Question about Cameras
That 'durn' memory card contact spring.
Before I try your excellent advice out, I gotta know if the little brass/metal clip down the slot on the rightside near the bottom is what is out of whack! It looks to be at some weird angle and I'm wondering do I bend it toward the insides of the camera as opposed to the battery side of the slot.
It's approx. 1/8 of an inch in length.
Oh, and thanks...
Here's a web-page I put up - http://fire.prohosting.com/manisask/dct50gateway.jpg - with a basic drawing of the camera parts concerned. I don't know how to do the unsoldering/soldering work you recommend. But, maybe I can just get the sensor out, that is, just as long as I know what the sensor is and where it is.
The drawing is of the back of the camera where the circuit board fits right up against the camera's body that has been unscrewed from its insides. The printed wiring has been 'un-plugged' from its receptacle.
The memory card slot's shield is more accessible now, yet only if you know what I'm looking for, and where?!
I can now see the 9 contact pins for the card to be read from each of its brass/metal tongues (contact springs).
There's a brass clip at an angle - is this the sensor?
The bottom drawing is the memory card slot shield with part of the slot's insides revealed.
In the memory card slot on the rightside at the bottom is the clip that sticks out at an angle. I don't know if this is bent out of normal configuration, or what??
Thanks for your time...
Posted on Nov 16, 2008
    Champion:
  • 225 Answers
As you can see on the memory card, there is a hole where the lock button slides back and forth. The camera is thinking that the memory card is locked, until the the camera's sensor finds the empty hole in the card. You will probably have to take the camera apart, unsolder the memory card shield, then examine how to repair or trick the memory card sensor. If that is not possible for you,, then I would just remove the sensor by digging it out. Logical output for that sensor should be no signal for the unlocked position anyways. Using the lock feature would no longer be possible then.
Posted on Nov 15, 2008
ASUS N56VJ BEEPING
Saltrock the beeps you hear are BIOS Beep Codes
The computer's way of telling you something is wrong, and an area to look into for it.
The beeps come out in a code
May be a long beep, then a pause followed by 2 short beeps.
May be 2 short beeps, a pause, then it beeps 2 short beeps, pause, and all over again.
You get the picture
Now in your best recollection just state the facts sir...............
What?
I mean what beep code so you hear Saltrock?
Post back in a Comment.
While I wait.............
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
(If you have the laptop hard wired to your router, unplug the cable from the laptop)
2) Laptop closed turn it over, Battery Compartment facing Away from you.
Remove the large panel on your side. Looks to be one single Philips head screw to remove/loosen.
Lift the Harddrive/Ram Memory Compartment Panel, up on the screw side at an ANGLE.
There are TABS on the panel on your side, that go into the Base Enclosure. (Bottom Cover)
Move the panel a little towards the Battery Compartment, and remove.
The Ram Memory module/s ('Stick') are held in by two spring clips on each side.
Closer inspection will reveal the spring clips have a protrusion, or 'Bump' on them.
These bumps fit into Side Notches, in the Ram Memory module.
Simply ease one spring clip to the outside. Be gentle.
The spring clip only needs to move far enough, for the 'bump' to clear the Side Notch.
Now do the same for the other spring clip.
When both spring clips are eased to the outside, the Ram Memory module will 'spring up' a little bit.
The BODY of the Ram Memory module, is everywhere on it, EXCEPT the gold plated contact pins on the bottom.
The Body is coated with a see-through protective plastic.
Handle the Ram Memory module by the BODY.
See the angle that the Ram Memory module popped up to?
Remove the Ram Memory module AT THAT ANGLE.
Reinstall the Ram Memory module at the same slight angle.
Failure to comply, can damage the gold plated contact pins on the Ram Memory module, and/or the contact pins in the Ram Memory slot.
