Ntldr cannot boot - Computers & Internet
  • 101 Answers
the ntldr - nt loader is missing or corrupt, this will require you to use the windows setup cd to perform a repair or full install of windows to fix the problem.
a advanced user might be able to correct the issue in the repair console but I wont get into that since I'm not sure how thats done.
Thank you,
I will fix it!!
Posted on Nov 14, 2008
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Jan 22, 2014 | Belkin Basic Wireless Router
NTLDR missing on XP desktop
NTLDR is the boot loader for windows XP. This is the part the kick starts the entire process of XP loading. It is located at C:\NTLDR One of the easier ways to fix this is Either boot in to the recover console from a Windows XP disc, or download Hiren Boot CD, burn it to a disc. Insert the CD into your Dell and reboot the computer. Note you may need to enter BIOS and enable boot to CD/DVD. Once at the Hiren menu, select Boot Mini XP. Once the Mini XP loads you can copy NTLDR loader from the mini xp to your C:\ drive. Then remove the disc and reboot the computer.
Jun 11, 2012 | Computers & Internet
NTLDR is missing
NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This often occurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the drive configuration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has been corrupted or deleted
  • Check that there are no CDs or DVDs in the CD/DVD drives.
  • Check that no removable drives are plugged in to the USB ports.
  • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices
  • However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this and use the Recovery Console to fix NTLDR manually .
    Jan 02, 2011 | ASUS Eee PC 900 Notebook
    Nltdr missing
    How To: Fix "NTLDR is missing"
    Applies to: Microsoft Windows NT, Windows 2000, Windows XP
    Symptoms
    When you start your computer, you receive the error message "NTLDR is missing. Press any key to restart."
    Cause
    The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found. This oftenoccurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the driveconfiguration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has beencorrupted or deleted.
    SolutionCheck the boot drives
    First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one thatcontains Windows.
    • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices.
    If this does not resolve the problem, you will have to repair the NT boot loader.
    Fix NTLDR
    The easiest way to fix the "NTLDR is missing" error is to use Spotmau PowerSuite.However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this anduse the Recovery Console to fix NTLDR manually instead.
    Use Spotmau PowerSuiteInsert the Spotmau PowerSuite CD and start the computer. The main menu will appear.spotmau-2.gif
    • Click 2. Windows Recovery.
    • When the Windows Recovery tool starts, click Windows NT/2000/XP/2003.
    • On the Windows NT/2000/XP/2003 Recovery dialog, click Recover NTLDR and NTDETECT.
    • On the Recover NTLDR and NTDETECT dialog, select your operating system (e.g. Windows XP) and then click Recover.
    The tool will repair the file and report "NTLDR and NTDETECT have been recovered successfully."
    • Remove the Spotmau PowerTools CD from the drive and click Restart to reboot the computer.
    Here link of the program Spotmau PowerSuite 2010 + Serial Download
    Here link of the program Spotmau PowerSuite 2010 v5.1.1.4846 Download
    Please Rate Me
    Nov 17, 2010 | HP Pavilion dv6000z Notebook
    What is NTLDR error sir?
    NTLDR (abbreviation of NT Loader) is the boot loader for all releases of Microsoft's Windows NT operating system up to and including Windows XP and Windows Server 2003. NTLDR is typically run from the primary hard disk drive, but it can also run from portable storage devices such as a CD-ROM, USB flash drive, or floppy disk. NTLDR can also load a non NT-based operating system given the appropriate boot sector in a file.
    NTLDR requires, at the minimum, the following two files to be on the system volume:
    • NTLDR, which contains the main Boot loader itself
    • boot.ini, which contains configuration options for a boot menu.
    This error means that NTLDR is missing somehow from your computer,hard disk problem,virus.etc
    You can go to that page and follow the instructions exacty as he says and your problem will gone:)
    http://www.tinyempire.com/notes/ntldrismissing.htm
    Jan 12, 2010 | Abit KW7 Motherboard
    NTLDR is missing
    Reference number: CH000465
    NTLDR is Missing. Issue:NTLDR is Missing.
    Related errors:
    Below are the full error messages that may be seen when the computer is booting.
    NTLDR is Missing
    Boot: Couldn't find NTLDR
    Please insert another disk
    NTLDR is missing
    Press Ctrl Alt Del to Restart
    Cause:
    1. Computer is booting from a non-bootable source.
    2. Computer hard disk drive is not properly setup in BIOS.
    3. Corrupt NTLDR and/or NTDETECT.COM file.
    4. Misconfiguration with the boot.ini file.
    5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
    6. New hard disk drive being added.
    7. Corrupt boot sector / master boot record.
    8. Seriously corrupted version of Windows 2000 or Windows XP.
    9. Loose or Faulty IDE/EIDE hard disk drive cable.
    You can go to these sites to view solutions (to much to post here) Very easy to understand:
    http://www.computerhope.com/issues/ch000465.htm
    May 22, 2009 | E-Machines eMachines Desktop PC
    NTLDR is missing
    Fixes for NTLDR Errors
    2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
      Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
    3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
    8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
    12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
    Jan 17, 2009 | Computers & Internet
    What is NTLDR
    NT Loader (NTLDR) is a small piece of software loaded from the boot sector of your primary hard drive that helps your operating system start.
    If you have multiple operating systems installed and properly configured, NTLDR will show a boot menu when your PC starts, allowing you to choose which operating system to start.
    Thanks for using FIxya
    SAM ANDERSON
    Oct 04, 2008 | HP e-PC 42 PC Desktop
    Ntldr
    check boot sequence in advanced bios set-up by pressing delete key when booting.make sure of the following
    1st boot-hdd(hardisk)
    2nd boot-cd rom drive
    3rd boot floppy drive
    missing ntldr happens when the floppy drive is
    not working..you can disable the floppy drive on the bios set-up as well
    thank you im april guevarra--phillipines
    you can mail me at redsmart_86@yahoo.com
    Dec 07, 2007 | ASUS P4S533 Motherboard
    Computers & Internet Logo
    75 people viewed this question
    David Payne
    David Payne
