Question about Toshiba Satellite A15-S127 Notebook
Shattered LCD screen on Dell laptop
I have found a replacement screen for the laptop, but want to know if I can change it out myself, or if I should pay for someone else to do it...the laptop is a Dell Inspirion 6400 if that makes a difference.
  • Toshiba Master
  • 4,806 Answers
Yes you can replace the screen yourself but it can be quite difficult, you have to remove the panel accross the top of the keyboard, remove the keyboard and unplugg the monitor plug and wireless ariel wires locate the screws that holds the lid to the base and unscrew, remove lid.
Now you have to unscrew the bezel (front plastic cover) the screws are located under the rubber screw covers, take care when splitting the bezel from the lid, (use a small flat head screwdriver if you have to), this will exspose the screen itself, disconnect the power plug, behind the screen you will find a ribbon cable remove this cable with great care................ job done! now you can replace the screen and put it all back together
If you think that this could be difficult for you, them i suggest a repair engineer to do the job for you but it will cost
Posted on Nov 14, 2008
Dell Inspiron 1545 Broken Screen?
The LCD is definitely shattered, looks like pressure was applied from the back of the screen (Pressed on, laid on etc) and the LCD will need to be replaced.
Several are available on Ebay
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+1545+LCD&_sacat=See-All-Categories
Service instructions are here
http://support.dell.com/support/edocs/systems/ins1545/en/SM/display.htm#wp1183775
Feb 07, 2010 | Dell Inspiron 1545 Notebook
My laptop was dropped & now the screen looks like it has been shattered. When it's off, you can't see it but turn it on & looks shattered with different colors.
You will just have to search for a new screen. They are not that difficult to change out. The people that said under warranty send it back. Well unless you purchased accident insurance on it, a cracked lcd is not covered. LCD just doesn’t crack from sitting and they will not cover them in most cases. It is considered miss-use or abuse. Replace the screen. If you are past your warranty, check eBay. Sometimes you can get a used screen for cheap. If you do that try to get it in the whole lid assembly, they are easier to replace that way. Check out the website for screens: http://www.screentekinc.com/
Thanks for contacting fixya.com
Nov 25, 2009 | Compaq Computers & Internet
As the result of blunt trauma to the monitor it is half green and the pixels that should have been there look like they are on the bottom of the screen. Is this fixable or should I replace the monitor? If...
If the LCD screen has a cracked or shattered glass then the LCD screen needs to be replaced, it is beyond repaire.
There are LCD replace available on the Internet, it needs to be one that suits your model laptop. LCD Parts can service, have parts and DIY info use this link to their WEB site :-
www.lcdparts.net
Sep 26, 2009 | ASUS Eee PC 1000HA Notebook
Have a broken lcd for a dell inspirion 1500 help!!!!!!
Is your laptop under warranty/extended warranty for accidental damage? If it is inquire from Dell about the procedure to send it to them and getting it fixed click here to get the contact info. If its not under warranty you can inquire Dell for your area dealer/repair shop to get the LCD replaced.
You can also get an estimate for replacing the LCD screen from your local area repair shop to have an idea. In most cases I have seen the technical job performed by the manufacturer is far more superior (Please do not take me wrong, its my experience).
Sorry could not be of much help then to guide you to a right path.
Hope that helped!
Nov 06, 2008 | Sony VAIO V505BXP Notebook
Screen was shattered
notebooks like toshiba's are hardware and software specific. Other hardwares will work but not guaranteed to provide full and satisfying results. Drivers may fix the problem. But I suggest you get a orginal Toshiba LCD
Oct 11, 2008 | Toshiba Satellite A15-S127 Notebook
Hp pavilion dv 1000 screen replacment
Dear lotaman, I have searched the world to find an exact guide for your monitor but it is impossible. Neveretheless I have found the following guides and they should be more than enough to complete the task in hand anytime.
TIP: The ZV5000 looks and is very similar to the HP DV1000 screen so I would start from there. All guides are very nicely explained.
Please remember to remove the battery before you do any work with the laptop.
Regards
Removal Step by Step HP ZV 5000 LCD Screen
http://www.instructables.com/id/SJFP10QF49G0AOR/
Removal Step by Step Compaq V2000 LCD Screen
http://www.screentekinc.com/lcd-removal-instructions_en,compaq.shtml
Removal Step by Step Compaq DELL LCD Screen
http://www.laptoprepair101.com/laptop/2007/02/03/repair-notebook-lcd-screen/
Mar 25, 2008 | HP Pavilion dv1000 Notebook
LCD PROBLEM
if you can get hold of a second Dell Lappy (same model) which is broken (not broken screen) you can swap the broken screen for the good one. It means opening the laptop, but due to the smashed screen the warranty is invalid anyway. There is usually 1 or 2 cables coming from the screen 1 for signal and 1 for power. you can explore the broken lappy to see how the screen connects,
Oct 08, 2007 | Dell Latitude C640 Notebook
Toshiba Satellite A15-S127 Notebook Logo
147 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
