Question about Acer Aspire 5002WLMi Notebook
My acer aspire one has a it's display is narrowed
I just bought a acer aspire one and from the moment i opened it the display won't fit all in the screen,atwo 2inches part of the monitor is blackandond 2 inches from the lower part zoomes zooms the opper two inches from the upper side of the display, it's strange cause in that six inch leleft of the display the resolution is normal and by movig the pointer at the edge of the screen the display slides and shows me the rest of the display, i know that i didn't explained myself well but it's a very weired problem. should i put a video on youtube of the problem so everybody could see it and understand better what i meant?
  • 1 more comment
  • Anonymous Jan 03, 2009
    same problem here. sometimes if i use the f2 function on start up then exit without saving changes (after making none) it resolves. suspect it might be related to low battery conditions or power issues, but that's just a hunch. also restored the operating system once (linux) which did help for a while...
  • rasul1989 Feb 04, 2009
    me again, i solved the problem by going to the shop where i bought it and got another one in exchange, and the strange thing that this new one has more hard drive space than the broken one :D good for me, by the way thanks for the help
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Go into the device manager and see if the display adaptor is installed. If so then it could be a corrupt driver. If you don't see it then there might be a question mark int there with a video controller name next to it then that would mean no drivers are installed. What OS are you running and I'll try and find a driver for you.
Fit my Acer Aspire 3000 ?
akku Acer Aspire 3000 100 percent compatible with you Compaq Presario CQ61. I bought two Acer Aspire 3000 batteries from http://www.pcakkus.com/acer-aspire-3000.html two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Nov 30, 2012 | Computers & Internet
When i open video and music no sound and display image
Try using VLC or make sure your video player has required codecs installed. Have you tried other videos ? is it all videos that won't play or just one ?
Jun 18, 2012 | Acer Aspire 3680 Notebook
Acer Aspire 5732Z won't turn on - the light comes on for a few seconds and then turns off - whilst the light is on the disk drive will open - the screen doesn't show anything
Could be bad ram,hard drive or possibly a bad display panel or video card.Try using different ram and removing the hard drive then try it.Also,connect it to an external display and see if it shows video or not.If after trying these things it still isn't showing let me know and i'll try to help more.
Nov 22, 2011 | Computers & Internet
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
Hello! I have an acer aspire one netbook D257. I won't open. I was using it for a while then it restarted for updates. While waiting for it to restart, i had the need to go already so i just closed the...
Please try removing battery for a moment (getting cold) and install it again, don't forget to connect charger, after the charge is completed try to turn it on, if there's no motherboard failure the computer should work normally, but if not, maybe you have a "fried" motherboard that needs to be replaced.
Aug 11, 2011 | Acer Aspire One PC Notebook
Would an acer aspire 5610 screen fit a 5630 acer laptop
probably, most of these screens are bought in from a different maker, i put an acer travelmate screen into a toshiba but be carefull some of the wireing maybe slightly different, if your not absolutely sure take it to SOMEONE WHO IS.
hope this helps
Sep 14, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Can i use the lcd of aspire 4315 to my aspire 5050
dear lcd desplay are same in every model just you need the same size of both. means if you have 15' then you fit only 15'.and if you buy your model lcd there is no any problem because right now problem with cericuit of lcd
Jan 19, 2010 | Acer Aspire 5050-3242 Notebook
How do I remove the display screen from an Acer Aspire 6930-6235 laptop? I have taken all the visible screws out but the bezel won't pop out at the bottom (where the hinge is). There appear to be more...
Unfortunately there is no manual from acers site on this laptop so it would be hard to tell.
If your trying to remove the plastic bezel just above the keyboard, there can be screws on the narrow side on the back, screws on the bottom of the laptop combined with plastic clips along the edges of it. Also could be screws behind battery if its located at the top on the back. I use these flat plastic tools for taking apart phones and mp3 players they work great for laptops
I just watched a youtube video showcasing the laptop and just watching that I would say there are screws under the battery. With the LCD closed you will probably have to unclip the bezel from the back end of the laptop as well as with the LCD open there are probably a lot of clips a long the edge.
Screws first then along the narrow end on the back then the rest of the clips should be easy to pop.
Nov 04, 2009 | Acer Computers & Internet
Acer orbicam- aspire 3680
Whenever it displays this try and reboot your system and if the problem persist, then t to reinstall the driver for the orbicam. good luckk
Jun 12, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5002WLMi Notebook Logo
194 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