When reinstalling insert at an angle, and fully inserted into Ram Memory slot. Then gently press down on the side that is tilted up; until the spring clip bumps pop into the Side Notches. (Of the Ram Memory module)
Note that there is a Locating Notch, on the Bottom of the Ram Memory module. (Where the gold plated contact pins are),
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
Make sure you line the Locating Notch of the Ram Memory module, up with the Locating Lug in the Ram Memory slot.
The Ram Memory module only goes in ONE direction.
What I would like you to do, is remove all Ram Memory modules, and clean the gold plated contact pins.
Use a pencil eraser.
If you are using an eraser on the end of a pencil, and not a solid eraser; refrain from letting the metal band of the pencil, touch the gold plated contact pins.
Rub back, and forth; and up and down. Clean EACH gold plated contact pin. BOTH sides. Doesn't take much pressure, nor rubbing to clean them.
Doesn't take much 'corrosion' to make a bad contact, either.
(Corrosion in marks because Gold isn't supposed to corrode.
Just my term)
When finished use air to remove the eraser dust.
If a can of compressed air for computers is available use it.
If not air pressure from your mouth will be sufficient.
Reinstall the Ram Memory module/s.
Reinstall the large panel cover.
Reinstall the Battery.
Reconnect the AC adapter, and then plug it into power.
WAIT 1 minute, turn the laptop on.
Still no?
I await the BIOS Beep Code then.
Asus Support > Asus N56VJ series of Notebook PC > Downloads page,
http://support.asus.com/download.aspx?SLanguage=en&m=N56VJ&p=3&s=390&os=36&hashedid=2W6oktGQFZdwZ7cP
Scroll down. Click on the blue + sign, next to the blue Manual (4)
Scroll down to Version E6951
To the right of - Download from,
click on the Blue -> Global
This is a PDF file. It is also the User Guide.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on Global it may take up to 30 seconds, before the first page comes up.
Go to Page 64 - Locating the hard disk drive
Shows you the panel to remove, and where the screw is located.
Page 66 - Memory (RAM) does not show you the panel, nor screw.
Regards,
joecoolvette
Feb 06, 2013 | Unknown ASUS N56VJ-WH71 15.6" Premium...
How to open casing and upgrade the RAM in Gateway LT2811u?
A) No, the case does not lend itself for easy access to the Ram Memory.
B) 'Other site' is full of beans. Impossible to replace, or upgrade the Ram Memory? Must not be a professional product support website, and does not have computer techs.
1) Work on a table. If the table is on a carpeted floor, refrain from swinging your legs. Observe Anti-Static Precautions.
[ Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
With a desktop computer you can relieve your body of Static by;
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
No such luck when working on a laptop/notebook/netbook/tablet.
An ESD wrist strap should be worn, and it's alligator clip connected to a good ground source.
{ Average cost of a Electro Static Discharge wrist strap, is around $3 to $6.
Example,
http://www.radioshack.com/product/index.jsp?productId=2103245
(It isn't just a piece of wire connected to an alligator clip, and to your wrist. The wrist strap has a metal plate which contacts the skin of your wrist. The metal plate is connected to a 1 Mega Ohm resistor, which in turn is connected to the wire going to the alligator clip,
http://en.wikipedia.org/wiki/Antistatic_wrist_strap )
I connect to an unpainted surface, of the metal frame of an open, Empty desktop computer case ]
It may be argued that you are just replacing Ram Memory, and an ESD wrist strap is not needed.
In this instance I will agree.
There is a metal static shield under the Keyboard, and next to the Ram Memory. The Processor is under the motherboard. (To the right of the Fan Assembly, when looking down from the top)
Also, ram memory modules ('Stick') are coated with a see-through plastic coating, on the Body of the module.
(Refrain from touching the gold plated contact pins on the bottom)
I would place a clean towel on the table, to protect the table, and the Netbook, lay the closed netbook upside down on it. (Bottom side up)
2) Remove ALL power. Remove the AC adapter (Charger), and Battery.
3) Turn the netbook over, open it as far as possible.
Remove the Keyboard
4) Removing the Keyboard:
At the top of the Keyboard, (LCD screen side) there are 4 Tabs to release.
