Question about Canon XL2 Mini DV Digital Camcorder
Canon xl2 playback
I shot on a Canon xl1 in HD but did not use an HD tape and now I am trying to play back on a Canon Xl2 but it wont work.  The tapes seem to be corrupted.  Does anyone know how I could get this to play back?
    Novelist:
  • 208 Answers
I DON'T THINK YOU HAVE A PROBLEM EXCEPT TRYING TO USE A GENERIC TAPE TO RECORD IN HD AND THEN EXPECTING IT TO PLAYBACK IN HD. IT WASN'T MADE FOR THAT AND WON'T WORK FOR HD. IF YOU ARE GOING TO USE A HD CAMERA, YOU NEED TO USE THE CORRECT HD TAPES TO EXPECT THEM TO WORK AND PLAYBACK CORRECTLY. WHY WOULD YOU BUY ONE OF THE MOST EXPENSIVE CAMERAS ON THE MARKET AND THEN USE A $2.00 TAPE AND TRY TO PLAY IT ON A $2000.00 CAMERA AND WONDER WHY IT DOESN'T WORK? BUY GOOD QUALITY TAPES.
Posted on Nov 15, 2008
Canon xl2 tape won't eject
This is a known problem.
Broken loading gear, Example: canon zr65 replace broken gear
Canon XL2 and ZR65 uses same tape drive system.
Feb 20, 2015 | Canon XL2 Mini DV Digital Camcorder
XL2 Tape Fault
Does this occur with this one specific tape?
Dec 29, 2007 | Canon XL2 Mini DV Digital Camcorder
Playback flickering
The most common cause of this is dust, debris or contamination on the heads.
Firstly, it's extremely important that you use only DRY LUBRICANT type DV tapes on the Canon branded camcorders.
Different manufacturers design their heads to be used with either Dry or Wet (coating lubricant type) tapes - NEVER BOTH. Canon is DRY type.
Consumers are led to believe that they should be using well known branded DV tapes, such as Sony. This is fine, if your camcorder is a Sony. However, you should NEVER use Sony tapes in your Canon - Sony tapes are of the WET type.
So, the question is, "Are you currently using Dry or Wet type tapes, or a mixture of both?" If you have used either a WET tape, or a mixture of both in your Canon, then this may have contaminated your heads.
If this is so, then don't panic - simply run a special Head Cleaning cassette (for Dry tapes) in your Canon for no more than 5 secs. Note: your heads are very delicate, so only run the cleaning tapes for a few secs at a time.
Also, try to avoid recording over the cassette too many times, as the quality will sometimes degrade each time.
An example of the Dry tapes are the Panasonic ones (Myself and other Pro Videographers often use Panasonic Prof, Studio or Master Quality tapes, as these are some of the better quality Dry tapes on the market).
As your XL2 is a Pro Camcorder, I recommend you stick with Studio quality (or higher) cassettes.
See this link for Dry DV tapes: http://cgi.ebay.com/Panasonic-mini-DV-digital-video-cassette-AY-DVM63SQ-5pk-/170645949017?pt=US_Camcorder_Tapes_Discs&hash=item27bb4a8a59
or
http://cgi.ebay.com/5-Panasonic-Master-HDV-HD-video-tape-HC9-Mini-DV-/220519311691?pt=US_Camcorder_Tapes_Discs&hash=item3357f9a94b
See this link for Head Cleaner cassette: http://cgi.ebay.com/MiniDV-mini-DV-Panasonic-Head-Cleaner-Cleaning-Tape-/220683036059?pt=US_Camcorder_Tapes_Discs&hash=item3361bbe59b
If the problem still exists after head cleaning, then suspect either a faulty cassette (most likely) or damaged heads requiring service.
Let me know how you get on...
Scott
"If this has helped you, please be kind enough to leave a testimonial"
Jul 09, 2011 | Canon XL2 Mini DV Digital Camcorder
Camera: Canon XL2 My camera has got jammed. Tapes refuse to play. I understand that I need to change the entire recording system. What is the technical name for that system and how much does it...
It is usually called the "Transport assembly" or "Transport carriage" and is quite often the most expensive portion of the camera (motherboards can be pricey, too). They often cost upwards of USD $200-300.
Jun 27, 2011 | Canon XL2 Mini DV Digital Camcorder
I got the problem with my canon XL2 since last 3 months ago. The tape cannot unload sometimes. During recording and run out with tape, try to change with the new one but the cassette compartment cannot...
that is could be the cassette in switch or door swith inter mitent contact, or the mode switch for the mechanism position....
or a good clean up of the mechanism...
hope that will help you
regards allan
Sep 02, 2010 | Canon XL2 Mini DV Digital Camcorder
Canon xl2 will not take the tape it says remove tape in viewfinder.camera is dry whats going on here
Canon XL series will indicate "remove tape" sign when the head does not read the data when inserted. You probably have clogged head and probably needs cleaning. Depending on the condition of the clogged head, you can try by running head cleaning tape for about 10 sec. If that does not resolve, it shoud be cleaned and adjusted by trained technicians. Good Luck. If need a professional help, go to www.camerarepairjapan.com
Mar 15, 2009 | Canon XL2 Mini DV Digital Camcorder
Canon XL2 wont record or playback tapes - grey
Sorry to hear your situation, usually when serviced by a technician, head and tape path is cleaned and adjusted. During use you will encounter pixelation problems occur and most case tape cleaner should resolve the problem. Your condition is where if all the system is ok and have a heavy clogging on the heads, requires technician to clean each head manually to bring it back. so look for a camcorder repair facility locally and get cleaned. If you cannot find one, the service is provided for around $100 at www.camerarepairjapan. Good Luck
Feb 03, 2009 | Canon XL2 Mini DV Digital Camcorder
Cleaning tape jammed in canon xl2 camcorder
Take the camera to a reputable camera shop, there is honestly no way to do this at home, if you touch the video heads by accident, or accidently move something, it could spell big trouble. Also I to have an XL2, and canon might be willing to fix this for free from what I understand about their customer care plan (Best Regards)
Dec 30, 2007 | Canon XL2 Mini DV Digital Camcorder
Condensation operation
follow the manuals instructions for this, ergo: leave the tape hatch open for at least 30 minutes to an hour, and try again. If this doesn't work. Call canon, and see if they can repair or replace your XL2
Nov 24, 2007 | Canon XL2 Mini DV Digital Camcorder
Canon XL2 Mini DV Digital Camcorder Logo
250 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
