Question about HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop
Dvd player won't open
My DVD rom player won't open. My wife isn't sure if there's a cd in it. I've tried the paperclip in the hole, but that doesn't work. It just makes a couple noises and the slot doesn't even open a bit. I've tried tipping the computer at different angles, but nothing happens. I can't see how to get the plastic cover off the computer, as there are no visible screws. The computer is a Dell desktop. What else can I try?
  • jrhadley171 Nov 16, 2008
    Thanks for the replies. No, the player won't eject when I try to open it under my computer. Yes, the light's on and it flashes a lot with whatever method I try to open it. When I use the paperclip, I feel it pressing against inside, so I push harder and the part I'm pressing gives way, the light flashes, the machine whirrs, and still nothing happens. I guess my next step is to remove the rom. We'll see how that goes.
    Sergeant:
    Champion:
  • 275 Answers
First of all is the system under warrantty?
secondly the paper clip should work in any case
its either u are not applying proper presure or the clip is short ... the clip should be atleast 2 inches long and when u insert the clip at some point u will feel there is no place inside thats the time u apply presure and it should open ... its a way to open the tray which works on mechenical parts so there is no point of failure with them
Posted on Nov 14, 2008
I had the same problem. I got here by accident (google).
I'm ecstatic--I did solution #1 (click eject) and it worked!!!!!
Thanks much!!!
Posted on Dec 06, 2008
    Scholar:
  • 121 Answers
Have you tried to open from windows itself.....rite click the rom under my computer and select eject
if this doesn't help.....is the light on on the rom itself when you try to open??
here is a step by step guide for you to remove the Rom.......take the ROM out take the top cover of the Rom out inspect the Rom........is there a CD ...Remove the CD if its there put everything back together...test your ROM
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=uk&docname=bph07164&dlc=en&product=3199127
keep me posted
Cheers!
  • Asish Sharma
    Asish Sharma Nov 17, 2008
    hope it worked for you!
    keep me posted
    cheers
Where is the hole located to open dvd cd door
The small hole to put a pin or paperclip into is on the face of the DVD tray. It is there, look hard for it.
Mar 02, 2014 | E-Machines emachines (emachinees) CD-ROM...
Manually open dvd tray
Look next to the DVD tray to find a small hole. Once you have found that hole use a small paper clip and straighten one part of the clip. Carefully insert that extended paperclip into the hole, if you meet resistance apply gradual pressure until the tray opens...if the tray does not open...Remove the paperclip end (straighten the paperclip again and reinsert the straight end of the paperclip straight into the hole. Once you meet resistance press gently again, if you feel the paperclip continue into the hole without bending, continue pushing until the try opens. This is the correct way to open a CD/DVD/Blu-ray tray with or without the power on.
If you need further assistance, please ask...
Oct 22, 2012 | Daewoo P480 DVD Player
The DVD/CD drive won't open
There's a little hole in the front of the dvd drive (it may be behind the flip down cover). Stick a paperclip in the hole while pushing the eject button.
Jan 21, 2012 | ASUS Computers & Internet
Dvd drive won't open
you can try opening it with paperclip if it's stuck. Straighten the clip and locate a small pinhole on the drive it and insert the clip in. You might need to push the paperclip in an out a few times to eject the drawer.
Jun 19, 2010 | Computers & Internet
Cant remove dvd from burner - appears dvd is corrupt
If you have a desktop pc,open the flap that covers your burner.On the front of the burner itself you will see a small pinhole.and by using a strong paperclip push the end through the hole and it will open your burner.You may have to push hard .Hope this helps you.
Regards Bill
Apr 30, 2010 | BenQ (5232X-0C1) CD-RW/DVD-ROM (Combo)...
WHEN I PRESS THE OPEN/CLOSE BUTTON THE DISC TRAY DOES NOT OPEN. HOW CAN I GET THE DVD OUT OF THE DISC TRAY?
Look for the small hole in your dvd rom. This hole usually can fit a paper clip. Push and hold the paperclip inside the hole to open the dvd tray.
Dec 28, 2009 | Samsung DVD-R135
Cannot play DVD and stuck CD in the system! how
Most Philips DVD player and recorders have a manual release on the bottom of the unit look for a slotted hole on the bottom put a small screw driver in the slot and slide across this will release the tray.
Some older models have the paperclip hole like on all PC DVD-ROMS this will also release the tray if you have it
Dec 12, 2009 | Philips DVDR3380/05 DVD Recorder
My cd draw is stuck in the cd drive. How do i get it open
you should find a paperclip and straighten it out, on the front of the CD drive there will be a small hole just big enough for the straightened paperclip to fit in. Push it in until you feel tension and it should start to manually open.
Sep 12, 2009 | Dell Inspiron 6400 Notebook
Dvd-rom drive doesn't open
Sounds like the drive eject motor is broken, maybe time/easier to by a new DVD Burner?
Mar 20, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Wont eject
Hi, If there is a disc in the drive it's possible that it has become jammed and therefore will not allow the door to open. If you get a large paperclip and bend out one side you will find there is a little hole in the front of the drive. Insert the straightened end of the paperclip carefully into the hole until you feel resistance. Gently but firmly you will need to apply an amount of force and the door will pop open. Remove the disc and restart the computer, hopefully the drive will now respond as required.
If not then possibly the door mechanism band/spring has become too loose or broken. At least these days CD/DVD drive are not too expensive to replace.
Let me know how you go,
SeaJade
Jan 27, 2008 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop Logo
1,282 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