They are from Right to Left;
Above the DELete key, F12, F8, and F4 keys.
If you look close you will see four thin rectangular pieces of plastic, above the noted keys.
These are depressed down.
I c-a-r-e-f-u-l-l-y press down on them, with a flat tipped Jewelers screwdriver.
Start on the left side with the release tab above the F4 key.
Once depressed the Keyboard will be released from this tab.
Go to the next tab, and so on.
Once all release tabs are released, the top of the Keyboard should pop up, a little.
S-T-O-P!
The Top of the Keyboard is lifted s-l-i-g-h-t-l-y up. Do Not raise it too high.
There may be side tabs also. These will pop loose once the top of the Keyboard is raised up slightly.
There is also a Keyboard Cable attached to the Keyboard.
It is Not needed to disconnect this cable, and I STRONGLY advise against it, as the plastic tabs of the connector on the motherboard, will break VERY easily.
Leave the Keyboard Cable attached.
The Back of the Keyboard may have plastic tabs protruding from it.
This is why the Keyboard is only raised to a slight angle, also.
With the Keyboard in an approximately 45 degree position, move it forward a little, then roll it over, and lay it down.
(Top of Keyboard lays down)
The bottom of the netbook has a Door. This Door is removed for access to the Ram Memory, and Harddrive.
Keyboard removed there are 5 screws marked with Door next to them, to remove.
Push on Door Release (Pretty hard) to ease the Door out.
Then go around, and gently pry the Door off.
Each ram memory module has a spring clip on the side. Each side.
The top of the clip is gently moved to the outside, just a little.
The top of the spring clip has a 'bump', or protrusion, which fits in a Side Notch, on the Ram Memory module.
Once both spring clips are eased out, the Ram Memory module will slightly spring up.
DO NOT remove a Ram Memory module in a straight up position!
You will bend contact pins down in the ram memory slot on the netbook, and damage the contact pins on the Ram Memory module.
The Ram Memory module is brought out in a 45 degree position.
It is installed back in the same position.
Handle the Ram Memory module by the Body. The body is coated with a see-through protective plastic. (The gold plated contact pins are on the bottom, of the Ram Memory module. The rest of the module is the Body)
When the protrusions of the spring clips are fully seated in the Side Notches of the Ram Memory module, the Ram Memory module is fully seated in the ram memory slot.
(Note*
The spring clip protrusion, and the Side Notch, are not a perfect fit.
A little leeway is allowed )
The Gateway LT2811u Netbook PC uses DDR3 Sdram ram memory, that operates at a maximum frequency rate of 1066MegaHertz.
(1066MHz)
It is PC2-8500 that is SO-DIMM.
The Maximum TOTAL Amount of ram memory is 1GB.
There is 1 ram memory slot.
Regards,
joecoolvette
[ Mega = Approximately 1 Million
Hertz = Cycles per Second
The above ram memory, can operate Up To 1066 Million Cycles per Second, frequency rate. ('Speed')
Dec 11, 2011 | Gateway Computers & Internet
How to re install oven door
There are two pieces of metal that are inserted into the hinge slots on the body of the oven, the spring (upper) and the hinge. Before you can re-install the door, you have to clip these two together by laying the door handle side down and then using all of your body weight to push down on the spring arm, using gloves and a wadded up rag to soften the impact to your hands, and then clip the two pieces of metal together using the little hinged clip on the hinge piece and the slot on the spring piece. When you've clipped these together on both sides, lift the door and insert the metal pieces into the two respective metal slots on either side of the oven body. when they're in as far as you can push them, use a flat edged screwdriver to release the clip and close the door. Good luck, it may take a couple of tries and be careful of the spring, because it can snap back and hurt you if the clip comes off prematurely.
