your picture tube. you probly have a shorted hori out put transistor.
Posted on Jan 19, 2008
SOURCE:
Toshiba 46g310u turns off and on by itself
The problem is a voltage dip. I can reproduce this on the same model TV by turning on the A/C or the oven and dryer at the same time. As soon as I hear the thermostat click on the TV shuts off. Just order a voltage regulator today, will see if that works.
May 28, 2014 | Toshiba 46G310U LCD TV
Tv randomly shuts off
next time it shuts down and power light goes out--do the self check.
On front of set press and hold BOTH MENU AND INPUT BUTTONS FOR AT LEAST FIVE SECONDS AND RELEASE BOTH BUTTONS.
Power light (if an error is detected) will blink a two digit code.
Most common is 2 blinks, pause and 2 blinks---set if there is a error code will repeat it at least 5 times.
If you detect a error code, let me know and I will tell you what it means.
SD TECH
Jun 24, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Sylvania LD320SSX turns off by itself.
your powersupply is dying in the set.. have it checked..
Apr 10, 2010 | Sylvania LD320SSX LCD TV
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Lcd sanyo
Could be main or power board
Dec 30, 2017 | Sanyo DP23625 23 in. LCD Television
TV turns off by itself
you have a bad CRT causing the set to shut down. after the CRT has cooled down the computer finds all value to be ok then comes back on....
Jan 07, 2008 | Philips Magnavox 24MC4306 24" TV/VCR/DVD
RCA F27242GY 27" TV Logo
70 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
