Panasonic SA-PM30MD is displaying LOCKED when in "Digital-In" sound mode. Sound stops, not sure if this is due to the "Locked message" and if it is how to fix this problem.
  • Anonymous Nov 23, 2008
    same thing happened to me.
  • Anonymous Feb 20, 2009
    My daughter was fiddling and now I have the same problem!!!
  • 56 Answers
If the sub has a volume control, turn it down then turn up the volume on the amp to the very high volume you mentioned. If it still has very low muffled sound, then we know the problem is about the amp.
Posted on Apr 24, 2007
  • 4 Answers
SOURCE: F61 error in my SA-AK25 Panasonic Audio System
Posted on Mar 27, 2008
  • 4234 Answers
SOURCE: Technics SA-DX950 has lost digital sound
This may sound like a silly check, but verify that the tape monitor switch is not engaged. What is the quality of the sound when turned up? Is the cound clear or raspy?
Posted on Dec 04, 2008
SOURCE: Panasonic DVD-R30 Displays ''locked''
My problem was solved by holding the back button open button and pause button at the same time for 3 seconds.
Posted on Feb 16, 2009
  • 8 Answers
SOURCE: no sound in hdmi mode unlock flashes on display I get sound in cd
Its asking your permission to unlock the setup menu. When you hit setup, and it says "unlock," you have to hit one of the navigation arrows on the remote control. Once you have unlocked the menu, you can assign the audio to that HDMI input.
Posted on Sep 07, 2009
2wd vs AWD
Page 13 of owner's manual says:
(if equipped):
Illuminates when the AdvanceTrac
system is active. If the light remains
on, have the system serviced
AWD locked (if equipped):
Illuminates when all wheel drive
(AWD) is engaged/activated. If the
light continues to flash, have the
system serviced.
Page 224:
Your vehicle may be equipped with an All Wheel Drive (AWD) transfer
case. With the AWD option, power is supplied to all four wheels
automatically with no need to shift between two-wheel drive and
four-wheel drive. If your vehicle is equipped with the AdvanceTrac
stability enhancement feature, you can change AWD modes, if desired,
by selecting AWD options through the message center.
For the lubricant specification and refill capacity of the AWD transfer
case refer to Maintenance and specifications chapter.
If your vehicle is equipped with AWD, a spare tire of a different
diameter than the road tires should never be used. Such a tire
could make the vehicle difficult to control as well as result in damage
to driveline components.
Utility and four-wheel drive vehicles are not designed for
cornering at speeds as high as passenger cars any more than
low-slung sports cars are designed to perform satisfactorily under
off-road conditions. Avoid sharp turns or abrupt maneuvers in these
The following sections, Normal operation, Autolock operation and
Disabling AWD, apply only to vehicles which allow the driver to change
AWD modes through the message center.
Normal operation (vehicles equipped with AdvanceTrac
During normal operation:
• the AWD system is in AWD AUTO mode (AWD LOCKED will
illuminate in the message center for four seconds when you first start
your vehicle). The AWD LOCKED indicator in the instrument cluster
will also come on.
• AWD AUTO mode can be overridden by pressing SETUP in the
message center. When you first press SETUP, AWD <AUTO> will be
displayed, then if you press RESET within four seconds of pressing
SETUP, AWD <LOCKED> will be displayed. AWD <LOCKED> provides
power to all four wheels constantly which allows you to operate your
vehicle in severe winter or off-road conditions such as deep snow, ice
or shallow sand. It is not recommended that you use AWD <LOCKED>
on dry pavement.
Page 225:
• AWD <LOCKED> can be cancelled by pressing RESET in the message
center. (The AWD LOCKED display in the message center will then
turn off and the display will return to AWD <AUTO> for four seconds
when the shift is complete.)
Autolock operation (vehicles equipped with AdvanceTrac
If the AWD system begins to overheat, the system will place itself in the
Autolock mode:
• the AWD LOCKED indicator light will illuminate in the instrument
cluster and AWD DISABLED <LOCKED> will be displayed in the
message center.
• AWD LOCKED will be displayed in the message center for four
seconds and a warning chime will sound. This condition may clear
without any action being taken by the driver.
