Question about RCA TH1101 MP3 Player
It wont connect to windows media player
Plug it in and it says connect a device
  • 8,596 Answers
If you have Windows Media Player 11, update the firmware at www.rcapearl.com
Posted on Jan 09, 2009
MP4 player
The first time you connect a device that plugs into a universal serial bus (USB) port, Windows automatically installs a driver for that device. After a driver is installed, you can disconnect and reconnect the device without performing any additional steps.
Before you install your device Check the instructions included with the device to determine whether a driver should be installed before you connect the device. Typically, Windows detects a new device after you connect it, and then installs the driver automatically. However, some devices require you to install the driver before plugging the device in.
Also, while most devices that have power switches should be turned on before you connect them, others require that you turn them on during the installation process. Because of issues like this, it's a good idea to read the instructions included with a new device before you connect it.
If the instructions that came with your device contradict the information in this topic, follow the instructions that came with the device.
Plugging your device in If your USB device1.gif uses a power cord, you should connect the device to a power source and turn it on before connecting it.
Next, determine which USB port you want to connect your device to. If your computer has USB ports1.gif on the front, consider using one of those if you plan to frequently connect and disconnect the device.
YOU MUST NOW " SYNC" YOUR DEVICE WITH MEDIA PLAYER THIS IS HOW TO DO IT.
Set up a device to sync in Windows Media Player You can use Windows Media Player to copy music, videos, and pictures from your Player library to a portable device, such as a compatible MP3 player. This process is called synchronization or syncing.
There are two methods for syncing items to a device: automatically or manually. When you connect a device to your computer for the first time, Windows Media Player selects the sync method that works best for your device, depending on the device's storage capacity1.gif and the size of your Player library. After your device is set up the first time, you can choose a different sync method if you want.
  1. Start the Player, turn on your device, and then connect it to your computer. If prompted, select the AutoPlay option to sync the device using Windows Media Player.
  2. Do one of the following:
    • If the Player has selected to sync your device automatically, click Finish. When you do so, the Player will sync your entire library to your device. After that, your device will automatically sync every time you connect it to your computer while Windows Media Player is running.
    • If the Player has selected to sync your device manually, click Finish. Then, in the Sync tab, you can select the files and playlists you want to sync manually. For more information, see Sync manually in Windows Media Player.
Comment by Christalnet, posted on Feb 12, 2008I HOPE THIS IS HELPFUL.... PLEASE CONSIDER USING A LIVE CHAT BOX OR YOU CAN INSTANT MESSAGE ME FOR HELP IN DOING A WALK THROUGH IN REAL TIME, YOU MAY CONTACT ME USING........
MSN MESSENGER- CHRISTALNET@HOTMAIL.COM
YAHOO MESSENGER- CHRISTALNET@YAHOO.COM
OR I USE ICQ # 147169792
Comment by Christalnet, posted on Feb 12, 2008You can find a nice walk through on transfering music manually and installing third party apps for this purpose by clicking HERE
Feb 13, 2008 | Microsoft Windows Vista Ultimate Edition
Media Windows player recognizes this device but all I get is erro
you have to drop and drag it wont sync up with a media player and make sure to take the battery out before you connect
Apr 08, 2009 | GPX MW3836 MP3 Player
My sansa wont be read by the computer
What i would recommend you to do is to uninstall the device and reinstall it back...to uninstall it...assuming that you are running windows xp...click on start, right click on my computer and go to properties..you should have your system properties open then click under hardware then device manager...look for the sansa device..it usually located under portable device..if its not showing there i would recommend you to look for under disk drives and see if its there..right click on the device and click on uninstall...after you unintall it unplug your device from the computer....Then follow this link below to download the porting kit...http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en .Then check the mode of yuor device to make sure it sunder MTP not msc...To check the mode go under menu, settings and choose usb mode...After you check the mode open up your windows media player click on tools, options and click under privacy...clear the history and caches...after you finish you can plug the device on the back of the computer not the front then windows should recongnize it and it should work properly..if that doesnt solve the problems upgrade your windows media player to 11 even though you have done that already..and try to reconnect your device..make sure you have it connected on the back USB>>>
And if that doesnt work try to obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerre
Dec 26, 2008 | SanDisk Sansa Connect MP3 Player
Cannot delete the songs on mp3
I do mine through Windows Media Player
1)Plug in Sansa
2)Open up Windows Media Player and wait for the Sansa e250 icon to show up under the library. First time, might say 'What device is this' or 'Autoplay'-for autoplay,you click 'sync media files to Sansa e250 using WIndows Media Player'
3)When library shows, click 'Sync' if it is not already there.
4)Just simply click and drag the songs you want from the computer library to the list pane on the side.
5)Once your done, click 'Sart sync'
TO DELETE
1)Plug in
2)Wait for the icon under Library in WIndows Media Player
3)Go to Songs under Sansa e250
4)Right click desired songs and choose Delete. You only want to delete from Sansa e250-nothing else
~loli~
Dec 23, 2008 | SanDisk Sansa e250 MP3 Player
My Phillips Go Gear 8GB MP3 player wont sync music
Windows Media Player 11 ruins this player. Uninstall Windows Media Player 11, and roll back to Windows Media Player 10. Then use version 10 to sync songs to your device.
Sep 11, 2008 | Philips GoGear HDD1830 MP3 Player
Device manager wont detect my gogear HDD1630/17 even though i recently updated the software and driver, also my device is frozen on "Please connect player to pc". I can't even get it back to the menu...
I was experiencing this similar problem, and from my research so were alot of other people, what finally worked for me was this:
  • Update all the software on your computer via Phillips site
  • Open the Philips Device Manager
  • With the device connected and the 'connected to pc' screen showing on the GoGear, do a 'soft reset' by holding the Power Off + Volume Up buttons for a few seconds
  • As soon as the device restarts itself, hold the Volume Down button, the computer should now recognize the GoGear
  • Follow the onscreen directions to Repair the device
  • Thank the intarwebs.
May 21, 2008 | Philips GoGear HDD6330 MP3 Player
Cant detect player
Do you have media player 11 installed? It wont work with media player 11.
Also make sure you have no traces of media player 11. When you roll back from 11 to 10 it still leaves a trace of media player 11. Check your add/remove programme setttings carefully to make sure there is no reference to media player 11. If there was and you have removed it, restart your computer.
Nov 10, 2007 | Samsung YP-K3 MP3 Player
Wont sync up
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Aug 19, 2007 | iRiver H10 MP3 Player
RCA TH1101 MP3 Player Logo
27 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
