Question about Philips 27PT6441 27" TV
Picture bowed in on left side 2 inches
Horizontal problem on phillips
  • 81 Answers
Probably a bad cap in the horzontal section
Posted on Dec 15, 2006
SOURCE:
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Sony trinitron picture bowed
YOU MAY A PINCUSHION PROBLEM...SEE A TECH....CUSTOMER CONTROLS WILL NOT CORRECT THIS !
Dec 21, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Horizontal lines on top of phillips tv
bad feedback electrolytic in vertical circuit. need tech.
Nov 23, 2008 | Philips TP2797B 27" TV
Picture double an inch from the left side
Your TV most likely has a convergence problem.
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
www.TvRepairKits.com
Nov 12, 2008 | Sony KP-51WS510 51" Rear Projection...
Bowing in the middle like an hour glass
about the zenith it seems you have the flyback transformer malfunctioning - try to change it - delfo
Mar 22, 2008 | Televison & Video
Phillips 60 inch HD rear projection? Convergence!
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 26, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Blue out of whack around sides
I have the convergence problem with the red. After reading your site I replaced the 2 ICs and the problem is worse. Before the only problem was I could not adjust the red horizontal. Now I have no control over the vertical or horizontal and the overall picture is very red and it bows at the top and bottom very bad. A friend said I might have the ribbon connector in wrong or the convergence (silver box?) box maybe bad. Any ideas? Thanks,Dave.
Oct 12, 2007 | Philips 55PP9352 55" Projection Television
2 inch black on both sides of the monitor (Horizontal)
1 it is due to horizntal output trnansistor. 2 capacitor connected to horz output. 3 flyback transformer. hope this will help you.
Oct 08, 2007 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
Sudden discoloration, ghosting, bowed horizontal lines in top and bottom of picture
The convergence ICs probably have a cracked solder joint on the foil side of the circuit board. Re-flowing the the solder would help. I will always replace the convergence ICs when doing this job. The labor remains the same and you will have to pay a few extra bucks for the parts. To fix this yourself, you will need to be able to identify the two convergence ICs, have a basic knowledge of electronics and be able to use a soldering iron. You will also have to do an alignment through the service menu.
Apr 01, 2007 | Samsung HC-P4752W 47" Rear Projection...
PICTURE TROUBLE ON SONY TV ..KV-27FS12
most sony tubes bow in the corners, they just arent built that well
Apr 11, 2006 | Sony KV-27FS12 27" TV
Philips 27PT6441 27" TV Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
