Question about Lexmark X1270 All-In-One InkJet Printer
Dell computer does not power up when connected to lexmark printer 3350. I am running windows xp. When I disconnect the usb cord to the printer the computer starts to load then I can connect the usb again and it works.
    Master:
  • 638 Answers
Its not the problem of printer.the jack where u connect your usb wire in your dell pc is somewhst loose and so this problem.make it proper.
Posted on Nov 14, 2008
Lexmark 2600
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aNGYmW. Select your operating system, download and execute the file.
Jan 11, 2012 | Lexmark Office Equipment & Supplies
Cannot get my Lexmark x7170 to scan.
  4. Reboot computer.
Jan 04, 2012 | Lexmark X7170 All-In-One InkJet Printer
Cannot get my Lexmark Z2420 printer working--it has the wi-fi capability, but trying to connect it via USB. Should be plug-and-play but windows makes a sound like it recognizes it, but nothing comes up as...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/9xPHL4. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 26, 2011 | Lexmark Z2420 Printer
How do i connect my printer to my computer
hi
prepare the power cord and USB cables for the printer .
  • you must have minimal Windows XP to operate this printer on a PC - first disconnect printer from your computer.
  • download drivers and applications from link below and save on your desktop of computer.
  • open the downloaded file and run it on your PC.
  • during or after installation is complete, the program will prompt you to connect the printer USB cable to the computer (make sure the power cord i salso connected)
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_CA&locale=en&productCode=LEXMARK_X4650&page=product&frompage=null#1
if you are running a MACINTOSH computer , the same link can be used to access the drivers and applications .
please send me 4 thumbs up , to keep available for future requests
Jan 25, 2011 | Lexmark X4650 InkJet Printer
I have a lexmark x63 and everytime i try to print something it says the device is busy try again later. i click on the printing icon that pops up in the bottom right hand corner of my screen and there is...
hi Cavschick104.
this is all i could find out.
COMPLETELY uninstall the printer and
reinstall it..... It may have occurred if you have your printer connected
during the installation of XP.... it is normal practice to keep the printer
disconnected during an upgrade or clean install.... and then correctly
install it afterwards.
This from the Lexmark site:
Remove the USB cord and the power cord from the back of the printer, and then remove
the USB cord from the back of the computer.
Uninstall the printer/scanner software from the Program menu and restart the system.
Check the part number on the setup CD. If it is not P/N 13H0350, you need to download
the XP driver from the Lexmark web site, www.lexmark.com.
When the PC has restarted, log in as an administrator and insert the setup CD into
the CD-ROM drive
Click OK and Install now.
Follow the setup instructions to install the scanner software. When you see Connect
the USB Cable to the printer on the screen, first attach the power cord to the
printer, then attach the USB cord to the printer, and finally attach the USB cord to
the computer.
Follow the setup instructions on the screen to complete the printer software
installation.
If you want technical support of Lexmark, you can contact us on Lexmark Printer Support 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/bpBgcR
Lexmark Printer 1 866 877 0191 Help Support Service...
Nov 27, 2017 | Lexmark X63 InkJet Printer
Cannot connect a hp psc 2410 printer to dell inspiron 1000 laptop
Try a powered USB hub, this will boost the power in the USB curcuit.
Also ensure that in Device Manager, USB Root HUB, Power Management tab, that the option to let windows turn off the device is unchecked.
May 27, 2009 | Dell Inspiron 1000 Notebook
Computer will not communicate with printer
Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
Aug 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
Lexmark 2500
i need a lexmark 2500 imaging studio...can anyone help me?
Jul 18, 2008 | Lexmark All-in-One Printer with PictBridge
Lexmark X1270 All-In-One InkJet Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
