Question about KDS Valiant 6380iPTD-01 Notebook
Vaillant eco tec pro 28
My boiler is showing fault f.28 and will not ingite
please help
  • 1 more comment
  • r_smith Nov 14, 2008
    its a vaillant condensing gas boiler, it is showing problem with ignition, it won't fire up
  • superdoodie May 22, 2009
    ive had my gas meter changed from quaterly to card meter. now my boiler is showing a red light and has a error code f.28
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    boiler? what do you mean?
  • 104 Answers
IF the weather is extremely cold, and you're getting F28, the external pipework may be blocked with ice. Warm up the external pipes (lag them if you can) - and now see if your boiler will re-ignite.
A friend fixed our condenser boiler with this tip - hope it helps you.
Posted on Jan 09, 2010
  • nick-geek Dec 22, 2010
    This happened to me, in the end I cut the condensate pipe outside to release the water, all now working, just need to fit a joint on the pipe!
Ignition fault,
you either have no gas or there is a problem with the electrode or gas valve probably
Posted on Dec 13, 2008
  • 13 Answers
Could be a gas supply problem, as F28 is an ignition failure. Common due to the restrictive 15mm gas isolation valve, which actualy reduces down to 8mm inside. Get Transco to check the gas coming into the property
Posted on Mar 03, 2009
  • KDS Master
  • 4,806 Answers
Don't try messing with gas appliances, you need to get a registered gas engineer to come and have a look because it sounds like the coil has gone so the ignition won't work, please don't mess with it yourself because of the safety issues involed
be safe!!!
Posted on Nov 14, 2008
Its either no gas pressure, or its an expensive repair.
If you can get it done on insurance do that.
If not get a new boiler, your problems are only starting with with eco tech or any vaillant.
Posted on Feb 03, 2010
This fault appeared a few times when I ran out of gas, then when you top up, you may have to open the gas supply a few times before it kicks in again. Usually there is an audible pop, when your gas flows again.
Posted on Jun 04, 2012
Vaillant eco PRO 28 gas boiler stopped working
You need to replace the thermal couplerhttps://youtu.be/jDvo4yJ1OdE
Nov 26, 2016 | Water Heaters
My boiler got 108 code error
ariston boiler error 108 - industrial steam boiler manufacturer
www.zgboiler.xyz/ariston-boiler-error-108/
Dec 16, 2015 - Free repair help - ariston clas he system error code 108. ... HE and I turned the yellow and two black levers/taps under my boiler and it started ...
Water pressure low in boiler no hot water or heating ' Screwfix ...
community.screwfix.com > ... > Plumbers' Talk
Sep 29, 2014 - My boiler stopped working yesterday morning. Water was not getting hot. Checked boiler (ARISTON CLAS HE 24) says error with code 108 ...
I have an Ariston CLAS HE boiler which is showing err108.
www.justanswer.com > Plumbing
Get a Professional Answer ... I have an Ariston CLAS HE boiler which is showingerr108. ... The error codes are on page 32. .... My oil boiler leaks a little. Is it a ...
Inside look of Ariston boiler error - Boiler service North ...
? 1:42
https://www.youtube.com/watch?v=dWonQltUnGI
May 14, 2012 - Uploaded by unicuk
The boiler is not firing up to give neither hot water nor heating. It tries to start ..you can hear the fan running and ...
Ariston Clas He Boiler Error 108 - saetechnologies.com
www.saetechnologies.com/ariston-clas-he-boiler-error-108/
Feb 28, 2015 - Search for - boiler, error, 108: Hi did you get to find out how to Fix ... Checked boiler (ARISTON CLAS HE 24) says error with code 108 ... Not sure if this is the best forum but I have a fault (F12) on my Glow Worm CXi30 boiler.
Dec 26, 2015 | Water Heaters
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
How do I fix a fault
Not a problem. I have noted that the F4 Ignition fault you are getting is with a Glowworm 18si boiler.
This relates to the burner system and will need a gas licensed technician to fix it.
I am providing you reference to an Installation and service manual to help you understand the likely fault but under no circumstances is this an invitation to attempt to fix the fault unless you are a qualified gas technician. Refer page 37 in the manual.
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Glow%20Worm/24ci-18si.pdf
Aug 13, 2014 | Dishwashers
My Smartfit room unit is showing no fault codes but boiler wont cut in I have no power at PL in control box or at L on boiler
Boiler make and model????
To which control box do you refer? The system junction box? Boiler junction box?
No power at L (line?) on boiler (and this is why the make and model is important) means boiler should show no signs of life at all, but then it's boiler specific, some have 3 wire power (L,N,E), others have an extra terminal called something like SL.
Jan 21, 2013 | Heating & Cooling
I have a vaillant eco tec pro boiler and the pressure guage is showing zero and boiler not working, is there a simple fis ?
Refill system with water to 1bar bleed rads refill again to 1 bar , there should be a filling loop to do this with.
Oct 23, 2012 | Grilling
Manual for a Vaillant combi boiler, ecoTEC pro28
my eco tec wall mounted boiler cuts out after about 10to15 days this unit was fitted in august this year
Sep 29, 2010 | Heating & Cooling
Hi my vaillant eco tec pro shut down last night showing fault f.28 and will not ignite today 08/01/2010 looked out side to see the condenser pipe was frozen i defrosted the pipe but boiler still wont...
Got exactly the same problem with mine. Manual says f28 = fault in gas supply, gas pressure too low. Boiler will ignite but goes out within minutes? HELP!
Jan 08, 2010 | KDS Valiant 6380iPTD-01 Notebook
KDS Valiant 6380iPTD-01 Notebook Logo
10,918 people viewed this question
Top KDS Computers & Internet Experts
Michael
Michael
Gary Finch
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
