My panasonoc flatscreen wont turn on the little red light next the on off switch is blinking
    Sergeant:
    Champion:
  • 346 Answers
How many blinks?
Posted on Nov 14, 2008
My insignia flatscreen wont turn on red light flashes 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 20, 2016 | Insignia 50 in. Flat-Panel Plasma HDTV
My Teac flatscreen tv wont turn on the light is flashing red and green. I have turned it off and on at the power source and changed the batteries in the remote
Apr 24, 2016 | Televison & Video
My tv flatscreen (LE40A557P2FXXU) seems to be stuck in stand by mode "red light flashing" and when switched on via remote nothing happens, ie tv wont come on. Also when the switch on the side of...
Internal checking circuits, most likely the high voltage circuit. Take off the rear cover. From where 120 volts AC, leads to a fuse, then to a small high voltage transformer, then a capacitor. Check DC voltage at the capacitor. For me it was 380 volts. This capacitor needed to be replaced. Samsung uses a 100 uf rated at 450 volts. Found some old power supplies and got two capacitors - 150 uf and 220 uf both rated at only 400 volts. Had to connect them in parallel making 370 uf. The voltage check was 391 volts, but my TV is now working.
Jan 08, 2018 | Samsung Televison & Video
T.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Aug 11, 2009 | Sony BRAVIA KDL-40V3000 Television
I have a LG 32 in flatscreen. It wont turn on. The green light blinks and I see the monitor light up some but no picture or sound. I can not see the menus or anything else. What can I do to fix this? I...
hi..the reason due to this problem may be
due to the circuit board.If the soldering is not
done in any part of the main board this type of
problem occurs.check the board completely.
check this out..
thank u..
rate me..
Feb 10, 2009 | Philips Televison & Video
INSIGNIA 32 IN FLATSCREEN MODEL NS 32LCD
check for capacitors on the power supply that are puffed up. Also the mai board can cause this but the power supply is where i would start.
Jan 08, 2009 | Televison & Video
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Televison & Video Logo
Top Televison & Video Experts