Feb 20, 2011 | Thermador PGR366 Gas Kitchen Range
MY MEMORY CARD WILL NOT LOCK INTO PLACE WHEN I PUSH IT INTO SD SLOT
  • Most likely the SD card is not being pushed in far enough to lock into place. You really need to use your fingernail to push it in past flush until you hear a clicking sound, at which point the card will lock into place.
  • Here are full instructions for insertion and removal of the SD card: Insert the memory card with the metal contacts going into the slot first and facing up at you. In other words the SD card label should be upside down when you insert it this way. You need to push the card in past flush to have the spring mechanism lock the card into place. To get the card out of the slot, push the card in past flush and then the spring mechanism will release it. You will hear a click when the card locks into place or is released from the slot.
  • Dec 05, 2010 | Bushnell Trail Scout 11-9500c Digital...
    How do I upgrade the Ram of a Toshiba Satellite M35X-S114? Currently have 256MB. Any special precautions?
    How to upgrade the Ram Memory of a Toshiba Satellite M35X-S114 Notebook PC, and stating special precautions at the same time:
    1) Work on a table. Do Not work on a bed, couch, or directly on a carpet floor.
    These are high areas of Static electricity.
    [ Static electricity can fry out (Short Circuit) the hardware components inside your computer. It can also fry out the new Ram Memory module/s before you install them ]
    Do Not remove the new Ram Memory module/s from their protective Anti-Static cartons, or boxes, until you are ready to install them. (Old ram memory module/s removed)
    If you do not have an ESD wrist strap available, and a good ground source to connect the alligator clip to, at least touch a metal door knob before sitting down to replace the Ram Memory.
    If your table is sitting on a carpet floor, refrain from swinging your legs, and your feet on the carpet.
    2) Remove ALL power to the laptop.
    Remove the AC adapter (Charger) and Battery.
    Press the Power On button, and hold it down for a count of 5 seconds. Let go. Do this procedure two more times. You are draining any residual power.
    3) Laptop turned over the Memory Compartment Cover is the small square cover.
    http://www.irisvista.com/tech/laptops/ToshibaM35X/satM35X_1.htm
    Left-click on the photo in Step 1.
    Now close this small window, and left-click on the photo in Step 2.
    Step 1 photo shows you the Memory Compartment Cover, and the single Philips head screw to remove.
    Step 2 photo shows the Memory Compartment Cover removed, and the Ram Memory modules locked into the ram memory slots.
    The Ram Memory modules ('Sticks') are DIMM modules. Dual Inline Memory Module.
    They are a variation also for a laptop. They are SO-DIMM.
    Small Outline Dual Inline Memory Module.
    There are 200 gold plated contact pins on the bottom of the ram memory module.
    100 on EACH side.
    The photo above is to show a typical example of a SO-DIMM ram memory module.
    I would like you to;
    A) Observe the gold plated contact pins on the bottom.
    B) Observe the Locating Notch in the bottom of the ram memory module.
    C) Observe the Notch on each side of the ram memory module.
    D) Observe the Black DRAM chips on the side of the ram memory module
    When handling a Ram Memory module, refrain from touching the gold plated contact pins on the bottom.
    Handle the Ram Memory module by the body of the module.
    This area is where the black DRAM chips are.
    Note the Locating Notch in the bottom, and how it is not centered.
    This Locating Notch MUST line up with a Locating Lug, in the bottom of the Ram Memory slot.
    Observe the direction the old ram memory module comes out.
    There are metal clips on each side of a ram memory slot, that hold the ram memory module in place.
    These metal clips are Locks.
    Thin spring steel clips with a protrusion, or 'Bump' on the end.
    The protrusion, or 'Bump' snaps into the Notch on the side of the Ram Memory module.
    One on either side.
    To remove the Ram Memory modules, if there are more than one, you have to remove the top one first.
    Take your fingernails, and gently spread the metal Lock clips, towards the outside of the Ram Memory module
    Sometimes when you ease the metal clip out on one side, that side will pop up a little bit.
    Sometimes it takes releasing both Lock clips at the Same Time.
