Back to:
Tags:
Toshiba 32AF43 32
TV does not respond to Remote (by 6 users)
posted by Yeye on Nov 21, 2006
I have a Toshiba 32AF43 of 32". Became having trouble with remote control, I replaced batteries and even got a new remote of same model. By now, just sometimes respond, but so many others does not respond to Remote Control. Does anybody knows what to do? thanks.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by Guest, posted on Apr 22, 2008
TV responds to physical hand control but will not respond to remote control .Model type is 36HF71.
Comment by Jeff T, posted on Apr 06, 2008
My remote has stopped as well. Is taking the shell off easy?? Anything I need to know before I attampt it?
Comment by Guest, posted on Jan 20, 2008
Have had same problem since new. They sent me new one that one was no better.
Comment by jennifer49, posted on Jan 12, 2008
My Toshiba and Tivo remotes have stopped responding to Toshiba 32af43 after working fine for years. Cannot even bring up the Toshiba menu.
What is a RF LED? Can it be fixed.
Comment by Guest, posted on Dec 29, 2007
SAME PROBLEM
Best Solution
FixYa! (100)
Terryfic
Rank:Guru Guru
Rating: 87%, 1396 votes
Correction...solder bad connects on IR DETECTOR LED =
Infra-red detector light-emitting diode...located on front edge
of circuit board...if soldering does not fix,replace LED.....I can
provide part number.............................T.
Comment by Terryfic, posted on Jan 12, 2008
Part # 23009490 IR detector
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on TV does not respond to Remote:
I don't want to Accept this solution
Solution #2
posted on Mar 23, 2007
Helpful (85)
Mrov
Rank:Wiz Wiz
Rating: 82%, 104 votes
possible defective rf receiver led defective in the tv.
Thank You!
Solution #3
posted on Feb 05, 2008
Not Rated (0)
Brainbox
Rank:Master Master
Rating: 75%, 6 votes
Dear Mr.yeye,
There seems to be a problem with the IR LED of your television. solder the connections if any of them is cut. Also there can be loose connections. its better to contact the retailer from whom you purchased this tv
Thank You!
Can you Help with these Standard Televisions problems?
Toshiba 32AF43 32" TV
Our Toshiba 32AF43 looks great on some channels, and...
Toshiba 32AF43 tv bought 4 years ago. Last couple of weeks...
Does this tv need a digital set top box (LG 32AF 43 )...
My toshiba T250V61 is a few years old, has always worked...
TV is 2.5 years old, works perfectly for an hour or two,...
Loading problems.
Repair Service
Find Standard TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
