Question about Samsung 500w Rrss Rear Reflecting Surround Sound Home Theater System
SAMSUNG HT-TZ212 home cinema kit comes up with protect
Have a SAMSUNG HT-TZ212 home cinema kit. now when i power this on, it displays protect and then powers off
  • 8 more comments
  • Anonymous Nov 30, 2008
    Exactly the same happened to my system(HTTZ212):(
    Frorem
  • Anonymous Dec 12, 2008
    same here ....just played well and just on one they it says protect and shuts off, nothing helps ..what can i do about it
  • Anonymous Dec 30, 2008
    I am having exactly the same trouble with mine and it is not mentioned at all in the user manual - only had the system a couple of months and was working fine yesterday!! :-(
  • tuggismallz Feb 24, 2009
    same problem has happened to my samsung httz212 ,wont turn on just displays protect and turns off
  • curryman123 Feb 26, 2009
    I have the same problem, samsung comes up protect, then powers down, dvd still inside, pressed all buttons, checked book and no english in book.
    same as prior people, what can i do here, bin it or what
  • hakkibasri Mar 03, 2009
    have a SAMSUNG HT-TZ212 home cinema kit. now when i power this on, it displays protect and then powers off
  • Anonymous Apr 12, 2009
    "SAMSUNG HT-TZ212 home cinema kit comes up with protect" problem
  • Anonymous May 06, 2009
    I have a Samsung Surround System HT-Z110, about 6 months old, now at startup it displays PROTECT and shuts down. What to do?
  • Anonymous Mar 17, 2014
    Does the samsung Home cinema system ht z11 have an aux function? If so where is the input point?
  • Samsung Master
  • 19,396 Answers
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
  • 4 Answers
Try disconnecting all speakers and see if it still protects if it does it could be faulty cables or speaker
Posted on Jul 22, 2009
I have a Samsung HT X 30 home cinema after about 15 to 20 minutes turns off saying protected??
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 06, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
I have a samsung home cinema ht-tz212 keep saying protect and not working
its most likely over heated. Try removing the plug and moving it away from the tv and any heated areas for atleast a day, then try turning it on and it should work..
If it only goes into protect when you put a dvd in then change the regional code.
Feb 26, 2010 | Samsung Audio Players & Recorders
My samsung home cinema ht-tz212 wont play discs, just says loading, then open or disc error??? ive tried cleaning fluid lense cleaner with no luck ???
Try resetting the system turn power off then press and hold stop button on Main unit for at least 5 seconds this is main system reset it may well do the trick for you
Jan 31, 2010 | Samsung Audio Players & Recorders
Samsung hiome cinema protect error message
you need to change 5q tranzistor.if you dont have short circuit on pin 9 to ground on flat who comes from amplifier
Aug 04, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Ht-z210 home cinema protect error
Protection Error means that there is a malfunctioning component inside your unit. It will go into protection mode and immediately shut down to protect your system from any further damage. Unfortunately you would have to bring it to a dealer or repair shop to diagnose the exact malfunction and that could be expensive.
Gary
Jul 18, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Protection displayed and shuts off When I press the power button Protection is appear on screen on my home cinema system dvd player
check wiring on speakers it sounds like you have some wires touching together somewhere or you have a bad speaker.
Jun 15, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung ht-tz212 protect!
resistor smr60 is 470r / 470 ohm
Nov 08, 2008 | Audio Players & Recorders
Problem with DVD player
i have had samsung surround sound for couple months, only been used once, now when i power up, protect is displayed on front and then powers down, also, when it does work, sound is extremely low compared to when i first used it.
Jul 12, 2008 | Samsung 500w Rrss Rear Reflecting Surround...
4,320 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
sonic boom...
sonic boom...
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