• the AWD LOCKED indicator light in the instrument cluster will turn
off when the AWD system cools down.
• When the system is sufficiently cooled down, AWD AUTO RESTORED
will appear in the message center for four seconds and a warning
chime will sound.
Disabling AWD (vehicles equipped with AdvanceTrac
When a problem is detected in the AWD system:
• the AWD LOCKED indicator light in the instrument cluster will flash
eight times every two minutes in the message center.
• The message center will then display AWD DISABLED for four
seconds, then SEE OWNER'S MANUAL. A warning chime will also
sound. The warning displays and chime will continue until RESET is
pressed (which will clear the message from the display).
• AWD LOCKED can still be engaged by pressing SETUP (the message
center will display AWD <DISABLED> LOCKED), then pressing
RESET. The AWD LOCKED indicator light will illuminate in the
instrument cluster and the message center will display AWD
• To disable AWD, press RESET. The system will go back to AWD AUTO
mode momentarily, then the AWD LOCKED indicator light will flash in
the instrument cluster eight times every two minutes. The display will
then show AWD <DISABLED> LOCKED for four seconds and then
turn off.
Page 226:
• If a serious problem occurs with the AWD system, the AWD LOCKED
indicator light in the instrument cluster will flash 10 times every two
minutes. The message center will also display CHECK AWD and a
warning chime will sound. You can press SETUP to check the status of
the AWD system (which will display AWD <DISABLED> LOCKED),
but the AWD system will be disabled until the system is serviced.
Driving off-road with truck and utility vehicles
AWD vehicles are specially equipped for driving on sand, snow, mud and
rough terrain and have operating characteristics that are somewhat
different from conventional vehicles, both on and off the road.
When driving at slow speeds off-road under high outside temperatures,
use 1 (First) gear when possible. 1 (First) gear operation will maximize
the engine and transmission cooling capability.
Under severe operating conditions, the A/C may cycle on and off to
protect overheating of the engine.
Nov 30, 2013 | Lincoln Navigator Cars & Trucks
Panasonic Home T, sa-pt760, message LOCKED
While the unit is on, press and hold the play button and the power button, display should say unlocked. If this doesn't work, try it using the stop button and power button.
Apr 03, 2013 | Panasonic Audio Players & Recorders
I have a blue ray Prayer connected to my Panasonic SA-HE100 via a toslink digital audio cable. I don't get 5.1 surround sound. I do get stereo but not 5.1 where the back speakers sound. Any...
do one thing
1. press and hold DIGITAL INPUT button on the remote( will display AUTO--PCM FIX--DTS FIX)
2. select AUTO among them. and the try
Jan 31, 2011 | Panasonic SA-HE100 Receiver
Lost instruction manual for Panasonic MD Stereo System. SA-PM30MD. How can I find a new one online
do a google search , operating manual for panasonic md stereo sa-pm30md, check out the links for a free download, if not you can go to for 16.00 dollars download it. hope this helps.
Nov 09, 2010 | Panasonic Audio Players & Recorders
Panasonic SA-HE9 amp / Sky+ optical
i Have a Panasonic SA-HE9 and i cant get the optical cable too work on my Playstation 3 to get sound from there. can any 1 help me with this?????
Feb 19, 2009 | Panasonic SA-HE90 Receiver
Panasonic SA-HT520 error message
The system has a locked / unlocked toggle sequence on the main unit by holding down stop (or Play) and then tapping the power button. Use this sequence lock or unlock the DVD / CD drawer.
Sep 20, 2008 | Panasonic SC-HT520 System
Unlock panasonic sc-rt 50 home theater
theater sound system sa ht540 region hack
Mar 18, 2008 | Audio Players & Recorders
Locked sa-ht67
I hope you've already unlocked your DVD player by now, but for all those searching after you, I got the solution from Panasonic.
Make sure the device is on the DVD/CD mode. Press the Stop button on the main unit and the >=10/Enter button on the remote control simultaneously. You will see the word "Initilize" on the device, and at that point it is unlocked.
Dec 11, 2007 | Panasonic SC-HT67 System
387 people viewed this question
