Pixma 830 - have two, one upstairs and one downstairs. Use the lower one for full faxing. Can I set up the upper one to send faxes only and not recieve faxes? I assume you couldn't set up both to send and recieve on the same line as I assume it wouldn't know which one to send to? Thanks, Ben Korock
  • rottincrotch Nov 17, 2008
    Didn't totally work. Sent Canno another request
    Master:
  • 638 Answers
No.this is not possible from 1 line.but if you use two lines it is possible.
1 for receiving and 1 for sending.such option is there in the printer.
Posted on Nov 14, 2008
My upstairs temperature is 80 degrees and the downstairs is 69 Honeywell focus pro th6000 is set at 69. Why is the upstairs so drastically hot?unit is located upstairs& thermostat is downstairs
if there is no control of air movement between floors and you have it on cooling then any cold air will go down to the lower floor
or alternately if you have it set on heating all the hot air will rise to the upper floor
where is the system located (upstairs or down stairs ) and where is the thermostat located
to get control close any upstairs to down stairs doors or erect a heavy curtain across the stair well
Dec 17, 2016 | Honeywell Heating & Cooling
Hoe do I set up fax functions on Canon Pixma MX452
My incoming fax issue was resolved when I enabled the answering machine function on my phone. All this time my answering machine was turned off. I have yet to send a fax. My model is the Canon Pixma MX452.
Apr 05, 2013 | Canon PIXMA Office Equipment & Supplies
How do i send a fax?
Hi kimberley299,
To send fax using your Canon Pixma MX340 follow the steps below:
1. First, you need to hook up a phone line from the wall jack to the lower phone jack on the back of the PIXMA.
2. Now go into the menu and set your PIXMA to telephone priority mode (manual fax recieve), fax priority mode (auto fax receive) or distinctive (fax) ring/auto answer mode.
3. To send faxes, put your originals in the feeder or on the glass, select fax mode, enter the phone number, and press start.
Hope this helps.
Thank you for using FixYa.
May 09, 2011 | Canon PIXMA MX340 Wireless Office...
Delay fax massege
check the setting and reset it to default.
Jul 02, 2009 | Samsung SF-830 Plain Paper Laser Fax
Canon pixma mp 830 on my fax activity report I
Yes,it means the fax did not go through,it will show OK on the report if it was succesfull
Jun 29, 2009 | Canon imageRunner C3100 Copier
HP 7280 fax interrupts phone calls
Set the fax to MANUAL MODE, you will then have tp press START to receive a fax.
Dec 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
Pixma MP530 Fax Problems
I am having a similar problem. You do have to connect your phone to the jack in the machine in the "Phone" jack slot, as well as have another line out to the jack in the wall in the "L" slot. That is all I know. I am having problems with my voicemail. Either I can received voicemail, and no faxes, or faxes, and no voicemail (fax picks up at specified number of rings). It is EXTREMELY frustrating. The machine is *supposed* to be able to discern between phone calls and faxes..and that is not happening.
Have you come across a solution? Aghhhhh!
Sep 13, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Cannot send out faxes
Directly from the wall, phone line should be connected to to Line port at the back of the printer and answering machine should be connected to EXT. port from the back of the printer. Make sure on the fax setting on the printer that you have all the info already ( ur number and stuffs), communication setting on the printer, drd set to all, ecm to off, v.34 to off, rings to answer 6 and dial tone detection to off. and answering machine distinctive ring pattern should be set to 4rings.
And since you are using DSL make sure that line from wall should have a filter then connect it to LINE port at the back of printer...
Apr 03, 2008 | Epson Stylus CX9400 Photo Printer
Receive faxes
In the receive mode choose tad. The fax will then distinguish between a fax and a call.
Feb 16, 2008 | Brother FAX-575 Plain Paper Thermal
Outgoing Faxes
THE MACHINE IS ET TO DELAYED TRANSMSSION (MAYBE THROUH TOLL SAVE BUTTON ) OR OTHERWISE, PLEASE CLEAR THE MEMORY STORED MESSAGES FOR DELYED SETTINGS, THE PROBLEM WILLL BE RESOLVED IMMEDIATELY HAPPY FAXING OMNIPRESENT
Jul 31, 2006 | Samsung SF-830 Plain Paper Laser Fax
jasbo
jasbo
