Question about Samsung 5528R Vacuum
Samsung Quiet Storm 9048R hose break
9048R canister vac no longer supported by Samsung. Hose breakage near plastic part that attaches to vacuum body with intermittent interruption of power to motorized brush head. Unable to get any help from Samsung. I could repair it myself if I could get exploded parts diagram or shop manual section explaining how to take apart plastic hose connecter without breaking it (or someone familiar with product who could talk me through it). I would also send hose assembly to repair shop if I could find one (not a lot of options in Wyoming!). This is all that's wrong with the unit and I would like to keep it. Thanks. Art Schueneman
  • arthurs572 Nov 17, 2008
    Not sure we're talking about the same animal. For some reason they listed this vac as a 5528R when in fact it is a Quiet Storm 9048R with the electric wires in the hose. The fitting that connects the hose to the vac appears to be 3 pieces of plastic - two halves of the housing each with a pushbutton operated catch that lacks the housing to the swivel in the vac body. Each half also has a metal lug or spade connecter to which one of the power wires is attached. These two halves are held together IN PART (and this is the jist of the problem) by a single screw and they appear to pinch the 3rd part, a plastic tube, one end of which protrudes out and into the vac body (the other end being connected to the hose). The problem is that when I take out the single screw, the 2 halves of the housing do not want to come apart and I'm afraid that forcing them apart will break something internally that is still holding the halves together.
Shelcny,
Do you still have the hose for Quite Storm vacuum by Samsung? Mine goes in fine and clicks but the suction is very poor (red on the indicator, green prior to putting the hose in). I electrical taped all the way, but still doesn't seem to get suction strong enough.
Posted on Aug 23, 2009
Shelcny
I bought an extra hose a while back when mine had a leak. I ended up fixing it with electrical tape and I have a perfectly intact hose just waiting to be used. I'd be willing to part with it.
Posted on May 08, 2009
    Scholar:
  • 132 Answers
OK ART THE FITTING THAT CONNECTS TO THE HOSE SHOULD HAVE TWO SMALL SQUARE HOLES OPPOSITE EACH OTHER YOU NEED TO PUSH TWO FLAT HEAD SCREW DRIVERS IN AT SAME TIME TO RELEASE THE SECTION THAT THE HOSE SCREWS INTO POP THIS APART THEN REMOVE THE SMALL PIECE OF BROKEN HOSE AND SCEW HOSE BACK ON REPLACE INTO FITTING SO THE SQUARES POP BACK INTO PLACE AND START VACUUMING HOPE THIS HELPS GLENN PS ANY VACUUM SPECIALIST WOULD BE ABLE TO HELP WITH THIS SMALL PROBLEM IF YOU WANT TO MEET ONLINE ABOUT THIS I WOULD BE MORE THAN HAPPY TO ASSIST
Posted on Nov 15, 2008
Weak suction strength
several things to look at. first, did you change the bag?. next, check the belt on the head unit. next, check the wand for a clog. some vacuums have several filters near the motor. check those too. good luck to you.
Feb 06, 2011 | Samsung Quiet Storm 9048R Bagged Canister...
My vacuum is constantly shutting itself off. When
It sounds like you have a blockage somewhere and the air is not passing over the motor to keep it cool. There is usually a thermostat mounted either on or near the motor. The blockage can be anywhere from the elbow ( the swivel part of your carpet sweeper if you have a canister vac) up thru the hose.If you have a canister vac, use a broom handle to push through the hose to clear the blockage. DO NOT ! use a coat hanger or anything that will cut or tare the hose. There are electrical wires in it that have 120 volts and causes quite a shock !
If you have an upright vac, start with the duct hose that comes from the part with the brush up to the hose and on to the main canister of the vac
If this does not work, take your vac to a reputable vac shop for repair. Hope this helps,
Joe
Nov 16, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have a torn hose on my Samsung Quiet Storm should I try to repair or toss it. Mfg no longer makes replacement hose
The early hose on these was prone to tearing. If you are careful you can shorten it once. Beyond that it will become too short to use on the vac properly. This hose was copied from the original Black and Decker hose and power head kit and was likely upgraded by a flex vinyl molded hose which should be more resistant to tearing.
Some vac shops carry hose "refills" and a Samsung dealer may have one in stock even if the hose was discontinued. The vac is good quality in its general design and worth fixing although the original diameter of this hose may be tough to match
Oct 30, 2009 | Samsung Quiet Storm 9069 Vacuum
Every time I turn vac on with hose attached the canister sucks in on itself. the hose is not plugged
Try it with no attachment or nozzle on the end. If it sucks the hose in on itself then, you'll be wanting to check that hose one more time. Pass something with a larger diameter through it. I'd try 3/4" PVC pipe or something like that. Another alternative is to place the hose on the exhaust of the canister and try to blow it out. Yet a third possibility is to reverse the hose on the suction side and **** through the hose backwards.
Best regards, --W/D--
Aug 08, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Will not start
try opening it up again and reclosing. Might be as simple as the cleaner is not lined up right. Check for bag misalignment. some cleaners have a lock-out mechanism that prevents the cleaner from starting if the lid and or bag are not in the proper alignment. If it is the filter compartment, same thing. Then, check a different outlet, check if your bag is full. if you were cleaning with the machine already prior to the checking of the back, maybe there is a clog or full bag as this would cause the vac to overheat and thus, the thermostat would not allow the vacuum to operate until it cools. If this is the case, change your bag, filter, and drop a penny through the hose(unattached from the vacuum and power nozzle) to check for blockage. Chances are, this is where your problem lies.
Jul 18, 2009 | Samsung Quiet Storm 9048R Bagged Canister...
Hose has a break
Don't cut the hoser. It has electrical wiring. You will need to replace it. Unfortunately, Samsung doesn't make vac's anyore. you might find a repair place that can fix your hose, or can order a new one. . we can fix it here, we are in Albuquerque, NM. I hope this helps.
Jun 05, 2009 | Samsung Quiet Storm 9048R Bagged Canister...
Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
Dirt Devil Upright Bagless Vibe Vacuum no longer sucks
Sounds like there's a clog in the long hose that connects to the dirt canister. Remove the hose completely and check for clogs. There is a blue plastic piece that the hose is attached to. You can remove it by taking out the two screws in the back, and the four screws behind the dirt canister. Once those are removed, the hose comes away from the vacuum with the blue plastic piece attached. That should allow you to check for clogs. If necessary, take the hose outside or a place that is well lit, so you can visually verify the absence of clogs.
Mar 09, 2009 | Dirt Devil M087700SV Bagless Upright...
Motor on the powermate keeps cutting in and out.
If your talking the motor on the beater bar, then chances are either when the beater bar was attached to the hose near where you hold it, it did not lock, and the connection is intermittent, or the cord has an internal break.
Jan 22, 2009 | Kenmore 22313 Bagged Canister Vacuum
Clogged vacuum hose
I used a snake like they sell for unclogging pipes. I can use the snake on one end to break it up. I attach the other end to my industrial wet.dry vac and **** it clean. Sometimes I cannot imagine how it fills half a five gallon bucket of dog hair and stuff.
Jul 30, 2008 | Kenmore 22812 Bagged Canister Vacuum
Samsung 5528R Vacuum Logo
720 people viewed this question
Top Samsung Vacuums Experts
woodzowl307
Dyson Solutions...
Dyson Solutions...
Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
