Question about Car Audio & Video
Locked radio I broke my 1998 Bose Head unit in my Cadillac Catera and bought a replacement at a junkyard that is the exact same radio. When I plug the radio in it tells me it is locked. I tried holding 2&3 and 1&4 for 15 seconds but nothing happened. I think the code is on the replacement head unit and is 8158. Please help.
    President:
  • 1,450 Answers
YOUR RADIO IS DIFFERENT THAN THE CODES YOU HAVE SEEN ME GIVE IT REQUIRES THE TECH2 SCAN TOOL TO RELEARN VIN TO RADIO. A LOT OF INDEPENDENT SHOPS HAVE THIS AS WELL AS DEALERS. THIS IS ONLY WAY TO GET YOUR RADIO UNLOCKED
Posted on Nov 17, 2008
  • 43 Answers
This is a different type coded stereo. These stereos communicate with the car's computer. The dealership is the only one that can recode this stereo to communicate with the car's computer to work. I have seen the dealership charge over $100 for this ten minute process, I have also seen them do it for free. If you are not happy with the recode quote, call another dealership.
I have a 1998 Cadillac Catera and the speedometer,odometer,& oil pressure gauge doesn't work.All of the icons on the dash are lit up.Also the radio appears to be playing and no sound.Can someone...
radio with no sound is the radio interface in the trunk next to the amp..i just fixed one and that was the problem $5 at junkyard..not speedometer and dash lights all on is your ebtcm have it rebuilt new there $2000
Oct 08, 2011 | 1998 Cadillac Catera
I have a 1998 cadillac catera and when i changed the battery the bose system anti theft lock was on the radio how can i get it to work again
Check and make sure there aren't additional cables that need to be connected directly to the battery.
Feb 28, 2011 | Car Audio & Video
I JUST GOT A 98 CATERA , IT DIDN'T HAVE A RADIO IN IT , SO I ORDERED ONE OFF EBAY ,PUT IT IN ,TOOK TO DEALER TO HAVE IT UNLOCKED & PROGRAMED , AND IT COMES ON ,SHOWS THE STATIONS & THE CLOCK WORKS...
If the system you bought is marked BOSE, it does not have any onboard amplifier power. The only powered radios for the Catera are units which only have AM/FM/Tape, all the CD units are Bose systems which used separate amps mounted on a tray in the trunk.
Dec 28, 2010 | 1998 Cadillac Catera
Car: 2000 Cadillac Catera Radio: Bose Info: Power goes off to radio, fuel door and trunk release. Seems to happen randomly. Any thoughts?
K134 Multifunction relay is on the driver side, inside the dash above the driver's left ankle (area). (2) panels need to be removed below the steering column to access this area. The first is a panel that matches your dash. The second is a cardboard panel with foam padding on it that encompasses the arms holding the brake pedal and accelerator. You'll then need to lay on your back on the floor board, head in first. Look for a gray box about 3" square by 1 1/2" thick. Push it 'up' off of it's mounting bracket to release. Unplug the wiring harness. Plug in new relay and re-mount.
Nov 01, 2010 | 2000 Cadillac Catera
My radio, trunk and fuel door all work sometimes. Where is the Multifunction relay? I believe the part# 90494163 It is a 2000 Catera Cadillac. Thanks
K134 Multifunction relay is under the dash on the driver side. When sitting in driver seat, above your left ankle, it is located behind a cardboard panel. Replacing cures many problems with the Bose radio, sunroof, gas and trunk releases, fog lights.
Oct 28, 2010 | 2000 Cadillac Catera
Where is the freeze plug on a 1998 cadillac catera?
There should be at least 8, depending on the engine. One at the end of each cylinder head. And, one on the outside of the block between each cylinder bore. NOTE- If you're attempting to replace a freeze plug, it does require a specialized tool and alot of B.S.&T.. Not a repair I would recommend to anyone but a professional.
May 23, 2010 | 1998 Cadillac Catera
I just got a 1998 cadillac catera and i been trying to figure it out where iwhs the transmision in this car cause i have to put some oil on it. but i can find it. i would like to know exactly where is it.
The transmission in your 1998 Cadillac Catera is a "sealed unit". Under normal use, it does not require service to the transmission filter/fliud.
If you insist on checking/changing the fluid, there is a fill plug at the side of the transmission that will help you determine the fill level of the transmission.
You warm the transmission to operating temp, and remove that plug with the engine running, then on top of the transmission on the driver's side of the vehicle, there is a red plastic cap you remove. Insert a funnel, and slowly add fluid, watching until it begins to dribble out of the check hole under the car. Reinsert the check plug, then cap the transmission again.
Recommended fluid type is Dexron-VI.
Dec 02, 2009 | 1998 Cadillac Catera
Bose radio from cadillac catera
I have a Cadillac caters 2001 I switch out my stock radio Bose to a jvc deck. The deck work but no sound coming out
Feb 07, 2009 | 1997 Cadillac Catera
Radio unlock code
try taking the unit out. there is a sticker on it with a serial number
call your dealer and tell them that you need a code " service department "
they will ask for the serial number on the radio
once you give the serial number they will look it up and give you the code
do not try to put a " random " code this will lock your radio and you will have to unlock it before putting the code in it.
if the screen shows " code " you are fine, just get the code and voile.
if your screen shows " waiting " the radio is locked up and i will assis you on that matter once you get the code.
May 20, 2008 | 1997 Cadillac Catera
Car Audio & Video Logo
156 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
