Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
  • 5 Answers
I took the fireplace's direct connect ignition spark box out of the bottom of the fireplace, its behind the bottom vents and bought one on line and replaced it, easy as pie. Best of luck.
Posted on Mar 07, 2015
  • WINDY Mar 07, 2015
  • Leisure Master
  • 3,161 Answers
Hi clean pilot light check out thermocouple might need new one
Posted on Feb 25, 2010
Pentair mastertemp 250 NA. heater will not fire, no error codes. starts fine, gas flows, igniter heating but still will not fire. It has a new valve, gas pressure entering valve from new regulator is 8.35...
All appearances - No fuel to ignite!
evrything else looks good, proper gas pressure, proper volts at igniter, etc - it should ignite! If fuel present, heater should Fire!
make sure all valves are open.
Gas valve is ON
AND purge any air from gas line.
IMPORTANT ****. If you bled gas line, don't try to ignite for a few minutes. Allow gas to dissipate first, use a fan to help.
Mar 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
Remote controlled gas log fire will not ignite,relaced batteries,cleaned logs etc,worked a couple of times then refused to ignite again ,can hear ignition ticking but cannot hear any gas coming through ,...
If you're using propane gas, the banging noise you hear is air in the gas line, which means either your tank is empty or the the tank regulator is frozen (if it's ,below freezing in your area). If the tank regulator is frozen, soak a bath towel in hot water and quickly place it around the regulator. It should thaw fairly quickly and the gas will start flowing again. However, you may need to purge the air out of the gas line to gas log burner. Rather than using the electronic ignitor, do it manually, until you smell gas, left off the control knob and wait 5 minutes and then try lighting the pilot electronically.
If you're using Natural Gas, it may still be a pressure problem to the burner. You'll need to have that professionally checked.
Hope this helped to solve your problem.
Feb 27, 2011 | Heating & Cooling
Pilot light on baxi bermuda 51/5 electronic, gas fire wont ignite, calling for heat but still doesnt ignite or click
Sometimes the thermostat wire (not sure of the technical name) gets oxidized and can't sense the heat (it's there as a safety measure so that when the pilot light goes out, the gas shuts off). If it isn't to hard to get to, sometimes you can use some aluminum foil to clean the wire so that it senses the heat of the pilot light flame. Make sure the main unit is off, and let the unit sit for awhile to make sure there is no residual gas hanging around. If this doesn't work, you might have to get a specialist out to replace that piece. Hope this helps.
Feb 17, 2011 | Heating & Cooling
The raypac 2100 pool heater turn on but when you go to fire it al
If you hear it sparking, verify the spark is happening INSIDE the combustion area and not shorting out at the ignition module. Also verify you actually have gas available and the gas valve is turned on...
Apr 08, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Gas Dryer. Heat for only one burn cycle.
Try vacuuming out the intake and exhaust of the burner to remove any lint or other debris. If no help, the main burner may need to be replaced.
Feb 03, 2010 | Dryers
Sometimes does not ignite.
you have a bad timer rotory dial that will not pick up the signal for the ignitor to fire
Jan 30, 2010 | Kenmore 73952 Gas Dryer
No flow of gas to fire after pilot light is lit and turned on.
i have had a legend vantage slide control gas fire for about 5 years.this problem is i believe a blocked oxy get which is a failsafe device to prevent a gas leak.can be remedied easily by a gas safe engineer.
Jan 07, 2010 | Vantage Televison & Video
I have a model 3E381E overhead heater. the pilot tries to lightbut there is no gas coming thru to ignite. there is sufficiant gas in place as there is a water heater directly below running off the same gas...
you have a clogged pilot orifice you will need to remove from valve and apply pressure to it to clear. compressed air with a fitting to make sure it goes thru the tube
Dec 04, 2009 | Heating & Cooling
Heating & Cooling Logo
187 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
