Question about MSI K9MM-V Motherboard
Problem on Boot
I'm tech.
The Mother Board is K9mm-v (ms7312)
The system has 1 Gig of Ram
When I Start up computer it Freezes! I can not get into bios!
It Freezes on logo.
I unpluged all Drives and I can't get into bios!
Power Supply is good (tested)
I think it is a bad Mother Board... but not sure??????
  • tccat1 Dec 02, 2008
    Memory Post ok for 1 gig DDR
    It's working good now
  • spongya77 Apr 12, 2009
    I have the same problem, and the changing the mouse does not help. I can get it work if I get it out, put it on a plastic surface, connect it to the supply, and short-circuit the power switch, but the next time it freezes, it starts it all over again. The company I bought it from says they tested it, and it ran fine.
    Please help...
    Scholar:
  • 126 Answers
Hello tccat1,
Definitley sounds like a bad motherboard, however, try removing the memory and using a different stick if you have some. Maybe 512 see if you can at least get it to post.
Posted on Nov 14, 2008
Found The Problem out (I just unpluged the mouse and key board and booted it up then shut it down
and placed the keyboard and mouse back in and it Booted up ok.
Posted on Nov 19, 2008
I have a MSI K9MM-V(MS-7312) mother board installed running on MS XP Professional, I wanted to temporarily boot from my CD/DVD drive how do I accomplish this?
Just go to bios setup, click "delete" or "F2" when the system started to boot up, go to boot set up and select "cd rom drive" first boot, save on exit. It restart w/ the cd rom drive first.
Hope that helps you out.
Sep 13, 2011 | MSI K9MM-V Motherboard
Can it support windows 7
yes, its supported by windows 7.
but need more setting to make it fast. maybe tune up utility will help increase the performance.
help me by rate my answer.
Mar 06, 2011 | MSI K9MM-V Motherboard
How do i read the motherboard to see what board i have
The Manufacturer of the mother board is MSI and details are as follows:
Manufacturer Part # :K9MM-V
Product Type :Motherboard
Form Factor/chase: Micro ATX
Chipset Type :VIA UniChrome Pro K8M800 / VIA VT8237R Plus
Multi Core Support :Dual Core
Max Bus Speed :800 MHz
Socket Type 0 ( 1 ) :- Socket AM2
Compatible Processors : Athlon 64, Sempron, Athlon 64 FX, Athlon 64 X2
It supports 64 Bit Processor
Multi Core Support :Dual-Core
Its Supports RAM Technology: DDR II SDRAM
RAM Installation : 0 MB / 2 GB (max)
Supported RAM Speed :PC2-4300, PC2-6400, PC2-5300
RAM Features :Two DDR Channels
Video Memory :Shared video memory (UMA)
Audio Codec :Realtek ALC655
Sound Output Mode : 5.1 channel surround
Expansion Slots Total (Free) :1 processor - Socket AM2
You can addin RAM of :2 memory ( 1.8 V ) - DIMM 240-pin
PCI :3 PCI ( 3.3 V/ 5 V )
Storage Interfaces
Additional Connectors : 4 x Hi-Speed USB
Dec 21, 2009 | MSI K9MM-V Motherboard
Need a msi ms-7312 ver 1.0 vga driver
Hi, Your driver can be downloading easily by using this: Driver Update Software. take a look, and wish you best of luck. Hans
Oct 02, 2009 | MSI K9MM-V Motherboard
Cpu lead lights on but no display in monitor
check the RAM condition, For that remove the RAM from mother board and clean the two side of RAM contact terminals wiping with the eraser and insert it again into the mother board.
if you have using more than one ram just remove both the RAMs reinsert one by one after cleaning the RAMs one by one .
Jul 07, 2009 | EliteGroup ECS 755-A2 Motherboard
I have 1 gig ram added 2gig of ram to my P5VDC-MX mother board.
Your system might only be able to recognise 2gb of RAM. Tiger Direct has a RAM finder for almost every computer. Check it out to see if you have too much.
Jul 02, 2009 | ASUS P5VDC-MX Motherboard
K8 Neo-2 V-2.0
Please connect jPw1 to 4 Pin 12v, this supplies power to CPU. Than enter Bios & find Boot settings. Set the cdrom as boot 1 & hd as boot 2. Check the jumper on the cdrom, as it is the only device on secondary IDE controller it should be set as a master.
It is better to install a fresh copy of windows with a new motherboard. Put your windows CD in the cdrom & the system will boot to it. And your on your way. You can install the drivers for the board after windows has been installed.
Enjoy!
Plaease vote..
Dec 05, 2007 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
MSI K9MM-V Motherboard Logo
233 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
