Question about Refrigerators
Kemore brand - freezer works fine, refrigerator not cold,
What part do I need to fix it? Model 106 53602201
  • choyterry Nov 17, 2008
    Thank you very much. My found the problem before I read your solution but you are right on. Thanks again.
    When the panel is opened I saw too much frost on the evaporator and ice built up on the evaporator, the air duct was only partially connected to the fresh food compartment. The defrost system was the problem before due to the drain line was block by the ice and water found on the floor twice a day. I turned off the unit and connected the air duct properly. It is all working now but I still worry that the defrost system problem may come back.
    Scholar:
  • 66 Answers
The fresh food side is cooled by the freezer side through a duct between the two. It will have a small door that opens or closes depending on how cool you want the fresh food side. The door opens more as you adjust the temp for the fresh food side colder. If the duct is blocked in any way, then it would be like setting the temp setting for the fresh food side warmer and warmer. The freezer would be cold and the fresh food side would be warm. Set the temp to midway. Check for any obstructions to this duct. The evaporator fan is what moves the air to the fresh food side.. If the evaporator fan is not working, this could vary well is the problem. You may have to check the evaporator coil to see if it is frosted up enough to restrict air flow over the evaporator and to the fresh food side. If this helps you find your problem, please rate me. If there is anything else I can help you with, please ask. I am here to help you.
Posted on Nov 15, 2008
  • Charles Caldwell Nov 17, 2008
    I am not sure what you found but what ever it was, there is probably an underlieing problem. If you would let me know what you found. I would be happy to help in finding the original problem that caused your fresh food compartment to be too warm. Too much frost on the evaporator, ice build up on the evaporator, the air circulation stoped by some type of blockage. The defrost system failure. There has to be something that caused this. I would be happy to help.
The blower in frig is not working, frig is warm freezer is working fine, we have vacuumed all area & unplugged for serveral hours. please tell us what else we can try.
all it does is blow cold air from the freezer into the fridge section,open the freezer door,you should hear the fan blowing,no fan fridge will be warm bad evap fan motor,also send the brand name and model number,some machines have dampers in them if the damper is bad it blocks the cold air from entering the fridge section,send model number and brand name,
Sep 25, 2011 | Refrigerators
Have a kemore elite. Keeps making a buzzing noise every 4 minutes. The bottom feezor is cold but not cold enough to make ice, even with thermostate on high. The refrig top is fine no problems....
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 03, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Our Kemore Elite French Door Fridge is not working. The Freezer is freezing but the fridge is not cooling at all.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Jul 22, 2010 | Kenmore 77552 Bottom Freezer French Door...
I have a kemore elite fridge wont get cold
It can be the defrost timer,defrost element or defrost thermostat or a blocked vent into the fridge
Aug 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kemore Refrigerator MODEL# 2535808789A is not cooling.
Thank You for having your model number ready, Could you remove the grate on front and bottom of refrigerator to expose the defrost timer. In the opening on front turn the timer slowly turn clockwise until you hear a click or change in operation of refrigerator. Let me know, Sea Breeze
Mar 21, 2009 | Kenmore Refrigerators
MY refrigerator is running but is not getting cold.
Hi thanks for the question. check the freezer ,is the fan running. check the back freezer wall for frost build up. pull fridge from wall. remove back panel. clean all coils . thanks the appliance doc
Oct 06, 2008 | Maytag MSD2454G Side by Side Refrigerator
Kemore Refrigerator not working properly
need model # and type... what do u mean my too cold what the temp?
Nov 15, 2007 | Refrigerators
Refrigerators Logo
242 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
