Protect light is on
I have a hitachi 50dx01b and the protect light is on. i open the back and when you plug it up the green light onthe board will come on and then die out and the protect light will come on in pin 915R can any one help with this
  • mastertdog Nov 30, 2008
    how do i know what to look for and how do i check a surge protector
  • 4,806 Answers
Remove power at the wall and leave for an hour, hopefully this will reset the TV.
Posted on Nov 30, 2008
  • Lee Hodgson
    Lee Hodgson Nov 30, 2008
    would suspect the ballast, but try these first:
    Causes:
    Cause #1
    1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2.
    Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB,
    if missing check for an open F9A09 on the Power PCB, if it is open
    replace F9A09 part # 283P127060 and the Light Engine part # 939P977010
    3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector
    pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and
    C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part #
    930B921002) 4. At power on the lamp turns on and off three times and
    then the unit shuts down with a red lamp LED (lamp error). Replace the
    Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does
    not switch to 5 volts after turn on, 12 and 5 volt supplies are good.
    Suspect the Light Engine part # 939P977010 6. Lamp enable line at
    connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after
    turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt
    supplies are good. Suspect the Lamp Power PCB (ballast) part #
    939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine
    Driver PCB switches to 5 volts after turn on but does not go back to
    0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect
    the Light Engine part # 939P977010. Good Luck
    if no joy here is the repair web address:
    http://www.tvrepairman.com/brands/hitach...
    kind regards
  • 10,594 Answers
Mostly protect light becomes ON when TV got problem in deflection section, especially in Horizontal deflection and Convergence out area.
Your should check horizontal output transistor, fly-back transformer and convergence ICs, IF you have experience of TV repair.
Please obtain related service manual form any service manual on-line store to rectify problem properly.
Posted on Nov 29, 2008
    Genius:
  • 1,550 Answers
The protect light is coming in your tv because any of the components like fuse , resistor ,capcitor is blown . You need to inspect this parts and replace it .
  • 19,396 Answers
You need to get the service manual to fix this:
Service Manual HITACHI 50DX01B
I will be offline for few hours, I can give more support when I come back online.
  • Ginko
    Ginko Nov 29, 2008
    You can ask also help from the other expert, that is well known for being a tv repairer.
    Thanks for using Fixya.
  • Ginko
    Ginko Nov 30, 2008
    Unplug the TV and the 915R surge protection unit from power, and plug them back after one hour or so, Try to bypass the surge protection unit and see if this was the problem.
    The surge protection unit should not be taken apart for safety reason, the 915R allows a maximum of 125 VAC, if there had been a bad voltage from AC network, that can have been the cause that started the protect light.
    Leave the surge protector unplugged few hours, and then connect it to a different socket, if it works, the only problem that you can possibly have are concerning the AC socket.
  • 13,433 Answers
You need to buy a service manual to help you with the repairs.
Hitachi 42hds69 green light does not go on
Protection mode, either PSU failing on caps or transistors, defective AV board, or dead inverter.
Jan 16, 2013 | Hitachi 42HDS69 42 in. Plasma Television
Where to find a rf connector hp00351 for hitachi 50dx01b
I doubt that rf pack is available; a good idea might be to input signal to one of the sets of audio/video jacks via a cable box or even an old vcr to bypass a broken or defective connector.
Feb 05, 2012 | Hitachi 50DX01B 50" Rear Projection...
Picture will not come on
A few questions and a suggestion:
Do you get sound? Does power light stay on?
suggestion:
Unplug set and remove back cover---set will have several green led lights on board in power supply and one red one.
Red one should be on. While looking from the back have someone turn set on---note if all the green led lights come on and if one or more go off before the others you have located your problem.
The green LED's monitor voltage sources in the set's power supply.
I have more ideas but need more info from you.
If this helps rate this solution as very helpful as I do this here for free.
SD TECH
Aug 18, 2010 | Hitachi 50DX01B 50" Rear Projection...
We are seeing green and pink upper left corner and today it looks like double vision
There's a possibility that you place your tv set in a strong magnetic field. eg. large electric motor. speakers. try reposition your tv set
Jun 26, 2009 | Hitachi 50DX01B 50" Rear Projection...
Hitachi 50UX26B
Good day, seanhanna;
Hitachi has LED’s, green ‘lights’ and a red light to determine what circuit may be the problem; after removing the back of TV, bottom only, plug TV back in and observe which LED’s come on …..BUT most important which LED’s don’t come on; locate and note number, EG; DP37 and etc.
Good luck, big IRISH. Ps let me know.
Jul 12, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 60"(60sbx78b) Will not power on, fuse still good.
Matt, Hitachi`s have a series of green LED`s and one red LED on the main board, un-plug the tv for 30 seconds and then with the back cover removed plug the set back in and watch the led`s while someone else turns on the set, usually the led`s will temporarily light then one or more will immediately go out and then the rest will slowly go out and the red one will then start blinking, each led is a power supply indicator, 130 volt, 12 volt, 5 volt etcetera, find out which one(s) going out first and get back to me, BMW Rider
Jan 04, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
