Question about HP Office Equipment & Supplies
HP LaserJet 1300 crumples paper on top left corner
Almost every page (not all but most) that comes out of my HP LaserJet 1300 printer is crumpled on the top left corner. The pattern of crimping is almost identical on every sheet. It has worked perfectly for a couple of years and nothing has been done to it and, suddenly, this starts.
Any suggestions?
    Master:
  • 638 Answers
Simple, the printer needs servicing as the gears which forwards the paper out from the left side r getting blocked somewhere.and the gears needs to be cleaned.
Posted on Nov 14, 2008
Paper comes out crumpled, how do I take printer apart to get to top roller?
try this link- http://www.retrevo.com/support/HP-1012-Printers-manual/id/260bh827/t/2/
Aug 09, 2011 | HP LaserJet 1012 Printer
Printer prints but crumples paper
I guess you have a roblem in your fuer assembly, replace it
Apr 07, 2010 | HP LaserJet 1300 Printer
Paper does not feed through, gets crumpled, jams
you have to remove all covers, then you have to clean all paper feed rollers..chek fuser assy too! If you unable to do that just go visit any special printer service!
Apr 05, 2010 | HP LaserJet IIIp Printer
The paper comes out crumpled with smeared ink on one side
the problem is the fusing film of the printer. go to a store and try to change the fusing of your printer. sayedelyaskavesh@gmail.com
Jan 18, 2010 | HP LaserJet 1300 Printer
Paper will not go through output rollers - jams at crumples
ok, in this case you need do:
1) check the roller before the fuser and after it some roller old not enough firction and pressure balance
2) check the fuser press roller it could not has good tough to fuser surface, it should be no gap at all and good pressure balance on the fuser surface
3) check the fuser cleaner which maybe too dirty, or change new one if you have the parts.
4) fuser unit maybe too old if printing pagers over its life cycle
hope this help you and please ask me any time.
May 15, 2009 | HP LaserJet 1300 Printer
Paper is crumpled, toner is not adhering in certain areas
The fuser is shot....this is the unit that uses heat and pressure to fuse the toner to the page. It is primarily when the pressure roller wears that you get crinkling and bad fusing, but I'm sure the upper sleeve has seen better days as well.
These days it is (sadly) cheaper to replace this printer with a new little HP -only around $100 or so.
*please rate me :)
Mar 17, 2009 | HP LaserJet 1300 Printer
Hp laserjet 4650 crumples leading edge of paper
When you open the paper tray assembly you will see that on each side there is a silver bracket on each end of the paper tray that the paper sit under. You can bend these away from the paper in a sidways just a little and that will fix your problem. The paper is hanging on these plates as it feeds and is bending the paper as it feeds.
Oct 01, 2008 | HP LaserJet 4650 Color Printer
277 people viewed this question
Seeker5211
Seeker5211
