Question about Maytag Neptune MAH5500B Front Load Washer
Washer wont spin to strain load
When I select the SPIN cycle the number 9min displays. Then the machine agetates to one side for a few revolutions and then to the other. Then it sits for about 45-60sec then tries to begin straining and then it stops as if something is binding it and the display goes from 7 to 0. what could be this issue. Any assistance is greatly appreciated.
Safety recall on MAH9700. Found it on website http://www.fixya.com/support/t124779- washer_wont_spin_strain_load Have had this trouble and Maytag has refused to address problem. Went to website above and found safety recall. Give it a try. Hope sthis helps you. Maytag didn't!
Posted on Feb 21, 2007
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
LG Washer/Dryer Combo not spinning
If you can make the motor spin a few revolution by manual intervention, then the issue is most likely a faulty motor 'start' capacitor which is located near the motor: this replacement involves a dangerous MAIN AC VOLTAGE device and I would advice getting a qualified technician to check/repair your dryer.
Hope it helps.
Apr 06, 2014 | LG WM-2277HW Front Load Washer
Washer will not agetate or spin and will not unlock
See if this post http://www.fixya.com/support/t4626959-lid_locked_not_open will help you open the machine.
Any indication of power to the machine? What is your model number?
May 14, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Sears 700 series top load washer, model 110.27711600
no that is a shipping pin when they pulled the strap those pins fall into those little cups instead of onto the floor. so it does not spin. does it agetate? if the answer is yes you probaly have a good drive coupler. Possible suspects would be a bad transmission if it is stuck in nuetral drain, clutch if you can push start the basket in spin cycle you have a bad clutch, bad drive block you need to take the agetator off and check to see if the drive block is not raised from the basket drive basket drive has 2 ears that fit into the drive block.
Jul 24, 2009 | Kenmore 24032\24036 Top Load Washer
Code to restart washer Duet
Answer Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required.
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is your outlet voltage low?
Check electrical source or call an electrician.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Aug 23, 2008 | GE WHRE5260E Top Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
It sounds like you need a motor and control board, This is almost always what is wrong when there is a spin problem with these particular washers. I belive the parts are under warranty for 5 years, so that should save you the cost of that if its not too old.
Nov 21, 2006 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
107 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
