Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Whirlpool dishwasher doesn't clean/drain.
Model #GU98OSCGQ2. It cycles through, but with long delays between cycles. When the "clean" light goes on, there's still water in the bottom of the tub and the dishes are not clean. When I push "Cancel/drain", a motor goes on and it sounds like it might be draining, but when you open and check, there is still water in the bottom. A service technician was here this morning, he checked the drain hose under the dishwasher, took a white, plastic thing out and cleaned it, said THAT was the problem and left. Unfortunately, he didn't seem to know much about fixing dishwashers and was on the phone with his supervisor. It still is having the same problem. Any ideas? At least if they send HIM back to me again, I can point him in the right direction. Thanks for ANY help you can give me!
  • crisnpete Nov 23, 2008
    We have the same problem. The service repair guy said it was a clog in our plumbing after the dishwasher. I snaked all the lines and still have the problem. I got charged ofr the visit even though he did not do a thing to help me. Anyone know what could be wrong?
  • 457 Answers
Sounds to me like a drain pump restriction or failure. let me know if this helps.
Posted on Mar 01, 2010
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Whirlpool DU930PWP02 Start Light Flashes 3 Times and does not run
Sounds like the anti flood alarm has activated - may be a small leak from the door or the sump into the base tray. You need to drain the tray, fix the leak and test. Try cleaning the door gasket and part of the door it seals against.
Feb 04, 2018 | Whirlpool Dishwashers
My Whirlpool Quiet Partner II will not drain at the end of the final cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 16, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool model dp8500xxn2 Leaving white film on everything
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Apr 11, 2011 | Whirlpool Dishwashers
Control panel on my whirlpool dishwaher not functioning properly
The console (control panel) is defective. The buttons may be getting stuck and/or are corroded.
Feb 20, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Clean light flashes constanly. Won't clear out to start new cycle
I can't get the light to clear off. I can "cancel" and it goes through the drain cycle, but when done after opening the door to reload, then trying to start, it does nothing.
Nov 15, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Doesn' cycle power is on except drain cycle goes, clean light blinks 7 times
Check this link for more info:
http://www.repairclinic.com/0088_9_1.asp
Jun 17, 2008 | Dishwashers
Whirlpool Gold dishwasher
did you check the thermal fuse in the console part #675813? its mounted on the control board white fuse w/ 2 wire leads
Jan 26, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
274 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