    When the 'Bumps' are free from the Notches on the side of the Ram Memory module, the Ram Memory module will spring up, or pop up, a little bit.
    Hold onto the upper corners with your fingertips, and slide the Ram Memory module out.
    NOTE*
    DO NOT pick straight up on a Ram Memory module when removing!
    You will bend the contact pins of the ram memory module, and ruin the contact pins down in the ram memory slot.
    The Ram Memory module comes out at an angle.
    To install:
    Install the bottom Ram Memory module first. (Yeah I know. Duh!)
    Line the Locating Notch up with the Locating Lug.
    Slide the Ram Memory module into place until the spring Lock clips need to be spread.
    Spread the clips, slide the Ram Memory module all the way into place.
    Be SURE the metal Lock clip 'Bumps' are seated into the Notches on the sides of the Ram Memory module.
    This way you can be assured that the Ram Memory module is seated correctly.
    Reinstall the Memory Compartment Cover.
    Turn the laptop over, reinstall the Battery FIRST.
    Then plug the AC adapter in.
    WAIT 20 seconds, turn the laptop on.
    BIOS will automatically 'recognize' the new ram memory.
    If you have questions please post in a Comment.
    Regards,
    joecoolvette
    Nov 15, 2010 | Toshiba Satellite M35X-S114 Notebook
    Watch indicated "low battery" Jeweler replaced the battery but the watch did not respond and remains blank. The watch goes through 2 to 3 batteries per year and light remains on too long and cannot be...
    Hi
    Try resetting it - it worked for me. First, orient your watch face down (with the watch belt buckle opposite you), the new battery in and latched. Second, on the right side battery hold-down latch you will see a small metal circle (~1 mm diameter) with a black dot in the center. Take a small paper clip and touch this metal pad to the metal battery hold-down latch for about 1 second. This will reset the watch.
    Rotate the tiny donut that clips over the battery so it touches the brass spring that is next to the battery, replace the back plate. you can use a small tool to carefully lift the metal contact back up off the contact plate. Also make sure the back of the case is on tight as this also plays a role the electro mechanics of this watch.
    Let us know if you want to know something else accept the suggestion.
    Thanks for contacting fixya.com
    May 27, 2010 | Timex Ironman Data Link 5C291 Wrist Watch
    Memory Card Stuck in slot
    Disassembly and repair isn't something for the faint of heart nor the inexperienced with tools. If you don't have the best buy extended warranty for this device and since it's been over a year, your options are slim.
    It is possible to repair the spring mechanism on these devices, but you'll need some fine tiped screwdrivers bowls for parts, a good memory for where parts came from to be put back, annd a lot of patience.
    The spring is a leaf spring on the bottom of the card slot and the retention clip is on the right about half-way into the card slot.
    I wish you the best of luck with your repair.
    Mar 07, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
    Card put in camera. Afterwards noticed that the small metal contact strip had fallen off card. Card won't eject now.
    So the metal strip is not inside the camera?
    If no, try this: Cut a piece of stiff plastic, exactly the width of the metal strip (19mm) and as long as comfortable. The plastic should not be mush thicker than the metal strip. Carefully insert the plastic strip in the card slot next to the card on the side where the metalstrip is missing. Press down on the card as you insert the strip. Do not try to pull out the card with force as this would bend the tiny springs in the card slot. When the strip has released the springs, the card should eject.
    Oct 21, 2009 | Fuji FinePix F30 Digital Camera
    Rear break clip cant get it to set right
    If you are referring to the big U ring that goes from one side down to the bottom and then back up to the other side nd fits into the slots on each brake shoe, there is a special tool that makes this clip easy to put on, but if you cannot get access to this tool, you will have to remove the U ring and start it from the bottom under the metal clip and then carefully (it will try and spring back at you) use a big screwdriver or small pry bar to fit it into the slots on each brake shoe. Hop this helps.
    Mar 11, 2009 | 2000 Pontiac Montana
    Cameras Logo
    85 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
